New RX8 owner
New RX8 owner
Hi fellow rotary owners!
Only had the Rx8 for a few days and loving it so far! It's my wife's car but I am tasked with maintaining it. I also get to have a go once in a while, which is nice
Will have a good look around the forum and I have a few questions to post. For now though it's going to be a steep rotary learning curve!
Have fun,
Nigel
Have fun,
Nigel
- warpc0il
- Has thanked: 822 times
- Been thanked: 3534 times
- Contact:
Re: New RX8 owner
Nigel
Expect a few messages welcoming you on board, including from another "Nigel" on here.
- Ainmhidh
- Has thanked: 531 times
- Been thanked: 454 times
Re: New RX8 owner
Hi Nigel. Welcome in!
- Harrizone
- Founder Member
- Been thanked: 361 times
Re: New RX8 owner
Oh No! Not another Nigel.
You are most welcome here . You will understand my initial comment when the other more notorious Nigel appears, but only after he has consumed his lunchtime meal, bottle of wine and umpteen bars of choccy. Cannot believe he is not here to greet you already if only to up his post count .
- These users thanked the author Harrizone for the post (total 2):
- GreySilver Beast (Thu May 14, 2020 3:12 pm) • nightfire10 (Thu May 14, 2020 3:14 pm)
- GreySilver Beast
- Has thanked: 18434 times
- Been thanked: 4651 times
New RX8 owner
Hi Nigel & to the RX-8OC
- casey
- Has thanked: 2146 times
- Been thanked: 2390 times
Re: New RX8 owner
There's plenty to read on the forum to get you up to speed. If you can't find what you need with the "search" facility then feel free to ask away
- acegeezer
- Has thanked: 168 times
- Been thanked: 133 times
Re: New RX8 owner
Don't forget to become a full member.. you are restricted to just certain topics as a guest .. the best stuff is sitting there waiting for you and with the savings available, you will get back membership fee and then some.. to our forum Nigel
- Shagrington
- Has thanked: 964 times
- Been thanked: 1056 times
Re: New RX8 owner
Hi and Nigel. Have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (when we start them again, they're currently all postponed for obvious reasons - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
Re: New RX8 owner
Thanks for welcome guys and the valuable and useful advice and tips! First job on to do list is to source a good quality sports cat that will go through the mot without any problems . Any recommendations as I don't want to waste money on something that's not up to the job?
Looking forward to the rotary journey. Driving experience so far........its slightly different to our other car but in a good way and also bloody addictive and great fun.........only driven it twice! My wife will have her first drive in it today so fingers crossed she likes the experience...........
Enjoy your weekend folks!
- nightfire10
- Has thanked: 2405 times
- Been thanked: 1156 times
Re: New RX8 owner
Rrp 200cell £499
