Hello all new here
- Colour: Aluminium Silver
- Has thanked: 14 times
Hello all new here
Morning all bought a 2004 rx8 2 weeks ago and the same fault code p2288 injector control pressure to high and I can't find anything on the forums or the Web about this problem in a rotary. If I obtain new injectors and a fuel rail would this problem dissappear or could it be an ecu problem? The car has been sitting for a number of years on a farm as it was going to be a project that was never started.
Thanks in advance
Thanks in advance
Hello all new here
Hi & to the RX-8OC
Re: Hello all new here
You need to double check that code as P2288 isn't recognised by the RX-8 PCM
- SikSyco (Thu Apr 29, 2021 8:08 pm)
I did find a thread in here that listed fault codes and it wasn't on there, guessing it's to do with the cheap obd scanner, will have to double check, thanks
Hi and SikSyco. I don't know if these are useful to you right now, but it would be rude of me not to post this - Have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (they were all postponed but are beginning to happen again now) - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
Awesome thank you for all that info, the car had been sitting for around 3 to 4 years prior to me getting it and I did manage to get it going last Friday for a quick run out it was a blast, now I'm upgrading the ignition parts as it takes a while to start and hoping that clears it up.
I have seen spark plugs on ebay from Jap4mance and wondering if the deal maybe too good to be true https://www.ebay.co.uk/itm/271001439967
Every where around here I'm looking at nearly double that if they don't have a sale on
Sent from my HRY-LX1 using Tapatalk
- Has thanked: 176 times
- Been thanked: 324 times
Quite a few of us buy plugs from JP4MANCE with no issues, there was a bit of chat about it yesterday in another thread.
- SikSyco (Thu Aug 27, 2020 10:24 am)
Thanks just read the thread, will give them a tryNickp47 wrote:Quite a few of us buy plugs from JP4MANCE with no issues, there was a bit of chat about it yesterday in another thread.
Is there anyway to find out the owner of the car before I picked it up? It has a forum club sticker on the back window
If you have the number plate the person who owned it may have added it to the list in the members' sections - somebody could check there for you.
Hi all, new problem today, reinstalled the battery after a good charge done the ecu refresh by hitting the brake 20 times and left the car to run for 10 minutes and noticed a knocking from the engine while idling, any ideas?
What sort of knocking?
It could be engine mounts or a loose heatshield on the exhaust.
Does the frequency of the knock follow engine revs?
If it's more of a tapping then it could be the linkage on the SSV.
I ne er reved the engine as too scared it could of been something worse, it was defiantly coming from the engine somewhere. It was more a knocking than a tapping,
Update it seems to be the air compressor after it stops blowing air down to the cat it seems.
Be interested to hear what your insurance company says when you tell them about the decat - unless you choose not to declare the mod - having posted it on a public forum
That's the exhaust done, now just brake pads and another 8 will be back on the road
Anyone have any opinions on brake pads will just be for road use at the moment and has any one tried the brake caliper rebuild kits from ebay?
Look at this on eBay
https://www.ebay.co.uk/itm/332858428352
Frentech rebuild kits are good quality from what I hear. I was actually going to use one myself whilst rebuilding my spare callipers.
Looking over cooling mods would it be more bebificial to go with a fan controller kit which splices into a line or change the the thermostat for the mishimoto one?
Joining the club will give you access to all the various FAQs and DIY How To Do notes and all the technical manuals and members car projects. Plus discounts from numerous suppliers so you can soon save the cost of your subscription.
The bar that runs from wheel arch to wheel arch under the bonnet, the one the batters box sits on and the air box, is this structural? Can it be replaced? Changing the radiator today and while removing the undertray a bolt came out with part of this bar on it after inspecting it looks pretty rusty.
Yes it’s structural and people have sourced them from donor cars and fitted to replace rotted ones.
