Mazdaspeed Bumper (Aerokit Replica) Mesh recommendations
LeeW
Has thanked: 108 times
Been thanked: 87 times
Post by LeeW »
Can anyone recommend what mesh to use on the Mazdaspeed front end? The only thing i know is i want it black, not silver.
Not sure what size pitch is recommended for adequate protection to the oil coolers and radiator? Is there any reason to go for ABS plastic rather than stainless steel?
Any recommendations are welcome, my bodywork is now moving forward so want to buy something soon.
Cheers in advance
07' Kuro
RRP Single Res midpipe w/ Pettit/Milltek cat-back, RRP MK2 Coils and leads, AEM CAI, RRP Custom Map, RSW Custom Steering Wheel.
RX8 Story (slow progress): viewtopic.php?f=104&t=78506
Has thanked: 552 times
Been thanked: 2348 times
Re: Mazdaspeed Bumper (Aerokit Replica) Mesh recommendations
I use this stuff as it's tough, UV stable, cheap and easy to replace if required.
Amazon link was the first one to come up but it's available in all sorts of places, including Poundland
LeeW
Post by LeeW »
baring in mind its for gutters, does that stuff only come in 16x5 strips? i would want something to cover the whole middle opening in one piece. having to join loads together will look a bit naff?
07' Kuro
How deep is the opening?
Spoiler:
@Nigel - You're barred from responding to this question [-X
Vj4sothername (Fri Mar 20, 2020 7:21 pm)
LeeW
Post by LeeW »
hahaha.
haven't actually measured but it's more than 16x5. 60x30 if i had to guess.
07' Kuro
LeeW
Post by LeeW »
What's the deal with the contrasting grey lower sections of the MS kit? Is it always that colour because thats the look of the genuine? Is it widely accepted that it would look bad if all matching body coloured, even on a black RX8? And what is the 'official' colour of those sections that I should tell my body guy?
07' Kuro
Ryan Rotary Performance
Former Trader
Former Trader
Has thanked: 69 times
Been thanked: 219 times
Post by Ryan Rotary Performance »
warpc0il wrote:
Fri Mar 20, 2020 5:42 pm
Cheap and Nasty IMO (you got the poundland Decals to go with them? :lol: ), if you just look on Ebay and search universal car mesh or grill a plethora of returns will show all with different styles to match the look you want.
Merlin motorsports is another shout.
untakenname
Has thanked: 120 times
Been thanked: 137 times
Post by untakenname »
I originally tried gutter guard but it melted so then used some aluminium mesh that is designed for car grills on my rear bumper, it holds its shape and is easy to mould, has lasted 3 years now with no corrosion.
LeeW
Post by LeeW »
Thanks for the replies guys. I sort of got off topic on my own old thread though, rather than start a new thread. My last post was asking about the paint colour differences on the MS kit, not mesh anymore....
07' Kuro
pfletcher83
Been thanked: 23 times
Post by pfletcher83 »
AFAIK there is no official code for the grey - at least none that i could find and that included phoning mazda themselves.
The colour i had mine painted was - a39 (Mitsubishi graphite gray) which seems spot-on.
Not the best pics but gives you an idea
Paul
These users thanked the author pfletcher83 for the post:
untakenname (Fri Nov 27, 2020 8:42 pm)
LeeW
Post by LeeW »
Cheers Paul
They’re beautiful pictures. Is that a genuine rear or replica?
07' Kuro
pfletcher83
Replica unfortunately, tried to get an original at the time but they were pretty much impossible to come by.
Its been on 10 years and still looks in perfect condition so i cant complain really :thumleft:
Been trying to get hold for some genuine R-Magic side skirts for years but they are even more difficult to come by without importing from japan and taking out a 2nd mortgage :x
Paul
LeeW
Post by LeeW »
pfletcher83 wrote:
Fri Nov 27, 2020 12:48 pm
Paul
Looks great. Would you happen to have any pictures of how you braced the bottom on the tabs? I see the genuine came with Z shaped brackets but obviously nothing with the reps. Did you source some similar brackets?
Also, have you left it with no fog light? Or does anyone have any recommendations for a replacement foglight that can be fit nicely into the bumper?
07' Kuro
pfletcher83
I didnt fit the bumper but i have been under and can say that the bottom tabs are not secured to anything. Its secured to the bumper and in the wheel arches
I noticed it when i went to wire in a fog light for MOT. It did concern me at the time that windflow could cause it to bow, but ive had someone follow me at motorway :whistle: speeds and there is no movement, still solid to this day.
I dont have permanent fog light, i just bolt on a cheap one for MOT, or when its foggy :D
Paul
LeeW (Fri Jan 29, 2021 1:03 pm)
LeeW
Post by LeeW »
How important are the rubber oil cooler surrounds? I think I want to remove them for the MS front bumper. The cut outs sit quite tight to them.
07' Kuro
They direct air through the cooler core, rather than let it escape round the outside, so make the coolers much more efficient.
However, unlike the radiator surround, the oil cooler efficiency shouldn't be an issue for a road car, hence the Mouse Mat mod.
Different story if you plan to take the car on track.
I would be inclined to take a scalpel to the surrounds and just trim the area that interferes, rather than removing completely.
LeeW (Tue May 25, 2021 3:43 pm)
LeeW
Post by LeeW »
Turns out they fit fine behind there actually.
And the bumper is only resting on the top mounts, not bolted in properly at the sides or anything, hence why its sticking out all weird.
These users thanked the author LeeW for the post:
MARKTHOMASBRAND (Sun May 30, 2021 7:46 am)
07' Kuro
