New Rx8 owner
Yozhek
New Rx8 owner
Post by Yozhek »
Hi,
My friend had an Rx8, the engine went bang and he had some 'Rx8 expert' rebuild it, the rebuilt engine was a disaster leaking coolant from one of the main rotor housing seals and when the alternator supposedly failed we found the handful of swarf they left in the ECU box was causing a short, he sold it before anything else went failed. Anyway the way that car drove kinda stuck in my head, good handling, crazy revs and a power band bit like a 2 stroke, awesome :D
Fast forward 3 years and i managed to retire a little early and got to thinking about a fun toy to keep me occupied, somehow i remembered the Rx8, cheap to buy, lots of fun and having been in the motor trade for many years i'm not scared of the odd engine rebuild. So, off i went looking at Rx8's.
Now i was expecting some corrosion but the dented rust riddled rubbish i was driving hundreds of miles to look at (and that is just southern cars) was a bit of an eye opener :shock:
Long story short, i eventually found a good one and it was only 10 miles from where i live! Unmolested origional 06 plate with 41,000 miles with nearly perfect strato blue paint, lovely, drove like a new car :D the down side it is a 190hp but i guess i can live with that.
Of course there is rust in the usual places but mostly surface corrosion. After powerwashing the underside it looked pretty grim but a few hours with a needle gun revealed most of this was just staining on the stone chip and no swelling or weakness along the bottom of the sills or chassis. It did have holes starting at the front of the rear wheel arch/back of the sill which needed cutting out and plating and also the lower 3 inches of the wheel arch needed remaking, some seriously difficult shapes to make!
The welding and paint is now done and i'm in the process of dosing every inch of it with Dinitrol :thumright: :|
Ade
These users thanked the author Yozhek for the post:
30405 (Mon Jan 04, 2021 7:11 pm)
Has thanked: 266 times
Been thanked: 320 times
Re: New Rx8 owner
Post by Shagrington »
Hi and :welcome: Yozhek :D Well done on finding a good one - and only 41k miles too. There's nothing wrong with a good 190, there really isn't much difference between that and a 230 on the road and the 190 is actually a bit better to drive in town.
Have a good read through whatever in the FAQ section you didn't already read :study: and then (and just ignore me if you know all this already - I suspect you really won't need my tips) here are my best tips for keeping it all running sweetly:
2. Never [-X turn off the engine before it has reached at least somewhere towards normal operating temperature (should only take a minute or two, but best to go for a short drive if just swapping cars round on the drive etc). Switching off cold risks flooding, which is a real :censored: with a rotary engine. Mazda recommend rev to 4k and hold it for 8-10 seconds switching off while still revving if you have no option but to switch off cold (it is not necessary to do this in any other circumstance).
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it :twisted: ) and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great. ;)
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (when we can start them again - or if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more. :thumright:
casey
Has thanked: 508 times
Been thanked: 453 times
Re: New Rx8 owner
Post by casey »
:welcome: Yozhek, a good story, and I'm pleased to hear you've found what sounds to be a good one.
As Shagrington said, don't worry about it being a 192. The gearing on that model does a lot to make it a pretty fair match for the 231 in the real world. We've done several timed circuit events and the 192 and 231 come in with very similar times. In a tight slalom course, a 192 actually did the fastest times at an event I attended many moons ago.
I'd miss the 9k buzzer though ;)
casey
Re: New Rx8 owner
Post by casey »
Can't tell with the flash on that photo, but you mention the car is "Strato Blue", which is a very dark blue. Your photo suggests the much lighter "Winning Blue".
Oh, and your profile states "Titanium Grey", just to confuse :-k :D
HarSc
Has thanked: 569 times
Been thanked: 526 times
Re: New Rx8 owner
Post by HarSc »
:welcome: Awesome to see you've managed to find yourself a good one! At least rust-wise, and that's becoming a harder task these days! Top job. :thumleft:
casey wrote:
Mon Jan 04, 2021 7:03 pm
Hey, maybe it's just multicolour camouflage ;) :lol:
Some guy from oooop north ;) | Harry | Membership Secretary | Media Team
- My Main RX-8 R3 [MHZ 3800] thread here
- My Project Banana [GL04 MXU] thread here
- My Mazda 2 DE daily thread here
- My engine disassembly shenanigans here
SmuttyHutty
Has thanked: 252 times
Been thanked: 206 times
Re: New Rx8 owner
Post by SmuttyHutty »
I'll add to the 192 vs 231 debate. I felt for a long time that I had missed out by not having a 231 and then I bought a PZ. Having driven them both I can say that the ride on the 192 is far more comfortable. The gearing in the 192 seems more sensible for the real world. And waiting for the beep on the 231 takes forever!
I just wish I could get rid of the damn rattles in each of them.
HarSc
Re: New Rx8 owner
Post by HarSc »
SmuttyHutty wrote:
Mon Jan 04, 2021 7:48 pm
It just keeps going and going and going and going and going and going and going and going and going and going and going and going and going and going and going
...and I love it :lol: :shaking2: :xmasnuts:
Ollie
Been thanked: 284 times
Re: New Rx8 owner
Post by Ollie »
Doesn't take long at all in 2nd or 3rd. :p But you will suddenly be going about 80mph for some reason.
SmuttyHutty
Re: New Rx8 owner
1st......................beep.2nd.....................beep.3rd.........................beep.4th5th6th
30405
Has thanked: 750 times
Been thanked: 175 times
Re: New Rx8 owner
Post by 30405 »
SmuttyHutty wrote:1st......................beep.2nd.....................beep.3rd.........................beep.4th5th6th
What are 4,5 & 6 used for??????
Has thanked: 742 times
Re: New Rx8 owner
Post by nightfire10 »
Autobahn ImageImage
30405 (Mon Jan 04, 2021 9:27 pm)
SmuttyHutty
Re: New Rx8 owner
Mon Jan 04, 2021 9:26 pm
Make me feel like I am being economical
30405
Re: New Rx8 owner
Post by 30405 »
It's called an rx8 for a reason. Any mpg above that is wasted potential.
SmuttyHutty
Re: New Rx8 owner
The words of a man who puts napalm on his cornflakes.
These users thanked the author SmuttyHutty for the post:
30405 (Mon Jan 04, 2021 9:47 pm)
30405
Re: New Rx8 owner
Post by 30405 »
Yozhek wrote:Hi,
Ade
Welcome to the club! Sounds like your diving straight in. Please consider putting a build thread so I can be nosey and steall ideas Image
Ollie
Re: New Rx8 owner
Post by Ollie »
SmuttyHutty wrote:
Mon Jan 04, 2021 9:08 pm
When I was driving my 8 to and from work it was down country lanes... Get stuck behind a tractor or a slow driver... Sat in 3rd gear forever anyway... Would barely need 4th. :p 6th is purely an economy gear in any car anyway.
Has thanked: 1581 times
Been thanked: 365 times
New Rx8 owner
Post by GreySilver Beast »
Hi & :welcome: to the RX-8OC :thumleft:
<<<<<< Please put your Location in your Profile Box, it will help us to know where you are, if required any help in the future :thumright:
Please check out the EVENTS SECTION's for anything coming up soon in your area :thumleft:
Yozhek
Re: New Rx8 owner
Post by Yozhek »
Thanks for the welcome and advice :D
My profile is corrected now, my first purchase was a Titanium Grey 231 that was pretty good underneath but had the roof and bonnet painted due to vandalism. I hate doing bodywork :( so this is up for sale now.
Repairs are done both sides now and the dirty job of Dinitroling the inside and out is in progress
SmuttyHutty (Tue Jan 05, 2021 10:29 am)
