Hi and
*thomas*.
Congratulations on finally being able to get your car.
Have a good read through whatever in the FAQ section you didn't already read
and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
2. Never
turn off the engine before it has reached at least somewhere towards normal operating temperature (should only take a minute or two, but best to go for a short drive if just swapping cars round on the drive etc). Switching off cold risks flooding, which is a real
with a rotary engine. Mazda recommend rev to 4k and hold it for 8-10 seconds switching off while still revving if you have no option but to switch off cold
(it is not necessary to do this in any other circumstance).
3. Check the oil level regularly (use the dipstick - the oil gauge tells you nothing other than that you have or don't have pressure) and top up if necessary with semi synthetic 5w30
(most people and specialists are advising to use 10w40 now though) ... small amounts at a time, no more than ½ a litre then check the level again before adding more as you don't want to overfill it.
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it
) and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
5. We do have an 'overseas' club membership if you think it might be of benefit to you. My usual number 5 tip says to join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (when we start them again, they're currently all postponed for obvious reasons - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
Obviously the local meets will not be local for you and I suspect other events we attend as a club (when they start again) may not be easy for you to get to either. There is the sexy keyring.
