This was my first time buying a new car by myself (well I took my friend with me but still).
After checking through everything I could think of everything looked perfect. No rust on the body work. Hot started cold started fine. Pulled like no tomorrow.
I arrived home and realised the oil pressure light was on!
On the 60 mile trip or so home it definitely wasn't on. And it wasn't on when I viewed the car.
Obviously this has me in a bit of a panic. I did a quick bit of reading and I've seen there is a sensor in the oil pan that can go bad?
The cars lowered and the track I live down is a bit bumpy.. So I'm worried that a couple of bumps to the oil pan (I was driving so carefully too) may have done the sensor in?
So today I purchased a lovely rx8
- Been thanked: 93 times
Re: So today I purchased a lovely rx8
It may be the coolant level light that’s on and not the oil light? Does it look like the roman coliseum? If so it’s the coolant light. It’s a common fault. Just check your coolant level to make sure. Then either live with it, or disconnect the sensor and just check it regularly. The float can get waterlogged and sink, giving it a false reading. Going over a bumpy road can make this happen.
Kamikaze
Too many to list.
Too many to list.
If it is the oil can shaped light then it's more likely to be the low level light and not pressure as the RX8 oil pressure gauge is simple a pressure switch hence the gauge does not move with engine revs. Check your oil level and if it is at 3/4 then you don't have a level problem, it's a faulty switch sticking which is quite a common fault.
- Been thanked: 283 times
Tis definitely the oil can light. Oil was sitting at half the dipstick so I topped it up a little bit. If it is the switch sticking is a fix just a new switch? Lets just say that I bought this car knowing things could go wrong and budgeted accordingly. However my mum/her friend whose my mechanic usually, are somewhat... against the fact that I've bought this so I somewhat want to avoid "WHY DID YOU DO THAT IT WAS A STUPID IDEA!" where possible.
Really enjoyed the 60 mile drive home.. Was really enjoying the beautiful rotary noise. Getting use to a car that is actually designed for speed compared to a falling to piece hatchback is interesting.
More likely the rough roads and slightly low level just confused the sensor/computer.
Once triggered will stay on till restart.
I've had it come on under harsh breaking downhill pulled into garage and level was fine... Only happened once many months ago.
- Been thanked: 330 times
I too have the 'sticking' switch that tends to come on without fail on a hot restart
originally its there to warn the owner that the oil level is low and needs topping up
but to replace you need to have the sump off - not that big a job but I just live with mine and keep a close eye on the oil level
worth noting that its best not to fill right up to the max - you have less chance of oil carry -over into the intake if you run these things at 3/4 full
It doesn't seem to be going away. I didn't really expect the small amount of oil I put in to fill to the max. But I will keep that in mind!
Does it count as an MOT concern these days?
You need to complete your profile, including your location before we can answer that question.
ucp.php?i=164
In NI any dash warning light is an MOT fail.
In England you could possibly convince the tester that is doesn't relate to the emissions system, braking, seatbelts, airbags or lights, and therefore shouldn't be a fail - good luck with that.
Huh I thought I did complete my profile. Im currently in Scotland but should be moving back south to England soon.
a lit oil warning light is a mandatory reason to refuse to test in the uk.warpc0il wrote: ↑Sun Apr 14, 2019 11:46 amYou need to complete your profile, including your location before we can answer that question.
ucp.php?i=164
Thats what I was thinking. If it is just a sensor in the oil pan though, Ill just service the car at the same time. MOTs in December anyway so plenty of time to get it sorted.
Hi and Yorindesarin. I can't add to what has been said about your oil light, it sounds like you know what needs doing anyway.
For the sake of fixing the issue, the sensor was unplugged so it must've been loose and come undone when I went down my track. Plugged back in and all is good.
