New PZ Owner affectionately named "Rusty"
b7owa
Forum Guest
Forum Guest
Post by b7owa » Mon Feb 17, 2020 11:15 pm
Just wanted to say hello new to the club and car based in Midlands.
Delanor
Has thanked: 13 times
Been thanked: 76 times
Re: New PZ Owner affectionately named "Rusty"
Post by Delanor » Mon Feb 17, 2020 11:41 pm
:welcome:
Have a good read up of the various sections you will learn a lot, where in the Midlands are you based?
Has thanked: 9346 times
Been thanked: 2237 times
Post by GreySilver Beast » Mon Feb 17, 2020 11:45 pm
Hi & :welcome: to the RX-8OC :thumleft:
<<<<<< Please put your Location in your Profile Box, it will help us to know where you are, if required any help in the future :thumright:
b7owa (Fri Feb 21, 2020 7:45 pm)
RX-8OC Club Calendar - R.A.C.E Car Club - NPT Website - GSB III 03/08/13 - Present
S/D-C/limits - RX-8,3MPS,RX-8 R3,GT86 =17 Skid Pan =1 Go Karting =1 Cars Driven =185
3 MPS MKII T/D = 6
RX-8 R3 T/D = 5 + 7 session's
GT86 T/D = 60.5 + 31 session's
Total T/Days Jan 2011 = 71.5 + 38 session's
PaulAV
Has thanked: 51 times
Been thanked: 172 times
Post by PaulAV » Tue Feb 18, 2020 4:24 am
Might want to consider the midlands meets at the Appleby inn, first Thursday of the month.
Has thanked: 785 times
Been thanked: 806 times
Post by Shagrington » Tue Feb 18, 2020 7:32 am
Hi and :welcome: b7owa. :D Have a good read through whatever in the FAQ section you didn't already read :study: and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
2. Never [-X turn off the engine before it has reached at least somewhere towards normal operating temperature (should only take a minute or two, but best to go for a short drive if just swapping cars round on the drive etc). Switching off cold risks flooding, which is a real :censored: with a rotary engine. Mazda recommend rev to 4k and hold it for 8-10 seconds switching off while still revving if you have no option but to switch off cold (it is not necessary to do this in any other circumstance).
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it :twisted: ) and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great. ;)
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more. :thumright:
V8 Power
Has thanked: 85 times
Been thanked: 256 times
Post by V8 Power » Tue Feb 18, 2020 8:41 am
Welcome aboard, we all love a good PZ and a not so good one as well.
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
RRP Coils MSD leads
Scotty PZ
Has thanked: 34 times
Been thanked: 25 times
Post by Scotty PZ » Tue Feb 18, 2020 12:10 pm
Welcome fellow PZ owner, post pics when you get chance.
Galaxy Grey PZ number 24.
Honkytonk
Has thanked: 207 times
Been thanked: 395 times
Post by Honkytonk » Tue Feb 18, 2020 12:40 pm
Welcome! I decided not to tempt fate calling mine that, despite how appropriate it may be...
These users thanked the author Honkytonk for the post:
Vj4sothername (Tue Feb 18, 2020 12:48 pm)
The P-Shed Project Thread
Yorindesarin
Been thanked: 166 times
Post by Yorindesarin » Tue Feb 18, 2020 3:54 pm
Ive seen shipwrecks with less rust. :p
These users thanked the author Yorindesarin for the post (total 2):
Vj4sothername (Tue Feb 18, 2020 4:07 pm) • b7owa (Fri Feb 21, 2020 7:50 pm)
b7owa
Forum Guest
Forum Guest
Post by b7owa » Fri Feb 21, 2020 7:43 pm
:welcome:
Stafford way.
b7owa
Forum Guest
Forum Guest
Post by b7owa » Fri Feb 21, 2020 7:59 pm
Not too good with the old URL Image thing but attempted above.
b7owa
Forum Guest
Forum Guest
<a href="https://ibb.co/dKQgMLW"><img src="https://i.ibb.co/VBvm9Qj/Side.jpg" alt="Side" border="0"></a>
b7owa
Forum Guest
Forum Guest
Post by b7owa » Fri Feb 21, 2020 8:00 pm
Has thanked: 138 times
Been thanked: 502 times
Post by qwakers » Fri Feb 21, 2020 8:07 pm
Post by qwakers » Fri Feb 21, 2020 8:08 pm
pics hotlinked for you.
These users thanked the author qwakers for the post (total 2):
warpc0il (Fri Feb 21, 2020 8:16 pm) • b7owa (Fri Feb 21, 2020 8:30 pm)
Scotty PZ
Post by Scotty PZ » Fri Feb 21, 2020 9:19 pm
Looks lovely, same colour as mine.
These users thanked the author Scotty PZ for the post:
b7owa (Sat Feb 22, 2020 7:05 pm)
Return to “Hello.. I'm new here..”
