Headlights
brix79
Has thanked: 109 times
Been thanked: 366 times
Headlights
Post by brix79 » Tue Oct 13, 2020 6:25 pm
Stumbled upon an interesting thing:
Now I know the Dr of Franken has had many dabblings with this sort of thing, and may well be able to enlighten ( :mrgreen: ), so I thought we could have a thread for headlight things. 8)
Chairman & Forum Admin Team
2017 // 2010 Aurora Blue R3
Potenza S001s | 20mm Eibachs | M1144s | Pettit Catback
2011-17 // 2005 Titanium Grey 231 | Gone, but never forgotten..
Has thanked: 731 times
Been thanked: 663 times
Re: Headlights
Post by New Duke » Tue Oct 13, 2020 6:29 pm
OMG John where did you find those?!
I've wanted dark headlights for ages and if they could have pretty lights as well then that's just... goodness they're pretty.
Has thanked: 26 times
Been thanked: 360 times
Re: Headlights
Post by Yorindesarin » Tue Oct 13, 2020 6:39 pm
Ooft where do I get such goodies..
Has thanked: 434 times
Been thanked: 824 times
Re: Headlights
Post by kopite72 » Tue Oct 13, 2020 6:41 pm
liking the darkened housing although I'm a bit :-k about the light itself
R3 GONE, FUN WHILE I HAD HER BUT NOW LOVING MY 25TH ANNIVERSARY MX5.... MODS INBOUND 8)
brix79
Re: Headlights
Post by brix79 » Tue Oct 13, 2020 7:33 pm
Tbh, I came across it when browsing rx8 things, but the place I downloaded the pic from was here:
I know nothing more! Other than they are mighty fine, though I'm with Ian on the actual lights, I don't care much for the spectrum colours.
These users thanked the author brix79 for the post:
New Duke (Tue Oct 13, 2020 9:33 pm)
Has thanked: 105 times
Been thanked: 286 times
Re: Headlights
Post by PaulAV » Tue Oct 13, 2020 7:36 pm
I had a thread on headlights somewhere, earlier this year. It's worth watching flyryde on YouTube he modified a set of rx8 headlights (he's a professional at it)
Vj4sothername (Tue Oct 13, 2020 11:38 pm)
brix79
Re: Headlights
Post by brix79 » Tue Oct 13, 2020 7:46 pm
I knew there'd been a thread before, I'll have a look for it as there was a lot of useful stuff in it.
PaulAV (Tue Oct 13, 2020 8:14 pm)
Vj4sothername
Has thanked: 1323 times
Been thanked: 310 times
Re: Headlights
Post by Vj4sothername » Tue Oct 13, 2020 11:41 pm
PaulAV wrote:I had a thread on headlights somewhere, earlier this year. It's worth watching flyryde on YouTube he modified a set of rx8 headlights (he's a professional at it)
I watched his vid to get mine apart to add the DRL switchbacks and paint the internals. Clearly knows his stuff. The catching the whispy bits was the best tip.
S1 - 231 - brilliant black
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Has thanked: 266 times
Been thanked: 581 times
Re: Headlights
Post by Dr. FrankenRex » Tue Oct 20, 2020 4:12 pm
I've done a few sets for peeps :thumleft: pretty easy to do and - in my opinion at least - looks mega.
craigy85
Has thanked: 64 times
Been thanked: 16 times
Re: Headlights
Post by craigy85 » Thu Oct 22, 2020 5:32 pm
How much do you charge for such magical services Dan? Love the look, although I'd probably need a new set of lenses - mine have lots of what appear to be micro cracks across the top :(
2008 Sparkling Black R3 with RRP Mk3 Coils & MSD 8.5mm leads
Previously - 2005 Nordic Green 231 with Axxess Ipod kit, Integrated Bluetooth Handsfree Kit, SS Strakes, SS Lockwood Grilles
brix79
Re: Headlights
Post by brix79 » Thu Oct 22, 2020 7:48 pm
I have exactly the same problem with mine..
