I just want to say Hi to everyone, My name is Ross, I'm 30 live in South Wales and apologise in advance for possibly bombarding some topics with post . Only this month I bought myself a 2004 231. It's currently a non runner but looking forward to bring it back to life.
New owner and new member
Re: New owner and new member
Hi and Rosssheehan76. Good luck and well done on bringing a non-runner back to life.
Have a good read through whatever in the FAQ section you didn't already read and then (for when you do get it running again - and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (or if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- RX-8: Prospective Buyer
- Been thanked: 3 times
Howdy fellow new member! How did you figured out the not running issue?
Hi Ross & to the RX-8OC
- Has thanked: 750 times
- Been thanked: 175 times
Welcome to the club! You'll find everything here to get the car running. If you get stuck feel free to ask.
