Hi all,
New kid on the block here. I'm from Newcastle but living "down South" near Durham now...
Bought a 2005 231 in Velocity Red yesterday. 74k, Good solid history, good compression, good warm starting, etc, etc. My first RX8 but my buddy had one so I know a little about what I've let myself in for.
Good to be here!
Cheers,
David
New member in Durham, North East
- Has thanked: 27 times
- Been thanked: 2080 times
Re: New member in Durham, North East
Hi David, see my response to your technical question.
The welcome wagon will be along soon...
- 30405 (Wed Oct 30, 2019 8:05 pm)
- Been thanked: 3 times
Hi David, welcome to the club. theres members here from newcastle down to stockton.
the next club meet is probably next year now but plenty of advice when needed on here
viewtopic.php?f=164&t=73877&p=1226193&h ... t#p1226193
- These users thanked the author PaLow73 for the post:
- CylonOne (Wed Oct 30, 2019 8:11 pm)
Paul
Galaxy Grey 231, Rotary Revs D585-R Coils, NGK Iridium plugs, Essex Rotary Uprated Oil Regulator
- Has thanked: 750 times
- Been thanked: 175 times
Welcome!
Fantastic! Thanks for the welcomePaLow73 wrote: ↑Wed Oct 30, 2019 8:01 pmHi David, welcome to the club. theres members here from newcastle down to stockton.
I paid £900 for a 2005 Velocity Red 231. Full stamped Mazda and then later independent history, Decent compressions, no blue or white smoke and good hot starting. It has one mid-sized dent in the drivers door, where someone tried to close the suicide door with the drivers door already closed
Apart from that, it's pretty sweet. Engine sounds and runs lovely. It's on 74k, no rebuild. For the money I paid I just thought to myself that if it dies in 3 days then so be it! ...but it seems pretty happy. It's been premixed, yet still has the cat on which was a bit of a concern. But the cat's not glowing and it passed a MOT and emissions test 2 weeks ago, with no advisories.
Only issue I have is that the car is unsettled on the front end when coming off the power from hard acceleration. Dave is kindly advising me on that, on another thread!
Thanks, and would love to get along to the next North East meet
Hi and CylonOne. Sounds like you're pretty much sorted, but it would be rude if I didn't give you my usual greeting for newbies.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- CylonOne (Wed Oct 30, 2019 9:09 pm)
Hi David & to the RX-8OC
- CylonOne (Wed Oct 30, 2019 10:18 pm)
