Dropped myself in at the PZ end
- Has thanked: 121 times
- Been thanked: 202 times
Hi everyone!
Firstly, I'd like to say big thanks to everyone here who's already helped me when researching my purchase in the first place - even without knowing it, this place is such an amazing resource for anyone looking into the car, and as soon as I'd put my money down I signed up for club membership.
I'm delighted to say I picked up my first RX8 last night - and I was lucky enough to find a PZ in my price range, so couldn't turn it down.
I'm planning to take it as far back to 'factory fresh' as I can (minus a couple of tweaks like a SOHN adapter) - PZ's apparently have the best setup so I can't do much to beat that! It's done 76600 miles (and has minimal service history ) but so far it's just amazed me at every turn and I can't wait to get started working on it.
Couple of minor issues mechanically, a weird rattle in third gear (don't know if I can do anything about that!) and some odd idle behaviour, but it cold and hot starts great still. I think the front suspension has been lowered, have yet to confirm that but it seems to have a more wedge shaped stance than other pictures I've seen.
Bodywork wise, there's rust in the rear brakelight area, which I'm planning to get a new bootlid to replace, and also in the rear arches. I am finding out tomorrow just how far that goes, but I am braced for the worst... (Will grab some photos tomorrow, been chucking it down all day!)
...also the front woofers have been completely annihilated. I can only presume Viking death metal was a favourite of the previous owner!
I'm looking forward to taking part in the club, and more so to restoring and enjoying my RX8!
Sent from my SM-G901F using Tapatalk
- leeroy69 (Tue Mar 12, 2019 7:38 pm)
Re: Dropped myself in at the PZ end
Hi, and welcome to the Club. Your about to be bombarded with helpful advice, so I'll just make one comment. The correct PZ suspension is a full set of non-adjustable Bilsteins. The springs are unique, and I don't believe lowering springs are available for the model. So you either have a stock PZ, or it has had some alternative suspension fitted (which would be a shame), or your front springs have broken (unlikely, but not impossible).
The other possibility is that the front suspension is proper PZ, but the rears are stock s1 suspension. This is more likely than you'd imagine, because the rear springs are prone to break, and couldn't be replaced (until the Club arranged a special order of replacement units last year). So the previous owner may well have fitted the more common s1 units to the rear.
Hi & to the RX-8OC
Please put your Location here in the Profile Section
Please check out the EVENTS SECTION's - Events Team
- Been thanked: 2086 times
This has happened at least once before.The other possibility is that the front suspension is proper PZ, but the rears are stock s1 suspension. This is more likely than you'd imagine, because the rear springs are prone to break, and couldn't be replaced (until the Club arranged a special order of replacement units last year). So the previous owner may well have fitted the more common s1 units to the rear.
How could I not have thought of that! I'm getting it up on some ramps tomorrow so I'll be able to take a good proper look both front and rear.PeteH wrote: ↑Tue Mar 12, 2019 8:22 pmHi, and welcome to the Club. Your about to be bombarded with helpful advice, so I'll just make one comment. The correct PZ suspension is a full set of non-adjustable Bilsteins. The springs are unique, and I don't believe lowering springs are available for the model. So you either have a stock PZ, or it has had some alternative suspension fitted (which would be a shame), or your front springs have broken (unlikely, but not impossible).
I did come across the thread mentioning replacement PZ suspension sets before I joined - I just presumed they are sold out but I would definitely be interested if there are any still available.
Hello Honkytonk (why did I hear Dick Emery ... and how am I so old that I remember Dick Emery? ).
5. (It sounds like you don't need this, but the membership sec is away so if you have joined he hasn't been able to upgrade your status yet and you are still showing as a forum guest, so I'll leave it in just in case). Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections, local meets (or if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
Glad I not the only one BrianShagrington wrote: ↑Tue Mar 12, 2019 11:28 pmHello Honkytonk (why did I hear Dick Emery ... and how am I so old that I remember Dick Emery? ).
Ooh I say...Shagrington wrote:Hello Honkytonk (why did I hear Dick Emery ... and how am I so old that I remember Dick Emery? ).
Thanks for your warm welcomes everyone. I'm getting it up on some ramps tonight to have a good assess of everything, but will start a thread in the correct sub forum for that (with pictures!)
I'm also glad to hear it's not only me that has trouble pulling away... Still getting used to revving it from a stop. My place is right next to a massive hill with traffic lights on so I'm going to get plenty of practise with hill starts!
- Been thanked: 451 times
Hi, just adding another welcome to the Club and to say I'll be looking out for what you find once you've had a good look up on the ramps.
You shouldn't have any difficulty with obtaining some replacement speakers from a breaker on here - maybe try bigpete first.
