Hello from me & Kuro #148
- Has thanked: 15 times
- Been thanked: 20 times
Hi folks,
Just wanted to post a quick intro, as I've been looking around for a long time but never joined or posted, so thought now would be a good time after picking up my 2007 Kuro on Sunday.
I've always liked the RX8, ever since my Dad had a nearly new 192 back in 2006. A couple of years ago, an opportunity came up to purchase a winning blue 231 very cheaply (£350) with no MOT as a "fun car". Although I got it through an MOT after a little work, unfortunately it was in need of too much to make it "right" (rust, engine rebuild, bodywork, steering rack, rust...), so after enjoying it for around 6 months, I decided to move it on.
I never felt like I experienced the RX8 properly, and recently I had decided to change the Toyota Celica T Sport I have been using as the "fun car" for the past 3 years, so I decided to have a little look around for another RX8, albeit a much tidier example with a view to keeping it long term. After a littler searching, I found a very clean looking example of a Kuro online, and after a few phone calls I put a deposit on it.
I wasn't expecting much for £1500, but was pleasantly surprised when I saw the car how clean it was. There didn't appear to be rust in the usual places, and although it wasn't perfect, it was very tidy and it's previous 2 owners had clearly taken care of it (4 matching Toyo Proxies and a stack of paperwork and receipts was a decent sign that it's been looked after). I was happy, paid my money and took it away.
The car isn't without its fault's, which I fully expected at this price point, namely that it's slow to fire up, which is worse when it's cold (which I put down to a combo of an ageing battery and poor ignition system as there are receipts for no-name coils in the history from a couple of years back), there's a shunting through the car when coming on and off the throttle (which I presume is bad engine mounts as there is some vibration when the car is warm at idle too), there's a cheap aftermarket CAT fitted, which will have to go at some point, the drivers heated seat doesn't work, and the wheels need a refurb (as they all do!). However, having had the car on the ramp at work, there is very little rust underneath, and overall I'm really happy with it and pleased to be back behind the wheel of an RX8!
Sorry for going on a bit, but I look forward to being part of the community and hopefully attending some meets etc. in the future. I would post a couple of picture's, but not sure how yet, so I'll leave that to another time!
Craig.
Craig.
- These users thanked the author Craig010 for the post:
- willberry70 (Fri Feb 14, 2020 5:31 pm)
Re: Hello from me & Kuro #148
Hi and Craig010. Sounds good, but get the no-name coils swapped out for the real thing or better (you'll find where to get them if you read around here or ask) asap. A Varta E23 battery is an ideal replacement battery too. The cheap CAT won't last long, so yes get a good one or get a decat and save the cheap one for MOTs.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- Craig010 (Thu Feb 13, 2020 10:21 am)
- Has thanked: 101 times
- Been thanked: 83 times
Do the ignition.. coils, leads, plugs and replace the cat NOW.. don't allow things to degenerate further, good luck with her
EDIT.. Brian beat me to it
- willberry70 (Fri Feb 14, 2020 5:33 pm)
Thanks both for the welcome.
Luckily I haven't gone into this blindly, so I'm pretty clued up on how to keep her running well. Step one will be an oil and filter, as even though it's just been done, it looks like 5w30 fully synth was used, which is a big no-no as I understand it, so some 10w40 semi will be going in.
I've got my eye on the RRP ignition coils and leads kit, with some fresh plugs and a fresh battery for next month. Unsure on whether to go de-cat or sports cat (200 cel) yet though, so I'll have to have a think about that one...
- These users thanked the author Craig010 for the post (total 2):
- Ryan Rotary Performance (Thu Feb 13, 2020 11:51 am) • acegeezer (Thu Feb 13, 2020 1:54 pm)
- Has thanked: 32 times
- Been thanked: 35 times
Welcome to the club you picked a nice model. As others have said, the sooner you can get those bits sorted the better the life of your engine. Post up some pics of you get a chance.
Galaxy Grey PZ number 24.
- Has thanked: 56 times
- Been thanked: 51 times
Welcome, sounds like you have found a decent one to enjoy.
Your in the right place if you need any advice.
