'Allo 'Allo!
- Has thanked: 16 times
- Been thanked: 9 times
'Allo 'Allo!
Hello! Having bought my R3 on saturday just gone, and having trawled the forums beforehand I thought I may as well join the club and say hi!
Going across to RR on monday as they're not too too far from me for a master reset service and then we'll fix the other minor issues from there
(I know this photo is a little posey but it's the only semi-decent one I had to hand )
- These users thanked the author Whizzp for the post (total 4):
- 30405 (Fri Aug 14, 2020 1:20 pm) • Broron (Fri Aug 14, 2020 4:58 pm) • v-rex (Fri Aug 14, 2020 10:09 pm) • Ainmhidh (Sat Aug 15, 2020 12:01 pm)
Ben
- Been thanked: 451 times
Re: 'Allo 'Allo!
Hi and Whizzp. Looks like a very nice R3 you have there
I look forward to more pictures when you get a chance.
- Whizzp (Fri Aug 14, 2020 1:26 pm)
Re: 'Allo 'Allo!
Hi and Whizzp and thanks for joining the club already.
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it with the R3 you do have a redline that rises with the coolant temperature (as shown with the lights on the rev counter) but I still think the above advice is good as it allows time for the oil to warm up too) and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
No need for my usual tip #5 as you have already joined the club
- Has thanked: 75 times
- Been thanked: 34 times
Re: 'Allo 'Allo!
- These users thanked the author geofftl1000r for the post:
- Whizzp (Fri Aug 14, 2020 10:30 pm)
40th Anniversary RX8
- Has thanked: 566 times
- Been thanked: 520 times
Re: 'Allo 'Allo!
Got to say, that's a really nice looking R3 you have picked up. I hope you enjoy driving it! (and looking at it in all it's glory of course )
- Whizzp (Fri Aug 14, 2020 10:34 pm)
- Been thanked: 109 times
Re: 'Allo 'Allo!
Good choice on the R3...but then..I'm a bit biased
- Has thanked: 513 times
- Been thanked: 172 times
Re: 'Allo 'Allo!
I like that blue colour on the R3. Excellent choice!
- These users thanked the author v-rex for the post:
Re: 'Allo 'Allo!
I will certainly post more once I have more!
Why thank you!
I'm a real fan of that. What's with the gloss grill? Is that something you did yourself or is there a part for it?
It's the first thing that everyone comments on! Was really the thing that drew me to this one over some of the others for sale at the moment.
Ben
- Forum Administrator
- Has thanked: 47 times
- Been thanked: 155 times
Re: 'Allo 'Allo!
Naturally, I approve.
Welcome to the Club.
- These users thanked the author brix79 for the post:
- Whizzp (Fri Aug 14, 2020 10:48 pm)
Forum Admin Team
Forum Admin Team
Re: 'Allo 'Allo!
Hi & to the RX-8OC
Re: 'Allo 'Allo!
Just a question out of curiosity if you don't mind (if you don't want to say, that's ok!) - how much did you manage to get that beauty for? I'm just wondering what sort of price I'd be looking at to get an R3 as I'm currently looking at S1s mostly
Re: 'Allo 'Allo!
Thanks! What a nice car you have
Random question, how many ABM cars do we know of? Seems to be one of the rarer colours from my understanding.
Ben
Re: 'Allo 'Allo!
- Whizzp (Sat Aug 15, 2020 1:08 pm)
Re: 'Allo 'Allo!
Is there anything this forum can't do?
Ben
- Has thanked: 12 times
- Been thanked: 104 times
Re: 'Allo 'Allo!
Nice, welcome to the club!
- Whizzp (Sun Aug 16, 2020 5:33 pm)
'Allo 'Allo!
Your car is now on the R3 Register
- Whizzp (Sun Aug 16, 2020 5:31 pm)
Re: 'Allo 'Allo!
Thanks very much! My reg is SH10 UCT though, not SH10 UCF
- These users thanked the author Whizzp for the post:
- GreySilver Beast (Sun Aug 16, 2020 5:54 pm)
Ben
