Hi, Thomas from Belgium - New rear spindles
- Has thanked: 36 times
- Been thanked: 34 times
Hi all
I just joined the board as I bought my forst RX8 (and Rotory car for that matter) last week. Well, I actually bought it in March, just before Covid, but since it was located in the Netherlands, I could not pick it up.
It's a 2004 car, two owner car (second owner had it for 10 years) and the engine has just been rebuild by a reputable Rotary specialist, so should be fine. It's a 192BHP model and it's bone stock.
I will do some mods to the car once it's road legal (friday, I hope), but am on the lookout for a mazdaspeed bodykit (genuine, not a replica) and a set of R3 wheels... So if anyone has either, drop me a message.
Cheers
T.
Cheers
T.
- These users thanked the author *thomas* for the post:
- Torque23 (Tue Jul 27, 2021 3:55 pm)
Hi Thomas & to the RX-8OC
- *thomas* (Tue Jun 30, 2020 10:41 pm)
Re: Hi, Thomas from Belgium
Hi and *thomas*. Congratulations on finally being able to get your car.
5. We do have an 'overseas' club membership if you think it might be of benefit to you. My usual number 5 tip says to join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (when we start them again, they're currently all postponed for obvious reasons - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
Obviously the local meets will not be local for you and I suspect other events we attend as a club (when they start again) may not be easy for you to get to either. There is the sexy keyring.
- *thomas* (Mon Jul 26, 2021 9:38 pm)
Thanks for the advice. Having to wait for the car has given me the opportunity do to a lot of reading about them. Still, I learn every day .
Re: Hi, Thomas from Belgium - wheels ...
I have a question that is wheel related. I found a thread, but can not reply (new member?).
I have decided that I want a set of BBS wheels so replace my stock 18x8 50ET S1 wheels, but have a few questions about rim and tire size.
The wheels come in:
8*18 ET50
8*18 ET40
8.5*19 ET45
8.5*19 ET35
I was wondering if the last option will still be tucked under the arch (as in: not stick out) and if mated to a 245/35/19 tire, it wouldn't be to much of a compromise? I know R3's run 8*19 et45 with 225/40/19 and people have said the ride can be stiff.
The car is on stock 'sport' suspension, but I'd like it a bit lowered (will probably go Bilstein / Eibach route, and nothing extreme).
The wheels come in:
8*18 ET50
8*18 ET40
8.5*19 ET45
8.5*19 ET35
Re: Hi, Thomas from Belgium - wheels and transmission oil
I'm planning on changing the transmission (5 speed) and diff oil on my car. I have a bunch of castrol syntrax universal plus 75w90 left over from my Subaru.
Specs:
API GL-4 / API GL-5 / MT-1
MAN 3343 S, MAN 341 E3
Scania STO 1:0
MB 235.8
ZF TE-ML 02B, ZF TE-ML 05B, ZF TE-ML 12B, ZF TE-ML 16F, ZF TE-ML 17B, ZF TE-ML 19C, ZF TE-ML 21B
SAE J2360 (MIL-PRF-2105E)
The castrol website it's safe to use in the transmission AND rear diff. But not sure, as it's not specific for LSD diffs...
Specs:
Scania STO 1:0
MB 235.8
- Has thanked: 15 times
- Been thanked: 20 times
The type of diff fitted to the RX8 is not fussy about the oil used, and does not require it to have special friction modifiers. As long as it's correctly weighted, and of GL-5 spec, the stuff you have should be fine.
Some transmissions however are VERY fussy, with some people reporting synchro failure after using oils that meet both GL-4 & GL-5 spec, such as the one you have listed. This is thought to be due to the oil being too slippery for our synchronizers to work effectively, and wearing them out prematurely.
Only use a specific GL-4 rated, 75w-90 oil in the transmission. I have used Redline MT-90, which has improved the shift quality greatly.
- These users thanked the author Craig010 for the post:
- Been thanked: 544 times
true enough but thats for the 6 speed. the 5 speed is reportedly a lot less touchy,
not sure i would use it though. better safe than sorry and all that...
- Been thanked: 451 times
As you have the 5 Speed transmission that oil ought to be OK (it would certainly NOT be OK in the 6 speed!).
Ought to be OK in the diff too.
Reference here: viewtopic.php?f=25&t=50814
- *thomas* (Mon Jul 06, 2020 8:52 pm)
My fault, I didn't realise it was a 5 speed car. As above then, should be fine as the 5 speed is supposedly made of some strong stuff, however not sure it's worth the risk, even with the 5 speed.
Thanks guys for the info. Will use it for the diff, but not for the transmission. I don't like taking risks.
Redline is not easy to obtain over here, but what about Motul Gear 300?
Edit: Castrol Syntrans Multi Vehicle is mentioned in the oil thread (very comprehensive, thanks), will give that a go. It's rated as GL4 only. (no 5)
- Has thanked: 258 times
- Been thanked: 50 times
This trader sells Redline MT-90 and it’s Amazon, so I expect international shipping is easy:*thomas* wrote: ↑Mon Jul 06, 2020 8:52 pmThanks guys for the info. Will use it for the diff, but not for the transmission. I don't like taking risks.
Heads-up that, whilst Redline seems to be the ‘go to’ solution and improved my shifting, it likes to be hot and takes a fairly long time to warm up. Although I hear the 5-speed is made of stronger stuff than the chocolate 6-speed, you may experience some stiffness and notchiness for the first 5mins or so of driving with MT-90. My gear changes feel best after a good 40mins of driving and have felt slickest at track day temperatures.
There was talk on the US forum about a Ford brand transmission oil that performed comparably with Redline, but warmed up more quickly. My notes tell me that it was Ford Motorcraft XT-M5-QS, although I have no first-hand experience of this.
- These users thanked the author R1DSO for the post:
2009 R3 in sparkling black
Racing Beat REVi ram air duct
K&N panel filter
Suffix C Mazda coils
Magnecor leads
Racing Beat header / mid pipe
RRP engine mounts
Hel braided brake lines
Russell speed bleeders
Michelin Pilot Sport 4S tyres
R-Magic shift knob
Heel/toe pedal mod
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
Thanks for the advice. The Castrol I mentioned (and which was also mentioned in the 'oil-thread') is FORD-specific. It could very well be that FORD is using the same stuff (relabeled).
- Been thanked: 2086 times
Mazda were 40% owned by Ford back when the RX-8 was being developed and there was a lot of interaction between the engineering teams and supplier sourcing.
It's no coincidence that Forscan is just as happy talking to the RX-8 PCM as it is to a Focus.
There was much more cooperation between Ford of Europe and Mazda, than between FoE and Ford USA.
It wouldn't surprise me at all to find a FoE specification transmission oil perfect for the 8.
Anyone who can chime in on this? Thanks*thomas* wrote: ↑Thu Jul 02, 2020 2:27 pmI have a question that is wheel related. I found a thread, but can not reply (new member?).
The wheels come in:
8*18 ET50
8*18 ET40
8.5*19 ET45
8.5*19 ET35
Thomas, if you wish I can move the relevant posts to a project thread in the correct section of the forum...
- *thomas* (Tue Jul 27, 2021 2:17 pm)
If this is considered a project, yes, please do. I wasn't to sure because every forum has it's own idea about what makes something a project.
- Been thanked: 17 times
Re: Hi, Thomas from Belgium - New rear spindles
Moderation after checking with OP the journey continues over in the RX8 Discussion forum... https://www.rx8ownersclub.co.uk/forum/v ... =6&t=86847
- These users thanked the author HypoThermia for the post:
- GreySilver Beast (Fri May 05, 2023 1:16 pm)
And still three gears left...
