New PZ Owner affectionately named "Rusty"
Just wanted to say hello new to the club and car based in Midlands.
- Has thanked: 42 times
- Been thanked: 229 times
Re: New PZ Owner affectionately named "Rusty"
Have a good read up of the various sections you will learn a lot, where in the Midlands are you based?
Hi & to the RX-8OC
<<<<<< Please put your Location in your Profile Box, it will help us to know where you are, if required any help in the future
Please check out the EVENTS SECTION's for anything coming up soon in your area
- b7owa (Fri Feb 21, 2020 7:45 pm)
- Has thanked: 174 times
- Been thanked: 524 times
Might want to consider the midlands meets at the Appleby inn, first Thursday of the month.
- Has thanked: 266 times
- Been thanked: 320 times
Hi and b7owa. Have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
2. Never turn off the engine before it has reached at least somewhere towards normal operating temperature (should only take a minute or two, but best to go for a short drive if just swapping cars round on the drive etc). Switching off cold risks flooding, which is a real with a rotary engine. Mazda recommend rev to 4k and hold it for 8-10 seconds switching off while still revving if you have no option but to switch off cold (it is not necessary to do this in any other circumstance).
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it ) and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- Has thanked: 93 times
- Been thanked: 165 times
Welcome aboard, we all love a good PZ and a not so good one as well.
- Has thanked: 32 times
- Been thanked: 35 times
Welcome fellow PZ owner, post pics when you get chance.
Galaxy Grey PZ number 24.
Large street port. Lots of flames, lots of smiles.
- Has thanked: 121 times
- Been thanked: 202 times
Welcome! I decided not to tempt fate calling mine that, despite how appropriate it may be...
- 30405 (Tue Feb 18, 2020 12:48 pm)
- Been thanked: 283 times
Ive seen shipwrecks with less rust.
- These users thanked the author Ollie for the post (total 2):
- 30405 (Tue Feb 18, 2020 4:07 pm) • b7owa (Fri Feb 21, 2020 7:50 pm)
Not too good with the old URL Image thing but attempted above.
<a href="https://ibb.co/dKQgMLW"><img src="https://i.ibb.co/VBvm9Qj/Side.jpg" alt="Side" border="0"></a>
pics hotlinked for you.
- These users thanked the author qwakers for the post (total 2):
- warpc0il (Fri Feb 21, 2020 8:16 pm) • b7owa (Fri Feb 21, 2020 8:30 pm)
Looks lovely, same colour as mine.
- These users thanked the author Scotty PZ for the post:
- b7owa (Sat Feb 22, 2020 7:05 pm)
