Engine rebuilds near Surrey
onecruelbagel
Post by onecruelbagel » Tue Mar 12, 2019 6:08 pm
Hi all! I've had my Winning Blue 2004 RX-8 for a few months now, and was aware that the compression was a bit low. Unfortunately I managed to flood it and I'm pretty sure whilst trying to solve that, I've pushed it over the edge and it now needs a rebuild. I'm OK with that - the car was quite cheap, so I'm happy to put a bit more money into it - the problem is finding somewhere reasonably local to get it done!
I'm in Cobham (where the A3 and M25 meet - and also where the SW London group meet!) and after looking through the forums it seems there isn't anyone especially close who does the rebuilds.
AMT Ford-Mazda has stopped doing them, ironically due to too much competition, all of which has now gone out of business.
Rotary Revs and Ryan Rotary Performance are both quite a way away, and since the car won't start I'll need to get it trailered there, so that'll probably be expensive.
Warren Court and LC Rotaries are significantly closer in Kent, but still a bit further than I'd like.
Can anyone recommend a rotary specialist, ideally in Surrey or near by? If not, I'll probably go with one of the Kent ones! Thanks :)
Has thanked: 37 times
Been thanked: 147 times
Re: Engine rebuilds near Surrey
Post by mi60o0 » Tue Mar 12, 2019 6:18 pm
LC Rotary have recovery so I belive they will pick up and deliver the car
These users thanked the author mi60o0 for the post:
onecruelbagel (Fri Mar 15, 2019 10:01 am)
BatRex 192 stock
Has thanked: 258 times
Been thanked: 977 times
Post by warpc0il » Tue Mar 12, 2019 6:18 pm
I'd be extremely surprised if clearing a flood has pushed the engine to needing a rebuild, not that it's impossible, just very unlikely.
What specific symptoms are you getting?
Does it start fine when cold but have difficulty when hot?
viewtopic.php?f=25&t=36004
Does it make lots of noise and smoke?
Does it not start at all?
How old are the ignition components (coils, ht leads and plugs)? and/or have any been replaced with parts from ebay or other non-dealer source?
viewtopic.php?f=25&t=36282
Has the oil been over-filled?
viewtopic.php?f=25&t=36391
onecruelbagel
Post by onecruelbagel » Tue Mar 12, 2019 7:28 pm
mi60o0 - That's good - I'm a little concerned about the cost, but it's about 50 miles, so hopefully it won't be too bad! Thanks - I suspect this is what I'll be going for.
warpc0il - I had a compression test done before it failed, and it was getting close to the line - I can't remember the exact numbers but it wasn't good! After it was flooded, I think I spent too much time trying to get it to start, so I suspect I wrecked the seals from turning it over repeatedly on the starter, without it lubricating properly. I then had Luke Murdoch (who I believe is known on these forums!) out again to take a look. He didn't do a compression test, but said it was probably bad compression. It doesn't start at all from cold (if it started cold, I'd be able to drive it over there!). I get starter motor noise and it sounds like it's trying to start, but just won't. From what Luke said, I think even if I did manage to get it working it would probably need the rebuild soon anyway as it's on its way out.
Oh, and if I've said anything wrong in there, I'm probably misquoting Luke because it was a while ago - any mistakes will be mine and not his. :)
I think LC Rotary is probably the way to go - they seem to be well regarded on here. I'll get in contact with them tomorrow and see what I can arrange!
Thanks again guys! Looking forward to getting it back on the road. I'm back in the MX-5 at the moment, and I'm missing the power...
Post by mi60o0 » Tue Mar 12, 2019 7:52 pm
If they carry rebuild I will ask for free pickup at least wow you spend thousands.. Don't be shy and ask :)
BatRex 192 stock
Has thanked: 6800 times
Been thanked: 1700 times
Post by GreySilver Beast » Tue Mar 12, 2019 8:57 pm
Hi & :welcome: to the RX-8OC :thumleft:
Please put your Location here in the Profile Section =D>
RX-8OC Club Calendar - Gang Bang Car Club - My Website - GSB III
GT86 T/Days = 51.5 + 27 session's
Total = 62.5 + 34 session's
Cars Driven = 182
Has thanked: 644 times
Been thanked: 722 times
Post by Shagrington » Tue Mar 12, 2019 11:18 pm
Hi and :welcome: onecruelbagel. :) Hopefully you can get it sorted with LC - and yes if you had Luke look at it already I'm sure he advised you properly. If you can't get in there, as well as Warren Court you will find Essex Rotary are also within striking distance, just at the wrong end of the Dartford Tunnel.
