Hello All! Guy here.
Proud owner of an 06 192 RX8 Sunlight Silver. Brought with a fresh engine rebuild. I've just finished my 1000 mile run-in and had it compression tested and an oil change and oh boy am I enjoying it now
Looking forward to getting stuck into the forums.
Not sure if I should mention here or in General discussion but the clutch becomes a different beast when it's been stuck in traffic for a while. Biting point moves right up and both my partner and I find it quite unpredictable to drive at this point. I've done some proper digging around on these forums and would I be right in thinking being an early 2006 model, it is the clutch slave cylinder? And that replacing this and bleeding the system will solve this?
Also, the car had the dreaded 10.0.1 firmware. I bought myself a 9.67 Head Unit and it's now fitted. Firmware version checked and confirmed. I've got a bluetooth adapter in the back which is receiving power as my phone can connect to it no problem but I cannot get the stereo into EX Mode. Neither holding or double pressing the CD button or the Tape/MD button will work. I've done a tonne of reading on this and no joy. Am I missing something?
Let me know if I should post these questions in General
Content new RX8 Owner
Re: Content new RX8 Owner
The Slave cylinder issue applies to cars with VINs lower than JM1 FE**** ** 206481 (produced before May 1, 2006), so yours might be within that.guykjw wrote: ↑Thu Dec 12, 2019 8:46 amthe clutch becomes a different beast when it's been stuck in traffic for a while. Biting point moves right up and both my partner and I find it quite unpredictable to drive at this point. I've done some proper digging around on these forums and would I be right in thinking being an early 2006 model, it is the clutch slave cylinder? And that replacing this and bleeding the system will solve this?
However the symptoms of the problem are different. With the original slave cylinder, when the powertrain gets really hot the bite point moves down until eventually you can't get the clutch fully disengaged, even with the pedal on the floor.
There's something else going on with your clutch.
I suspect that, even if the brake fluid had been changed (I should be every 2-3 years) then the fluid in the clutch line hasn't.
Most garages and dealers "forget" this, as it's a lot more messing about and most owners wouldn't know and can't check.
Hi Guy & to the RX-8OC
<<<<<< Please change your colour choice to Sunlight Silver Metallic
- Has thanked: 6 times
- Been thanked: 13 times
The OEM clutch line can also expand when it gets hot, swapping this for a SS one fixed the issue I had with my old RX8's clutch.
Hi and guykjw. Looks good (and a silver 192 - best combination of course ). I'll leave others who know about clutches and stereos etc to answer your immediate questions ... and if that doesn't happen here then yes ask again in the 'RX-8 Discussion' section.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (or if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
Ah okay. So getting the clutch line fluid changed would be the first port-of-call then.warpc0il wrote: ↑Thu Dec 12, 2019 10:41 amThe Slave cylinder issue applies to cars with VINs lower than JM1 FE**** ** 206481 (produced before May 1, 2006), so yours might be within that.guykjw wrote: ↑Thu Dec 12, 2019 8:46 amthe clutch becomes a different beast when it's been stuck in traffic for a while. Biting point moves right up and both my partner and I find it quite unpredictable to drive at this point. I've done some proper digging around on these forums and would I be right in thinking being an early 2006 model, it is the clutch slave cylinder? And that replacing this and bleeding the system will solve this?
I'll check my VIN number too and if I'm in the affected range then I'll get a new slave cylinder put in as it doesn't look like an expensive part and I'm sure it won't harm to 'future-proof' it.
Thank you!
This makes sense! If I'm going to get the system bled it makes sense to replace the lines too. Thanks!
Thanks for the warm welcome and the info I bought the car from Warren Rotaries so the guys there got me fairly clued up on the basics. I'd probably have flooded the thing already otherwise!Shagrington wrote: ↑Fri Dec 13, 2019 2:55 amHi and guykjw. Looks good (and a silver 192 - best combination of course ). I'll leave others who know about clutches and stereos etc to answer your immediate questions ... and if that doesn't happen here then yes ask again in the 'RX-8 Discussion' section.