Some PZ's have different door speakers to normal Series 1, for reasons that I've not been able to identify or find any documentation.
This may of may not have implications too for the front woofers, but you might like to pull them first and match, rather than just assume that any replacements will be the same.
Aftermarket replacements would be a problem as the Bose output is balanced for 2 Ohm speakers and (virtually) all aftermarket are either 4 or 8 Ohm. Actually, it might be worth checking that the units haven't previously been replaced with unsuitable aftermarket.
How weird, speakers specific to the PZ , I'd never have considered that. Beats me why ProDrive would go to the trouble to changing the door speakers!
Lighter weight maybe
- Has thanked: 7 times
- Been thanked: 19 times
The upgraded door speakers have a massively beneficial impact on the (already amazing) PZ handling
I would check - I had a dodgy speaker, ordered a standard S1 speaker from eBay and it didn't fit!
It doesn't make any sense to me either but it was identified on a PZ a few years ago and has been confirmed by many owners since.
We know that the Bose systems were loaded with base equalizer settings for "leather" vs cloth interiors, so maybe it relates to the PZ seats.
However, it does seem overkill and there's no mention in the PZ Launch/Sales materials - which go into great detail on the other changes.
The cars that Mazda UK gave Prodrive were a special factory order, not just dealer stock, so I can only assume that the change happened on the production line and maybe the PZs got the same speakers as a different (no-UK) market.
Just to confuse things further, at least one PZ owner has advised that his door speakers were the same as his other non-PZ S1. However, both had a chequered history so either/both may have been changed before.
It's unlikely that all the (to be) PZ cars were produced at the same time, so maybe one or more batches got different speakers.
Edit: +1 on this list of confirmations
Wow, okay, thanks all. Will definitely bear this in mind. I need to swap the passenger door card out anyway as someone took a big chunk out of it (looks like they were transporting 2x4 or something ) so when I whip it off I should get a good idea of what the drivers are like.
Conveniently I work for an audio company so there's probably something I can do, whether it's stock or not.
To save extra searching about for people interested in my suspension, here's a side profile of the car. I think you can see what I mean by a low front end. Suspension doesn't seem broken (although maybe that's just me coming from a Vauxhall Vectra B...) which makes me think perhaps it's coilovers and I might be able to raise it back up. Will post with my findings when I'm done tonight!
//uploads.tapatalk-cdn.com/201903 ... c842f4.jpg
- Has thanked: 12 times
- Been thanked: 104 times
Welcome to the club!
The front 100% shouldn’t be like that. Looks rather slammed there and dare I say kinda a bit dangerous to drive fast round corners.
Edit to add OP picture.
Stock PZ units can't do that unless you have an elephant in your engine bay. That looks like it's running on the bump stops. Defo something none-standard going on there.
Lowered...?
Wow, serious risk of sump damage with the front that low!
Right, So...
A quick rootle under and inside the car tonight has taught me that my rust problems are minimal to none apart from surface bubbling (Yay!), and I have the correct rear suspension setup (Also yay!).
Front suspension, well this is where Dr Frankenstein gets involved (no, not you FrankenRex).
It appears someone has taken the original shocks and put these lowering springs (or similar) on them. I can understand being unable to source the correct ones, but putting lowering springs on? 'sigh'. This is, however, not as bad as I was fearing.
They've also torn the front gaiter
https://shop.rx8oc.co.uk/RX-8_front_sus ... 72001.aspx (currently out-of-stock)
Just on the one side luckily. I think I'm best hoiking both front suspension assemblies out and getting them redone. They haven't touched the rears by the looks of it, thankfully.warpc0il wrote:They've also torn the front gaiter
It drives fine (though obviously I'm taking it careful as with every 'new' car, but more so with the front that low...) and passed an MOT spotlessly in January - I believe the previous owner when he said he hadn't fiddled with it, he only had it for 7 months.
Luckily I have my Vectra for dailying and gadding about town in (see attached!), wonderful boat that it is.
I will starting up a thread in the ongoing builds section I think, rather than going off topic here. Thanks for all your advice and help everyone!
Counting the coils, I think they have put the rear Direnzas on the front suspension.
Also, the PZ units require flat ground spring ends. But the Direnzas have the unground "pig tail" ends. This could cause either the springs or the spring seats to fail.
I'd get them changed ASAP if I were you.....
Yep, getting them sorted is my first job, and luckily nothing else to worry majorly about. Am heading over to the other thread to see if I can pick up a set of PZ suspension. Got the airbag recall to do as well so I may ask the Mazda dealership if they could do both at the same time.PeteH wrote:Counting the coils, I think they have put the rear Direnzas on the front suspension.
On a less broken/mangled note, I only just realised you could change your dials from white to red last night on my way back from where I keep my ramps.