As you are in Cobham feel free to pop along to the Fairmile whenever we are having a meet there. :thumright:
SeriousSam
Been thanked: 227 times
Post by SeriousSam » Wed Mar 13, 2019 10:52 am
If you're still after other recommendations, RX Motors in Salisbury and Hayward Rotary in Newbury are both worth a look-in, and are closer to you than the Northerners. Hayward's did my rebuild, and I am very happy with it, although they have just moved workshop and are still getting fully set up. RX Motors fixed up a monster oil leak i had after Rockingham for sensible money, and I'd be happy to point you their way as well.
And if you need to get the car trailered to the rebuilder, get some quotes from Shiply - usually they'll move it for a pretty sensible price.
These users thanked the author SeriousSam for the post:
onecruelbagel (Fri Mar 15, 2019 10:02 am)
Has thanked: 33 times
Been thanked: 184 times
Post by V8 Power » Wed Mar 13, 2019 10:58 am
I have never heard of RX Motors before. I'm down in Salisbury in a couple of weeks so may pop in and see what they are about.
Bumper cold air feed
Aurora blue R3
Post by mi60o0 » Wed Mar 13, 2019 11:06 am
I hear from few members only good thinks about them. Worth a try I guess
BatRex 192 stock
SeriousSam
Post by SeriousSam » Wed Mar 13, 2019 11:07 am
You might enjoy your trip - Tim's daily is a 600BHP FC drag car with a purple flake paint job. And he's another one of those specialists who's really calm and softly spoken but drives mental cars. He's also got one of the only REPUs in the country, still to be restored, but epic nonetheless. Good guys :)
casey
Has thanked: 634 times
Been thanked: 882 times
Post by casey » Wed Mar 13, 2019 10:39 pm
Tim White at RX Motors has helped me out with a few minor items for my RX-7. Always fair and very helpful. Tim is VERY experienced with all Mazda rotary models. He has also attended several RX-8 OC events in the south, such as Simply Japanese at Beaulieu. From personal experience I would highly recommend RX Motors, alongside Hayward, LC Rotary and Essex Rotary in your area..
Club Secretary
Seibon Carbon Fibre Bonnet
Been thanked: 17 times
Post by Honkytonk » Fri Mar 15, 2019 7:51 am
casey wrote:Tim White at RX Motors has helped me out with a few minor items for my RX-7. Always fair and very helpful. Tim is VERY experienced with all Mazda rotary models. He has also attended several RX-8 OC events in the south, such as Simply Japanese at Beaulieu. From personal experience I would highly recommend RX Motors, alongside Hayward, LC Rotary and Essex Rotary in your area..
I live in Salisbury and this thread has answered a question about whether RX are trusted by the club or not! This makes any future issues I have wayyy easier to deal with...
And onecruelbagel, if you end up at a loose end in Salisbury, drop me a PM and you're welcome to a lift or a brew! I know all the places where the Novichok wasn't ;)
Sent from my SM-G901F using Tapatalk
These users thanked the author Honkytonk for the post (total 2):
SeriousSam (Fri Mar 15, 2019 9:33 am) • onecruelbagel (Fri Mar 15, 2019 10:02 am)
Have a gander at my slightly rusty pride and joy
The P-Shed Project Thread
One day, it'll be back in good condition. One day...
Next Jobs!
1. Suspension Return to Stock
2. Ignition Overhaul - plugs, leads, coils, battery
onecruelbagel
Post by onecruelbagel » Fri Mar 15, 2019 10:05 am
Thanks, everyone! I'm booked in with LC Rotary now - he's picking the car up early Monday morning, so hopefully I'll have it back on the road soon!
Shagrington: I've been to one meetup there, unfortunately they often clash with rehearsals for me so I won't be able to make another for a couple of months. I'll be back though - at least once I can turn up in an RX-8 instead of an MX-5 :-D
Post by Shagrington » Fri Mar 15, 2019 4:23 pm
I did think you may have been to one of the meets, but I'm old and easily confused so I lose track of who is who etc these days. ;)
Good luck with LC - you're in good hands anyway.
Ninja_Freak
Has thanked: 35 times
Been thanked: 32 times
Post by Ninja_Freak » Sat Mar 16, 2019 11:49 am
Can anyone pm me a direct contact number for Tim? I need some work done but don't just want to turn up Monday morning..
56 Plate PZ in Galaxy Grey!!
casey
Post by casey » Sat Mar 16, 2019 12:57 pm
Club Secretary
Post by warpc0il » Sat Mar 16, 2019 12:57 pm
casey
Post by casey » Sat Mar 16, 2019 1:00 pm
That's the one in Doncaster Dave ;)
Club Secretary
Post by warpc0il » Sat Mar 16, 2019 1:05 pm
Too slow & wrong then #-o
Try again http://www.rxmotors.co.uk/Contact/
Ninja_Freak
Post by Ninja_Freak » Sat Mar 16, 2019 1:48 pm
Thanks folks.
