OBD-2 WIFI Adapter
matt_banks
OBD-2 WIFI Adapter
Post by matt_banks » Mon Jul 16, 2012 2:00 pm
Hi all,
I bought one of [urlw=http://www.ebay.co.uk/itm/Wifi-device-O ... 4ab7c88915]THESE[/urlw] but I'm having trouble getting it to work with my iphone. I've tried Rev and Dashcommand but can't get it to connect properly.
Anyone have one that they've set up OK? It shows a communication but doesn't connect for long...
I have plans to properly integrate it if I can get a stable connection set up.
192 Winning Blue 07.10.10 - 06.03.13
231 Velocity Red 11.09.13 -
Been thanked: 50 times
Re: OBD-2 WIFI Adapter
Post by RX8R3Rod » Mon Jul 16, 2012 4:21 pm
Hi Matt, I have something that looks the same (PLX KIWI wifi) and it works perfectly with Rev on the iPhone ... But I'm not sure if it is exactly the same, though it certainly looks it to me from the picture.
matt_banks
Post by matt_banks » Mon Jul 16, 2012 5:45 pm
RX8R3Rod ye I thought it was the same thing but just cheaper direct from China...I may be wrong though...would like to see how someone elses is configured to see if the unit is faulty or I'm just stupid lol
Post by RX8R3Rod » Mon Jul 16, 2012 9:37 pm
I'll check and see if I still have the instructions, as I just set it up exactly as they suggested and off it went
matt_banks
Post by matt_banks » Tue Jul 17, 2012 1:26 pm
cool thanks
Post by RX8R3Rod » Tue Jul 17, 2012 11:10 pm
Haven't forgotten .... Still looking for the box and instructions #-o
Post by RX8R3Rod » Wed Jul 18, 2012 9:35 pm
Well, couldn't find the box but the instructions (and they're blissfully short and accurate!) can be found here http://www.plxdevices.com/support/manuals/KiwiWifi.pdf
Let us all know how you get on.
matt_banks
Post by matt_banks » Thu Jul 19, 2012 1:16 pm
Hey thanks for finding those out for me... there is still a connection issue. I can get the green tick to appear after about 1/2 hour of it trying, then when I click on gauges or codes it loses connection again!
so I am assuming it's one of three things.
1. It's because my iphone is jailbroken.
2. there is a break/loose connection in the wifi device.
3. theres a loose connection on my OBD port
I will have a look at the wifi device on sat but as all lights are flashing and I can connect to my phone I don't know if it's broken or just cheap crap lol
Ross15
Colour: Stormy Blue
Post by Ross15 » Fri Sep 14, 2012 9:45 am
Hi mate, I have one of these, it took a bit of time to get it up and working. It was to do with what ports you use. Need to match up etc etc. I will have a look this weekend in more detail. Unfortunately as I had my phone stole I cannot tell you off the top of my head.
matt_banks
Post by matt_banks » Fri Sep 14, 2012 1:12 pm
Thanks Ross I never managed to figure it out......
Ross15
Colour: Stormy Blue
Post by Ross15 » Thu Sep 20, 2012 12:15 pm
Iv not forgotten, just found the bit of paper I had written down. It was more trial and error matching up the IP addresses (not ports as mentioned before). I ended up using 192.168.0.11 or 12
255.255.255.0
and then 192.168.0.10 Port 35000
Make sure you pick the right software, that is on the dev on your phone its the Kiwi.
Il hopefully get my new phone tomorrow which Il need to set up again, when I do il write down what I done a bit more effectively!
Tmunro87
Post by Tmunro87 » Sat Nov 10, 2012 5:50 pm
You may of already seen this but in the description i found the following
Q:My Apple device finds and connects to this product, but nothing is working?
A:After you connect with WiFi, set a static IP on your Apple device with: IP 192.168.0.11 or 192.168.0.10 and subnet mask: 255.255.255.0.
2004 Titanium Grey 231
2003 Velocity Red 231 (Faulty)
2001 Bmw 3 series 325se ci (Sold)
2000 Suzuki Gsxr 750
2000 Suzuki SV650s (Sold)
1997 Honda CBR600f
1995 Ford Probe 2.0 (Sold)
Has thanked: 467 times
Been thanked: 1887 times
Post by warpc0il » Thu Nov 22, 2012 4:55 pm
The RX-8 has "a useful feature" that many have discovered...
If you leave your phone in the car with the WiFi enabled, there's a very good chance that it will trigger the internal movement alarm.
To avoid this, either
  • - take the phone with you
    - switch WiFi off on the phone
    - switch off the internal alarm using the fourth button on the fob, shortly after locking the car.
