Sohn adaptor installation support kit
Has thanked: 345 times
Been thanked: 1305 times
Re: Sohn adaptor installation support kit
Post by warpc0il » Sat Jan 19, 2019 8:55 pm
If you're planning to cut the hole then measure the old tank carefully and make the hole slightly smaller than you'd think.
A bit too small and it might need a good shove but too big and it'll leak, or fall out
Bigblueknight3k
Has thanked: 99 times
Been thanked: 49 times
Post by Bigblueknight3k » Sat Jan 19, 2019 8:56 pm
Ok cool i will want a tight seal for sure thanks
Has thanked: 409 times
Been thanked: 525 times
Post by goodeggbob » Sat Jan 19, 2019 9:01 pm
a tight seal is essential, just ask Nigel.
Bigblueknight3k (Sat Jan 19, 2019 9:06 pm)
Bigblueknight3k
Post by Bigblueknight3k » Sun Jan 20, 2019 12:35 pm
All done tight seal holds water just drilled hole in bottom for sensor nice and tight and had two in front for both pumps
Bigblueknight3k
Post by Bigblueknight3k » Sun Jan 20, 2019 5:43 pm
Thats the tanks sorted but the pipes are tight for the adapter and pump are they ok and not going to break or split for oil injectors ? Image
Post by goodeggbob » Sun Jan 20, 2019 8:18 pm
hi there,i can only tell you what i did on my car which has been very successful. some people drain the coolant to be able to remove hose that needs to be crossed. i found it easier to remove oil lines from omp and reconnect on the other side of said hose. cleanliness is essential at this stage as is taking care not to over stress oil lines. what i then did was premix a couple of tanks of fuel as well as a backup. if you put just enough 2t in the tank to come just up the delivery pipe,and run car for a short time only you will see a marked drop in level very quickly assuring you that your instalation is running properly ,also check for leaks. when happy with result fill up 2t tank,and what i did was mark some graduation marks on clear tank to be able to monitor consumption.
Bigblueknight3k (Sun Jan 20, 2019 9:19 pm)
Bigblueknight3k
Post by Bigblueknight3k » Sun Jan 20, 2019 9:13 pm
Its in place but them pipes are so tight its mad are upgraded pipes available ? For them ones as i dont fancy them blocking or breaking
Bigblueknight3k
Post by Bigblueknight3k » Sun Jan 20, 2019 9:14 pm
Yes and thanks i will do that but it is defo a better idea with new oil not old engine oil
Post by goodeggbob » Sun Jan 20, 2019 9:34 pm
not sure what you mean by old engine oil. as for the oil feed lines maybe do it when engine is just cool enough for you to work on it as they should be at their most flexible then.
Bigblueknight3k
Post by Bigblueknight3k » Sun Jan 20, 2019 9:36 pm
As sump from the engine and not fresh clean oil lol
Bigblueknight3k
Post by Bigblueknight3k » Sun Jan 20, 2019 9:38 pm
The metering pump oil lines as they are a hard plastic/ nylon short and hard/ brittle
Bigblueknight3k
Post by Bigblueknight3k » Sun Jan 20, 2019 9:39 pm
Just was asking is there a newer version of them
Post by goodeggbob » Sun Jan 20, 2019 10:13 pm
hi mate ,i dont know the answer to that, but there are others on here who probably do, warpcoil or big pete amongst others would be more help.
Bigblueknight3k (Sun Jan 20, 2019 10:14 pm)
Bigblueknight3k
Post by Bigblueknight3k » Sun Jan 20, 2019 10:14 pm
Ok thanks mate
RobinPZ72
Has thanked: 67 times
Been thanked: 32 times
Post by RobinPZ72 » Wed Jan 23, 2019 8:33 am
I know this is daft and sorry, but please make sure your 2-stroke choice has a good cold weather range as some of the popular ones are not that great in the cold.They thicken a fair bit and might not flow that well.
Bigblueknight3k
Post by Bigblueknight3k » Wed Jan 23, 2019 8:52 am
Am using protek R
