New owner....
New owner....
Hi,
I'm 33, and a new owner of a Black R3.....from here!
It's the gareth72's car! (yes i searched a little bit before).
It's why, i'm wondering how my freshly R3 was used!
Thanks a lot.
Thanks a lot.
Re: New owner....
Hi and Dayme. I don't know who has had the car or how it has been used since Gareth sold it - and that was nearly 6 years ago it seems, but you've done your research so you knew that already.
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it although with the R3 you have a red line that rises with the coolant temperature as indicated by the lights on the dash, but I think this is still good advice) and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
- Been thanked: 7 times
Re: New owner....
Glad she’s still alive. When I sold it she was pristine with no problems.
I hope she’s held up over the last 6 years.
You’ve come to the best place for advice and thanks for the message
COMMITEE - Discounts (2004 - 2007), MODERATOR 2004-2007 for my sins 2010-2013
2004 RX-8 192 Titanium Grey Pocket Rocket
2007 Focus ST'2 276BHP
2009 RX-8 R3 Sparkling Black
2013 Audi A3 S-Line Sportback
2016 LR Discovery Sport SE TECH Corris Grey
2019 LR Discovery Sport HSE Landmark Edition Narvik Black
2022 Audi Q4 40 e-tron S-Line Aurora Violet
New owner....
Re: New owner....
Thanks a lot for your welcome!
Thanks again to you, Shagrington, for the advices. When i bought it, i knew a few things, like that when she's cold, i reach 3k (you said 4k) and after i switched off (when the engine is stopping, i fully support the accelerator pedal).
Yeah, the R3 is really good to know if i can use the car totally or not
She's not pristine anymore, she had a lot adventures with many guys
But, my presence here should confirm that I will take care of it..
New owner....
Have put you and your car on the R3 Register
(NOTE you have to be a Paid Up Member to see the R3 Register)
Re: New owner....
Attached some photos of the old gal
- These users thanked the author gareth72 for the post:
- GreySilver Beast (Thu Apr 11, 2019 6:31 pm)
Re: New owner....
Pics when it went up for sale 2013
- GreySilver Beast (Thu Apr 11, 2019 7:13 pm)
Re: New owner....
Thank you Gareth.
Do you know if you've got any problem with the boot and the passenger door?
I can't open the boot with the key. And the door doesn't lock (i have to lock it inside).
Re: New owner....
All worked 6 years ago , Hmmm
1. Open the glovebox
2. Locate the button that enables/disables the trunk solenoid
3. Push it.
4. Test the remote.
If it works - awesome
If it doesn't work - maybe bad solenoid or sender on remote
Door - try a reset by disconnecting battery.
That's all I have - if doesn't work I'm not sure
3. Push it.
4. Test the remote.
Re: New owner....
For the button in the glovebox, i've tried yet
I called my garage, and he's going to order the parts. He thinks it's the "motor" in the passenger door who's dead...
So strange.
Anyway, how can i put some picture in this topic?
So strange.
Re: New owner....
Need to be a member if i want to put some pictures here (or in the "come on the R3's topic) easily (ifnot i have to upload it before so it'll wait a little bit).
No news about the door and trunk (waiting my garage).
Some news about the car....
When i bought it, my garage did change some things:
- Ignition: HP Ignition (coil) + Magnecor 8.5mm + RE-8CL (+RE-9BT)
- Racing Beat catalytic 200 cell
- News brakes discs (& pads)
- Oil and filter of course
- Treatment for rust
She have a washable air filter (K&N).
Body and rims are in poor condition
Moreover, My secret has come to an end: Yes She's in France now. I imported it from Doncaster.
But....one question....how did you know that i was french warpcoil????
Re: New owner....
We don't just let anyone on this forum, it was all part of the background checks
Spoiler:
Re: New owner....
Re: New owner....
The K&N filter I did fit one at hope its not the same one. If it is it might need a service or replacing.
