Sometimes it takes an hour to drive 20 minutes
SmuttyHutty
Colour: Nordic Green
Has thanked: 252 times
Been thanked: 206 times
Post by SmuttyHutty »
Hello everyone,
Thought I'd sort out a profile and read around the forums for a bit before becoming a member.
Bought a fab 2004 192 RX8 in virtually original condition just over a year ago. It had 3 previous owners - a lady who used Mazda for every service and kept it original. An enthusiast who had it about a year and changed the oil and filter. Then a total car nut who replaced coil packs and plugs, oil and filter and seemed to polish it more than he drove it. I paid £1600 for the car with, IIRC about 64k on the clock.
I've covered 3000 miles in my first year and popped on a 2kw starter motor (there were no issues - this was preventative), changed the gearbox and diff oils (different grades for each unit) and replaced the original catback with a stainless steel ToyoSports version.
Just recently (600 miles ago) I had a new genuine Exedy clutch fitted and pilot bearing - OMG that has made a difference. The garage said the old one was the original and almost down to the rivets. And the other day I had some refurbished polyurethan engine mounts fitted.
On that topic, I genuinely cannot tell the difference between the old ones (which were in good nick despite being 16 years old) and the new ones. But, again, this was a partially preventative measure.
The car runs and works perfectly, although I get a slight notchiness when changing from 2nd into 3rd. That's why I had the mounts changed.
I've bought a rotary compression tester and will give it a whirl before putting the car to bed for the winter.
Oh, and I had RRP do a mini-map in line with the tutorial that they put on YouTube. So now I can rev to 9000rpm which is useful for safe overtaking although I rarely go that high.
The car is in fab condition and I plan to keep it that way.
Has thanked: 1581 times
Been thanked: 365 times
Post by GreySilver Beast »
Hi & :welcome: to the RX-8OC :thumleft:
SmuttyHutty
Re: Sometimes it takes an hour to drive 20 minutes
Thank you.
I meant to say that the title of my welcome refers to driving in East Anglia. It genuinely does sometimes take an hour to drive a 20 minute journey.
I see that there are meets in Essex from time to time - I'll try and get along to one at some point in the spring when the car wakes up. Any excuse to get some miles on the clock....
casey
Has thanked: 507 times
Been thanked: 451 times
Post by casey »
:welcome: Nordic Green is quite a rare colour, be good to see one at an Essex meet next Spring (hoping the covid restrictions are behind us by then!).
SmuttyHutty (Thu Oct 01, 2020 9:40 pm)
Ainmhidh
Has thanked: 233 times
Been thanked: 146 times
Post by Ainmhidh »
SmuttyHutty wrote:
Thu Oct 01, 2020 3:15 pm
Hi SmuttyHutty,
I thought you meant that you'd go out for a 20 minute drive and enjoy it so much that you kept going for an hour!
These users thanked the author Ainmhidh for the post:
SmuttyHutty (Fri Oct 02, 2020 6:45 am)
SmuttyHutty
After having the ECU tweaked by RRP I have to say that the car is getting a few more driving hours...
*thomas*
Has thanked: 36 times
Been thanked: 34 times
Post by *thomas* »
SmuttyHutty wrote:
Fri Oct 02, 2020 6:47 am
Don't forget the OEM bearings are not designed to rev it up to 9000 rpm. I have a 192bhp and have been thinking about having this done, but I fear the bearings will give out.
SmuttyHutty
Yeah, I was warned to not do it too often. I found a few times before I had the tweak that I would hit the limiter when overtaking. For the brief moments when I do go above 7500rpm it is safer than the lurch when the limiter is hit.
I guess it is a risk/return decision.
Check out the RRP YouTube video about the changes they make. IIRC I cannot go above 4800rpm until the water temperature is above 68 degrees, although I keep it below 4000rpm until I am well into my journey. The fuel trims were adjusted and I think there were a couple of other things.
These users thanked the author SmuttyHutty for the post:
*thomas* (Fri Oct 02, 2020 8:38 am)
*thomas*
Post by *thomas* »
I understand why you've done it. It'd do it to if I wasn't so afraid of the bearings giving out... I rarely hit the limiter when overtaking tough... I'll check out the video!
New Duke
Has thanked: 695 times
Been thanked: 561 times
Post by New Duke »
SmuttyHutty wrote:
Fri Oct 02, 2020 8:31 am
That's my perspective on it as well. RRP raised my cut off to 10000rpm with a similar suggestion not to hit it often (which I do anyway :lol: ). Makes a big difference on track and at traffic lights when the S4 or equivalent in the other lane fancies a go.
Glad you're enjoying the car :salut:
SmuttyHutty (Fri Oct 02, 2020 7:34 pm)
Has thanked: 444 times
Been thanked: 2087 times
The raised rev limit is less of an issue if the engine has been rebuilt by someone competent, as they would have replaced the fragile 192 rear stationary bearing with the one for the 231.
Basically the 4-port engine was never designed to run with a manual gearbox, the UK being one of very few markets where this was specified.
Auto-'boxes don't apply any lateral thrust down the e-shaft, unlike a clutch....
Has thanked: 266 times
Been thanked: 320 times
Post by Shagrington »
Hi and :welcome: SmuttyHutty. :D
SmuttyHutty (Sat Oct 03, 2020 3:19 pm)
SmuttyHutty
Right fellas. Fees paid and membership gained.
Do I get to learn the handshake?
These users thanked the author SmuttyHutty for the post (total 2):
30405 (Wed Oct 07, 2020 8:05 am) • casey (Thu Oct 08, 2020 6:42 pm)
goodeggbob
RX-8: Kuro
Colour: Kuro Black
Has thanked: 219 times
Been thanked: 350 times
Post by goodeggbob »
i am sure Nigel will be happy to take you through the initiation process, i am still reeling 18 months on.
These users thanked the author goodeggbob for the post (total 4):
30405 (Wed Oct 07, 2020 8:04 am) • SmuttyHutty (Wed Oct 07, 2020 9:02 am) • nightfire10 (Thu Oct 08, 2020 8:22 pm) • GreySilver Beast (Thu Oct 08, 2020 8:49 pm)
Rob :thumright:
Thanks for joining =D> you should get your status upgraded and gain access to all the stuff in the members areas you couldn't see before too long (it just needs the right person to see and process your application then to hit the right buttons). The handshake has to be mimed from a distance of 2 metres for the time being.
These users thanked the author Shagrington for the post (total 3):
30405 (Wed Oct 07, 2020 9:46 am) • Ainmhidh (Wed Oct 07, 2020 10:07 am) • SmuttyHutty (Thu Oct 08, 2020 7:56 pm)
Ainmhidh
Post by Ainmhidh »
Should be up and running now. Welcome in.
Has thanked: 2572 times
Been thanked: 940 times
Post by ChrisHolmes »
:whathesaid: and :whathesaid: :welcome:
SmuttyHutty
Tis much appreciated.
I'm hoping the Essex lads might meet up in the next few weeks before the RX8 is put to bed.
