New
- Has thanked: 17 times
- Been thanked: 7 times
New
Hi....just joined club. Picking up my white R3 tomorrow. Any tips on the differences with looking after this beast much appreciated. Thanks, Ben.
Re: New
Others may pop in with more advice. I would just suggest reading the owners manual carefully. There's a digital version in the Technical part of the members area if you don't have a physical one.
I'd suggest checking the oil dipstick every other fuel fill up (as it says in the manual). I'd also suggest waiting a good 20 mins of normal driving before blasting it above 6k rpm. To be sure that the oil has gotten hot enough. Other than that just enjoy like you would in any other car.
There's no need for premixing or oil catch cans etc in the R3. Some people do... but there's no need. Hope you have fun and welcome!
- Has thanked: 252 times
- Been thanked: 206 times
Re: New
Hey Ben - I'd recommend a visit to Ryan Rotary Performance if you're anywhere near Rugby. I saw Carl Ryan in Suffolk a few months ago and has a mini ECU map done which, amongst other things, limited the revs to 4800 until the water temperature reaches (I think) 68 degrees.
- Been thanked: 453 times
Re: New
to the club, Freddie/Ben
New
Hi Ben & to the RX-8OC
Re: New
Hi and Freddie (Ben) Did you say you wanted tips? I have some tips that may be of use.
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it with the R3 you do have a redline that rises with the coolant temperature (as shown with the lights on the rev counter) but I still think the above advice is good as it allows time for the oil to warm up too) and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
I see you already joined the club so that saves me including my usual tip #5.
- Freddie (Tue Oct 27, 2020 2:28 pm)
Re: New
Hi Freddie - thanks for joining. Hope you've got the car now and had some fun. You shouldn't need to go for a mini map with the R3 as it should already have the variable red line to stop you over-revving it when cold (though as New Duke said above, just give it 20 mins or so to warm up before trying out the full rev-range - the limiter just helps when you forget!).
Share some pics when you get a chance amongst the rain showers!
Re: New
I stand corrected.Ainmhidh wrote: ↑Mon Oct 26, 2020 3:53 pmHi Freddie - thanks for joining. Hope you've got the car now and had some fun. You shouldn't need to go for a mini map with the R3 as it should already have the variable red line to stop you over-revving it when cold (though as New Duke said above, just give it 20 mins or so to warm up before trying out the full rev-range - the limiter just helps when you forget!).
- Ainmhidh (Tue Oct 27, 2020 9:23 am)
Re: New
Thanks so much for your kind introduction guys....todays run home in Freddy was unlike anything ive ever encountered on 4 wheels.....amazing. His names Fredrickson Fenrir Wankle, and mines Ben LOL. Off for aircon regas, alloy refurb, and a big cleanup from tomorrow.
- These users thanked the author Freddie for the post (total 2):
- 30405 (Mon Oct 26, 2020 6:01 pm) • New Duke (Mon Oct 26, 2020 6:14 pm)
- Forum Administrator
- Has thanked: 47 times
- Been thanked: 155 times
Re: New
You may not get much mpg, but you do get plenty of smiles per hour.
Welcome to the Club Ben.
Forum Admin Team
Forum Admin Team
Re: New
Congratulations and welcome to the club.
- Has thanked: 12 times
- Been thanked: 104 times
Re: New
Welcome to the club!
Another R3 and in white too! Your pretty local to me, high chance of you seeing mine on the roads and vice versa.
Who are you going to be using for the wheel refurb?
Re: New
Cool...we seem to be in somewhat of a minority! Am going to maxwax in Shoreham today as a pre lude to Friday and theyr going to look at the alloys too....who do you reccomend?
Re: New
We always use "Wheel Works" in Crawley.
http://www.wheelworksuk.co.uk/
They actually remove the tyres and proper acid dip the whole wheel before any work is done and powder coat them after any repair work. None of the usual push the tyre back and wet spray etc, this way you get the whole actual wheel done and tyres refitted and balanced to suit.
They offer a few option's, like same day if you book in advance or a three day turn around drop the wheels off and go collect, crazy colours choices and so on.
Cost a little more than the usual places, but as I said above this is a proper tyre off, wheel dipped and powder coated.
