Hi guys and girls.
I’ve just bought an RX-8 nemesis which developed an engine management light on the way home.
I’ve plugged in my obd and it comes back as P0420 catalyst system efficiency below threshold bank 1
I’ve read that this could be anything from a new cat to o2 sensor to a leaking vacuum pipe? Any ideas on how to diagnose?
I’ve not jacked it up and had a good look underneath yet, I’ll do that tomorrow, anything I should look for when I do?
It ran beautifully up until the light came on then started running a little rough and developed a whirring/whistling noise from the engine, I don’t know if this has anything to do with the code or not? I’ve read somewhere that it could be the air intake but I’ve checked the filter and cleaned the maf with no improvement!
Any help would be appreciated and apologies if this is in the wrong place!
Just bought a RX-8 nemesis and have code P0420
Hi & to the RX-8OC
- RX-8: Nemesis
Re: Just bought a RX-8 nemesis and have code P0420
All doneGreySilver Beast wrote: ↑Sun Jul 05, 2020 7:47 pmHi & to the RX-8OC
- These users thanked the author Srobo for the post:
- GreySilver Beast (Sun Jul 05, 2020 8:04 pm)
Hi and Srobo. You are right, that code could be any one of many things - how to diagnose which it might be is beyond my own skills ... if it is any help (probably not) I got the same code on my way home from the club AGM in February - the light came on as soon as I got on the motorway so I stopped in the next services and read the code. As it was that code I cleared it and carried on thinking I should be OK to get home and if I got a repeat I'd get it checked out. It hasn't happened again ever since ... but that is just me and my car.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (when we start them again, they're currently all postponed for obvious reasons - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- RX-8: Import
- Colour: Black Cherry
- Been thanked: 119 times
P0420 usually means it's been decatted. Have a look at your exhaust system underneath and see what mid pipe is fitted.
Black Cherry Mica
- Been thanked: 93 times
Hi there, welcome to the mad world of rotary as said above the code relates to the cat or lack of? I would also look at changing the coils, leads and plugs. I can’t stress enough how important this is for a rotary engine. But don’t buy cheap eBay ones. Go for genuine Mazda or as an upgrade look at Ryan rotary coils
We have a monthly meet the second Thursday of the month, which is this Thursday. We are meeting at the viewpoint car park up by Crickley hill, at 7:30. Come along if you would like to and we can have a look T your car and give you any pointers. We will be going for a drive then to a butty wagon for something to eat.
See the Cotswold all sorts thread for more details
Kamikaze
Too many to list.
Too many to list.
- Been thanked: 283 times
I think that code can also relate to longish motorway drives where the car actually gets a proper chance to check the cats efficiency if I'm not mistaken? Some people get it once (had it once myself) turn it off and then never see it again without the cat being dead.
other way round
the code relates to a missing or defective cat, however the car can only test the cats efficiency under certain circumstances, hence the code only appearing on long drives.
