Picked up a Grey 192 (2004) last weekend, loving it so far.
Big thanks to all the FAQ's and guides on here as they definitely helped me get informed enough to make my choice!
Picked mine up last weekend!
- Has thanked: 508 times
- Been thanked: 453 times
Re: Picked mine up last weekend!
to the forum Rayan. Same year as my RX-8, a great vintage in the best colour
Post up some photos when you get a chance
- Rayan (Fri Feb 08, 2019 3:59 pm)
Need to take some as soon as I've given it a proper clean and get some nicer weather!
Yep, mine's in desperate need of a good clean too
BTW, we have a rule never to quote a post if it's immediately above, so I've taken the liberty of editing your post above
- Rayan (Fri Feb 08, 2019 8:36 pm)
- Has thanked: 101 times
- Been thanked: 83 times
to the forum m8.. make sure you join fully as a Club member as you are restricted to only certain topics as a guest.. and you will certainly need to get on the members section and have access to the techy stuff
Thanks for the heads up Casey!
It's definitely on my to-do list as I've already found a few sections I want to take a look through but wasn't able to.
Hi and Rayan. Have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
