Black Halo Racing (BHR) Midpipe
shifty
Post by shifty » Fri Jan 21, 2011 5:22 pm
Well after reading Astons post on the BHR ignition kit I thought I would do one on there mid pipe which ive been running for about 2-3 months now.
Well if you look in the pic below this is it pretty sleek peice of kit and my first impression was ooo pretty :drool: shame its out of sight, If you look closely you may notice there is 2 bulges one is BHR custom made resonator and the other is a Dave sport high flow cat which BHR offer as an add on which they will weld in before dispatch you dont have to have this and just buy the pipe as a decat which I believe Elektix has opted for so hopefully when he has his fitted he will post an additional review here on the pipe without the cat.
I decided on this over the other offering from various company's du to there custom made resonator which was specially designed by the BHR guys to control the noise into a nice tone .
Well I did all the fitting my self (tight arse) and I managed to pick a nice wet and cold day to do it but it was simple enough to do after I managed to get the old nuts and bolts loose (rusted solid)
If you look in the pic below ive put the OEM side by side with the new pipe and there is a fair size difference not to mention a weight different im sure the OEM one is made from cast iron so that was another perk of the BHR pipe (weight reduction) :thumleft: aslo I noticed as a design improvement over oem is the O2 sensor position as on the OEM it faces down with a crappy little guard which ive clipped a few times du to me being lowered but the BHR pipe has the sensor more to the side tucking it out of reach of speed bumps and other objects protruding from the road..
After fitting it I took the car for a spin and the sound wasn't great it was a little lumpy and there was a few rattles :scratch: but I decided to give it a week or so and a few drives to bed in as my Borla took a while to settle and sure enough it did so no more rattles and the tone is spot on it has made it all louder but its not a thugish roar but more a smooth sporty growl from idle right up through the revs and gears , I can also say after giving it a good hammering to a mate who is an hour away there is definitely a little more poke how much I dont know but its there :twisted: .
So all in all im very pleased with it and I can recommend BHR to all there service is spot on even though there outside the UK and there products are of a high quality and designed by Rotary/racing enthusiasts :salut: =D> .
Has thanked: 467 times
Been thanked: 1887 times
Re: Black Halo Racing (BHR) Midpipe
Post by warpc0il » Fri Jan 21, 2011 5:31 pm
Did you reset the ECU after the install?
I would recommend a reset after any significant change to intake or exhaust, as it allows/forces the system to re-learn what works best for the new set-up.
shifty
Post by shifty » Fri Jan 21, 2011 5:35 pm
As per install procedure and common sense really I pulled the neutral from the battery and since im not the quickest worker it reset anyway after 15 minute I believe so it all worked out really.
Post by warpc0il » Fri Jan 21, 2011 5:51 pm
Battery disconnected doesn't give a full reset on it's own.
You need the [urlw=http://www.rx8ownersclub.co.uk/forum/vi ... 03&start=0]20-presses reset[/urlw] for all the trims.
Yours has probably got there by now...
shifty
Post by shifty » Fri Jan 21, 2011 6:18 pm
Ah I see maybe il try it at the weekend.
Elektix
Post by Elektix » Fri Jan 21, 2011 8:43 pm
Yes indeedy, mine is sitting on the floor, less than a foot away from me.......
I cant fit mine until I get a M18 x 1.5 bolt to blank one of my O2 sensor bungs. I spec'd a second one, so I could fit a wideband AFR gauge later on, but cant afford or install atm.
So need to get a bolt to block it off. If anyone has such a bolt ........ :wink:
And yes I will post up a little review once mine is on and bedded in. Which coincidently, will be just after my MOT on 2nd febuary odd....... :lol:
Tiny
Post by Tiny » Fri Jan 21, 2011 10:30 pm
I have a spare AFR bolt it is old and not shiney pretty but it's fine pm me your address and I'll post it out to you
2001 Mitsubishi Space Runner......Or the Red Bus Of Justice!
I no longer work for Apex and cannot under any circumstances recommend anyone use their services for anything.......ever......
Post by warpc0il » Fri Jan 21, 2011 10:45 pm
Elektix wrote: I cant fit mine until I get a M18 x 1.5 bolt to blank one of my O2 sensor bungs. I spec'd a second one, so I could fit a wideband AFR gauge later on, but cant afford or install atm.
