New RX8 owner - hello!
Hi guys,
Just wanted to introduce myself before I start searching around the forum.
I've bought a 2008 stormy blue RX8 recently, which I'm attempting to clean up a little and have as a fun occasional car.
Have wanted one for years, so really glad to have finally ventured into ownership.
I've got a battery drain issue currently where the centre console (where the clock is) stays illuminated when the car is locked. Any one have experience with this? Really need to have trust that I can leave it for more than a couple days without having to jump start.
Anyway, hello to you all
Last edited by Mattblack_lude on Sat May 18, 2019 7:46 pm, edited 1 time in total.
- Been thanked: 2080 times
Re: New RX8 owner - hello!
Does the alarm arm when you lock the car, e.g. do the indicators flash to confirm?
I believe so - seems to lock fine and indicators do flash. Oddly I've just gone out to it and the dash light isn't on now - going to check every hour so find out if its sporadically doing it. Strange.
Hi and Mattblack_lude. It's been a while since I stopped to look, but if you mean the dials have a sort of blue glow to them after you've locked the car etc I think that is normal, they do that for a minute or two ... perhaps (I have this vague memory from when I first got mine of it looking cool ).
- Been thanked: 109 times
You could also try offloading that 192 and buying my R3..
Do you mean blue glow to the rev counter etc?Mattblack_lude wrote: ↑Sat May 18, 2019 6:50 pmI've got a battery drain issue currently where the centre console (where the clock is) stays illuminated when the car is locked. Any one have experience with this? Really need to have trust that I can leave it for more than a couple days without having to jump start.
If so its a feature not fault...
Thanks for all the responses guys - very handy.
I've concluded that I think the battery being of such poor health could be the contributor, so I'm in the market for a new one.
I hear the Varta E23 is the battery of choice? What's the best place for best price?
Awesome, that'll help - although it says insufficient privileges once I try to access the area to get the discount. As I'm a newbie, is my post count too low?
You have to be an Owners Club member
https://www.rx8ownersclub.co.uk/members ... Select.php
This also gives you access to the 70% of the forum not open to guests, including the Technical Library and Group Buys
Thread revival - just got the car back from its MOT and noticed the same thing; centre console lit up again. It has a new battery on it (Varta E23) so I've ruled out it being the old knackered battery as a potential issues.
Really has me stumped and I dont want it to kill my nice new battery....
You never said if the dash is illuminated blue or is it all still lit up white?
