spoiler/s
NedKelly
Forum Guest
Forum Guest
spoiler/s
Post by NedKelly » Mon May 07, 2018 1:35 am
I've recently bought a 55 plate 231.
Mods (not done by me) as per:-
Sohn adapter with Mocal reservoir tank and Aeroquip piping using synthetic 2 stroke oil
D585 coils and Magnecor leads
Toyosports high flow stainless steel exhaust manifold
Toyosports cat back exhaust and Toyosports high flow cat.
Lightweight underdrive alloy pulleys
Recent new lambda sensors. Eibach lowering Springs and Koni adjustable rear shocks
Modified rear antiroll bar and new drop links
Wheels powder coated white with recent new General Altimax tyres at 48000 miles
20mm rear wheel spacers. Paint velocity red 27a 87.
I'd like to add a "Hooped Spoiler" along the lines of a Prodrive PZ type (or similar), sorry to you guys that like the JDM types.
I've seen a couple threads on here, some detailing cut and moulding, but would prefer a straight bolt on,either retaining the "Lip Spoiler" and adding the extra spoiler or removing the lip spoiler and utilising the existing mount points plus filling of the extra hole. Advice, how to's and hints and tips be real appreciated.
I'm in Swansea area.
Those in the know know where that is. those that don't it's off to your left (if you looking upto Scotland)
Has thanked: 619 times
Been thanked: 706 times
Re: spoiler/s
Post by Shagrington » Mon May 07, 2018 1:44 am
Hi and :welcome: NedKelly. :D Personally I'd remove the lip spoiler if I were you if you are fitting another spoiler. Some don't and do make it work to be fair, some don't and it looks a bit too cluttered for my liking.
It just so happens one of our ever helpful Spin Doctors did a guide on removing the lip spoiler and fitting a hoop spoiler (this is not the PZ or 40th Anniversary style spoiler, the hoop spoiler is from the Mazda aero body kit). Here is the guide https://www.rx8ownersclub.co.uk/forum/v ... 30&t=37203
If you want to fit a PZ spoiler there is another guide by our shopkeeper here https://www.rx8ownersclub.co.uk/forum/v ... 30&t=39925
Check the social meets section for the next South Wales meet.
NedKelly
Forum Guest
Forum Guest
Re: spoiler/s
Post by NedKelly » Mon May 07, 2018 9:13 am
many thanks for the links Shag.
Also does anyone have one for sale? :D
Dazza44
Has thanked: 172 times
Been thanked: 94 times
Re: spoiler/s
Post by Dazza44 » Mon May 07, 2018 9:24 am
Hi, you know you don't have to limit yourself to a spoiler specifically for the 8, several spoilers will fit,less course you just after the loop spoiler
NedKelly
Forum Guest
Forum Guest
Re: spoiler/s
Post by NedKelly » Mon May 07, 2018 9:25 am
yes Dazza. I prefer the hoop styled ones tbh
PaulAV
Has thanked: 26 times
Been thanked: 83 times
Re: spoiler/s
Post by PaulAV » Mon May 07, 2018 11:47 am
A fairly popular spoiler to fit is an astra irmscher spoiler i believe. I found when fitting my pz spoiler that a 22mm conduit hole cutter made perfect holes in the underside of the boot to fit washers and nuts, best advice I was given for marking holes for the studs was to put a blob of toothpaste on them, this leaves a witness on the boot, for the position of the holes that need drilling for the pz spoiler. Drill all the way through with a pilot drill, including the reinforcing panel inside the boot lid.
NedKelly (Mon May 07, 2018 11:52 am)
Dazza44
Re: spoiler/s
Post by Dazza44 » Mon May 07, 2018 1:18 pm
I have the Astra spoiler on mine,also left the rear lip on,looks good me thinks
Has thanked: 6374 times
Been thanked: 1597 times
spoiler/s
Post by GreySilver Beast » Mon May 07, 2018 1:35 pm
Hi & :welcome: to the RX-8OC :P
Please check out the EVENTS SECTION's :thumleft: - Events Team
NedKelly (Tue May 08, 2018 4:59 pm)
RX-8OC Club Calendar - GBCC
GT86 T/Days = 49.5 + 27 session's
Total = 60.5 + 34 session's
Cars Driven = 181
http://npt-communications.webs.com < Click > ****GSB III****
Paulie
Has thanked: 10 times
Re: spoiler/s
Post by Paulie » Thu May 10, 2018 8:05 pm
Hey welcome Ned!!
Return to “Hello.. I'm new here..”