Re: Headlights
Post by PaulAV » Thu Oct 22, 2020 7:57 pm
I set sanded my lenses with fine wet and dry (1000 down to 2000 grit) then sprayed them with clear lacquer can't see the cracks now
Has thanked: 23 times
Been thanked: 141 times
Re: Headlights
Post by 350matt » Thu Oct 22, 2020 8:33 pm
do you still see the cracks with the lights on?
Re: Headlights
Post by PaulAV » Thu Oct 22, 2020 8:41 pm
Nope
Has thanked: 456 times
Been thanked: 1837 times
Re: Headlights
Post by warpc0il » Fri Oct 23, 2020 12:10 am
Micro cracks are usually within the structure of the plastic, usually caused by solvents (e.g. wrong cleaning/polishes/screenwash) or local heat, and as such they would normally show up more when the light in on, as the edges illuminate like the ends of fibre optics. There's nothing you can do to fix these, other than replacement.
Surface scratches can also be caused by solvents etc but as they don't penetrate the surface they tend to be less obvious when the light is on. These can be fixed by removing the scratched surface and polishing.
Re: Headlights
Post by Dr. FrankenRex » Fri Oct 23, 2020 9:30 am
Unfortunately I have not found any new lenses for the R3 lights (or S1 for that matter) so that might be a no go. Hazing can be dealt with easily, cracks not so much.
Splitting down the lights, polishing the externals, spraying gloss black internals, reassembling and then clear coating the lenses is £150 with incl shipping (unless it's going abroad then it may cost a little more).
There's no guarantee the cracks will be improved upon, though, I'm afraid - rather be upfront than promise the earth and under-deliver.
New Duke (Fri Oct 23, 2020 3:44 pm)
Vj4sothername
Re: Headlights
Post by Vj4sothername » Fri Oct 23, 2020 11:14 am
Have you looked into recasting them Dan? I found a few products that would do it while looking at the rear lights.
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Re: Headlights
Post by warpc0il » Fri Oct 23, 2020 5:57 pm
When I said about "replacement" I was referring to entire light assembly rather than just the front lens.
These used to be super expensive and still are @ £648 a pop for the HIDs (£190 for Halogen) new retail from a dealer, but the number of cars being broken means that used supply exceeds demand and prices are much more reasonable.
I've seen a good(?) pair of HIDs go for £40 on ebay and even less on FB Market.
Re: Headlights
Post by Dr. FrankenRex » Mon Oct 26, 2020 12:22 pm
Not looked in to it at all as yet, mainly because I only really work with the R3 lights and they are usually in fairly good condition. Good enough to put up with.
Vj4sothername (Mon Oct 26, 2020 12:54 pm)
Re: Headlights
Post by Dr. FrankenRex » Mon Oct 26, 2020 2:11 pm
Just revisiting John's original picture, it's different. Not sure whether I prefer the matte/ satin black over the gloss in mine..
Hmm...
brix79
Re: Headlights
Post by brix79 » Mon Oct 26, 2020 7:21 pm
Do you have a pic of your gloss ones Dan? There was a thread with it all in wasn't there. Guess I should actually look for it.. :D
Something like the one above, just for comparison sake. Personally, I think either look damn sweet. 8)
Re: Headlights
Post by warpc0il » Mon Oct 26, 2020 10:39 pm
Someone at Mazdafest had a 2012 JDM S2 8 with metallic gunmetal headlight internals that looked really cool. He was pretty sure it came built like that and wasn't aftermarket.
I didn't get to take a photo as I was driving on track, and I've looked on the Irish Rotary forum and FB page and haven't found a pic there either (yet).
Vj4sothername
Re: Headlights
Post by Vj4sothername » Mon Oct 26, 2020 10:57 pm
Metallic gunmetal is a fine choice for accent bits.
Not that the 8 cans of it I have waiting for my next project bias my opinion....
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Goobie
Has thanked: 35 times
Been thanked: 312 times
Re: Headlights
Post by Goobie » Mon Oct 26, 2020 11:03 pm
That satin finish does look tasty!
Dan, you have pictures of ones you’ve done for people?