Why you no read [urlw=http://www.rx8ownersclub.co.uk/forum/vi ... 1&start=30]your previous thread[/urlw]? [-X
Elektix
Post by Elektix » Sat Jan 22, 2011 11:11 am
Omg, Im sorry I didnt realise, others had already offered! :shock:
Due to work I post replies and keep up with the forum then when I return, I click 'New posts' and miss out repsonses to those people have responded to :roll:
Whoever is willing to send me the bolt I will be greatly appreciative off :D :D :D
shifty
Post by shifty » Sun Jan 23, 2011 10:59 am
Here is a link to the BHR site page that explains how and why the midpipe came to be.
countzero
Post by countzero » Mon Jan 24, 2011 1:56 pm
MMMmmm, might be an option for me, given my concerns over not being able to make the noise limit on track days should I get a high flow cat
Never send a ferret to do a weasel's job.
Still zoom-zooming
Winning Blue 231 - with a few extras
www.wessexcarclub.com
shifty
Post by shifty » Mon Jan 24, 2011 2:15 pm
It does control the noise well it's still louder but not out of control loud
Arnie_O
Post by Arnie_O » Mon Jan 24, 2011 11:31 pm
a little off topic but has anybody see the butterfly valve from Apexi... could be a sneaky way to get past the noise test for a track day
Weld in version
http://www.rhdjapan.com/apexi-ecv-exhau ... type-51297
Exhaust Gasket style version
http://www.rhdjapan.com/apexi-ecv-exhau ... type-55779
Royal Purple 2 Cycle Premix
shifty
Post by shifty » Tue Jan 25, 2011 8:16 am
Might be worth a seperate post for this mate not so much to keep this on topic but to draw direct attention directly to them as there an interesting idea.
Detsawm
Post by Detsawm » Tue Jan 25, 2011 10:52 am
:whathesaid: that does actually look like a very good idea, good find
Drew
See my project page here
geordiemike
Post by geordiemike » Sun Feb 06, 2011 10:32 pm
shifty with the high flow cat in place do you know if it'll pass emission tests?
The unwilling,
Lead by the untrained,
Doing the unnecessary
For the ungrateful.
livin the dream!
xbox live tag GeoRDie MiKe 87
Will66
Colour: Metropolitan Grey
Has thanked: 8 times
Been thanked: 47 times
Post by Will66 » Sun Feb 06, 2011 10:51 pm
Mine has for the last two years!
geordiemike
Post by geordiemike » Sun Feb 06, 2011 11:28 pm
belta!! thanks will, i think this may be my next purchase apart from two new rears.
The unwilling,
For the ungrateful.
livin the dream!
shifty
Post by shifty » Sun Feb 06, 2011 11:41 pm
It passed emissions in California and there test is alot tighter then ours apparently.
mj2326
Post by mj2326 » Mon Feb 07, 2011 9:57 am
If you don't mind me asking shifty how much did you pay all in for pipe cat shipping and import tax
RB ram air duct with k&n filter, petit hi flow cat, K sport 8 pots, Ferodo DS2500 pads with Goodridge Hoses, OEM bodykit, R Magic rear wing spoiler, 35% rear tints and sunstrip, Cusco F+R strut brace, bc coilovers, petit rally clutch with cromley light weight flywheel, RB anti roll bars F + R, Koyo sport radiator, 20mm Eibach pro spacers all round, lockwood grills, axial flow short shifter.
shifty
Post by shifty » Mon Feb 07, 2011 10:25 am
Pm sent
Seedler
Post by Seedler » Mon Feb 07, 2011 4:07 pm
Can you PM me too please Shift :)
Brilliant Black with ST Orange accents
Too many mods to mention, too much petrol used and too many exhaust-gasms to care!
"Bear s**** as standard"
shifty
Post by shifty » Mon Feb 07, 2011 4:36 pm
No!!!!Image
Seedler
Post by Seedler » Mon Feb 07, 2011 4:53 pm
Thanks Shift :) lol
You may aswell change your sig too "I know BHR, you dont!"
shifty
Post by shifty » Mon Feb 07, 2011 4:58 pm
Or the BHR whore as it seems to be my company of choice lately.