Hi Craig & to the RX-8OC
- Has thanked: 175 times
I have the Ryan rotary performance coils and thier 200 cell cat, I would whole heartily recomend them, you could bash out your cheap killer cat as an interim precaution as the cheapo cats can't handle the heat, clog up and cause issues (including engine failure) I've got about 18,000 on Ryan rotary coils and about 12,000 on thier cat
- Craig010 (Thu Feb 13, 2020 5:42 pm)
Thanks all for the welcomes. I've now joined up to the club officially too
I'm looking forward to getting back to where she should be in terms of ignition and general running. Hopefully we'll have some decent weather soon so I can start doing a few bit and bobs.
And as I've now figured out how, here are a couple of picture's...
- Has thanked: 271 times
- Been thanked: 28 times
Ah such a lovely sparkling black sight.
I'm #400 and if you want it to last listen to the guys posting above
Mine's fairly stock but I dropped in new RRP mkII coils and it really picked it up
- These users thanked the author willberry70 for the post:
- Craig010 (Fri Feb 14, 2020 11:45 pm)
Events Coordinator
Events Coordinator
- Has thanked: 219 times
- Been thanked: 350 times
You dropped the coils in?
- willberry70 (Sat Feb 15, 2020 1:20 pm)
I was just thinking that Rob, think he means he dropped the box into Lukes hands. Hahaha, sorry Will, love your really.
- These users thanked the author PaulAV for the post (total 2):
- goodeggbob (Fri Feb 14, 2020 11:17 pm) • willberry70 (Sat Feb 15, 2020 1:20 pm)
I'm hoping the RRP coils will liven up the lower end of the rev range and make it a bit more responsive as she's a bit flat down there ATM.
Below 3,000 revs the engine isn't that lively, you effectively need twice the revs of a conventional engine, 4-7 thousand is where the magic happens, if your coils aren't the best you will notice better performance, might want to make sure everything is at its best, eccentric shaft sensor clean, maf sensor clean, airfilter clean and decent leads and spark plugs.
I understand that you need to spin these engines up as peak torque is so high in the rev range - I'm just comparing it to my previous 231 which wasn't in the best of health, but didn't seem as flat as this one does.
I'm sure things will improve once the ign. system is renewed/upgraded and I've gone through the car properly (new air filter, clean the MAF etc.). It's already more responsive then when I picked it up 500 miles ago (in only 5 days!!) by just being used I think.
- willberry70 (Sat Feb 15, 2020 1:22 pm)
Ahh, you got so many Kuros I didn't think you'd remember mine
It only took (almost entirely you) a couple of hours...maybe three. Thanks for the tea by the way
- goodeggbob (Sat Feb 15, 2020 3:20 pm)
Events Coordinator
Events Coordinator
I think both yourself and Rob are well aware of my mechanical aptitude.
Events Coordinator
Events Coordinator
Will, you love the car, that's all that matters, if we can help you to love it actually on the road I'm sure both me and Rob are happy to help
- willberry70 (Sat Feb 15, 2020 1:26 pm) • goodeggbob (Sat Feb 15, 2020 3:21 pm)
Yeah, mine went from being willing to pick up from 3.5k with coils on the way out, to picking up from 2.5k with the RRP mk2s (thanks to goodeggrob ). Obvs 3.5 is still better etc. Improved mpg by 10% too, but still dreadful .Craig010 wrote: ↑Sat Feb 15, 2020 12:54 amI understand that you need to spin these engines up as peak torque is so high in the rev range - I'm just comparing it to my previous 231 which wasn't in the best of health, but didn't seem as flat as this one does.
Events Coordinator
Events Coordinator
That's good to hear, and I'll definitely be investing in a set in March.willberry70 wrote: ↑Sat Feb 15, 2020 1:25 pmYeah, mine went from being willing to pick up from 3.5k with coils on the way out, to picking up from 2.5k with the RRP mk2s (thanks to goodeggrob ). Obvs 3.5 is still better etc. Improved mpg by 10% too, but still dreadful .
I actually changed the battery in the car today, and afterwards she started up much quicker and began running much better, not as lumpy, and the hesitation on the throttle / jerkiness (which I thought was dead engine mounts) has reduced too! Must have needed a PCM reset I thought, so then I did the 20 brake stomp just to be sure, and she's smoothed out a bit more again! I can't believe how much difference a reset has made. I know the throttle body was replaced just before I bought the car, so imagine it's something to do with that - it was likely never reset after.
- willberry70 (Sat Feb 15, 2020 5:39 pm)
