Idle problems
Idle problems
Hello,
I'm a new rx8 owner and really need abit of help.
So i just bought a 2005 231 with 58000 miles that has just had a home rebuild and I'm having some problems with it idling. The problem is is turns on and warms up fine until the rev get to about 1100 rpm then it starts surge from 800 to 1300 a few times before it stalls but theres no problems when driving. It also has two error codes p0113 and p0103. It had new plugs and cat before the rebuild so I'm pretty sure there fine. Since buying it I put new coils, battery and maf on with know joy. I can't find any obvious vacuum leaks and the filter is clean but if I unplug the maf it runs fine just idles at about 1100 rpm so I'm pretty sure it's a air problem. Any help or advice would be greatly appreciated.
Re: Idle problems
P0103 is the MAF sensor circuit and P0113 is the Intake Air Temp Sensor - which are both parts of the same module.
Either the module has been damaged, is saturated in oil or there's a problem with the wiring connector/loom.
Where did you buy the ignitions coils from?
There are lots of nasty fakes/clones out there that will kill your engine, even if their not responsible for your current problem.
Re: Idle problems
Further reading
viewtopic.php?f=25&t=36391
viewtopic.php?f=25&t=36282
and
The meet & greet guys will be along shortly
and
Re: Idle problems
Thanks for the reply. Maybe the new maf I bought is faulty aswell as the old one? And the coils are haas ones from euro parts so not the best but adequate?
- Been thanked: 109 times
Re: Idle problems
No,the ECP coils will not be adequate..think about replacing with genuine Mazda C coils,or upgrades such as D585 coils.
Was the new MAF sensor a genuine Mazda part or a pattern
Re: Idle problems
No it was off Ebay but seemed like a half decent one as it came with a year warranty.
Re: Idle problems
The warranty is worthless. It's just to give the impression of quality.
You'd be much better fitting a known good used Mazda part, as they very rarely fail, unless mis-handled.
- Has thanked: 71 times
- Been thanked: 90 times
Re: Idle problems
Could be a fueling issue, has similar idle issues couple of years back.
Try bypassing the fuel pump resistor so the pump runs normally when idling.
Re: Idle problems
Hi and Zachstrange. My first stop for parts, especially the critical things like coils etc, has always been Mazda Rotary Parts or one of the rotary specialists (there is a list with contact details in the FAQ section).
- Been thanked: 330 times
Re: Idle problems
if your scan tool can do monitoring take a look at what the lambda sensor is reading and what the LTFT ( long term fuel trim) figures are
as its possible you have 1 injector not firing so its stalling out once the cold start fuelling is used up
Idle problems
Re: Idle problems
Hey guys, thanks for you replies and help. I thought I'd give you a update. I changed the front 02 sensor which has seemed to get rid of the codes and made he car idle with out stalling but still not perfect. It will still stall on take off and hunt abit but not as bad. I noticed the front engine mount is shot so I'm just waiting on a replacement set think I will check the plugs and leads next as it's slow to start and every thing I touch seems to have been butchered so I dont believe they are as new as the previous owner has said...
Re: Idle problems
If you know where it was rebuilt did they also fit the engine? Could be worth a trip to your nearest specialist to save a lot of time and expense on parts you may not require plus guidance what good parts and which are bad.
- Has thanked: 101 times
- Been thanked: 83 times
Re: Idle problems
Suicidal ignition coils !!!!!!!!!!!!!.. they WILL kill your engine .. get genuine Mazda 'C' revision or uprated ones.. circa £300.
If you value the car, for gods sake don't buy off eBay they may well say genuine, but trust me they are far from it
Re: Idle problems
Mazda had to specify different front O2 sensors for the 231 and 192.
If you've replaced with anything other than the correct Mazda unit then it's the wrong spec.
Lot's of vendors list the wrong sensor for our car and it will put your engine at risk.
A good used original sensor would be a much better bet than a new non-original item.
If it says "oem" in the listing then that's usually the clue that it's wrong.
