Replacement Radiator
Ninja_Freak
Has thanked: 34 times
Been thanked: 32 times
Post by Ninja_Freak » Tue Apr 16, 2019 1:56 pm
HI folks,
As the car is in the shop having a rebuild (more on that later), after 100k miles on, is it time to change the rad?
What are the options? This (https://www.mishimoto.co.uk/mazda-rx8-p ... gIkZfD_BwE) is very pretty but it's also £260 quid (assuming we don't have a club discount anywhere??) which is quite a bit. Is it better to find a decent used version or not to worry at all?
All input gratefully received!
NF
56 Plate PZ in Galaxy Grey!!
Has thanked: 79 times
Been thanked: 81 times
Re: Replacement Radiator
Post by Scartlead » Tue Apr 16, 2019 2:41 pm
My advice is do not go for the mishimoto. It doesn't fit well. Go for OEM , less than 100£ from euro car parts or a bigger koyo if you're feeling flush! If the one fitted is the original one, then save some dosh and replace it with the same.
Ninja_Freak
Post by Ninja_Freak » Tue Apr 16, 2019 2:48 pm
Thanks for the advice.. :)
Essex2Visuvesi
Been thanked: 242 times
Post by Essex2Visuvesi » Tue Apr 16, 2019 3:13 pm
Was it you that had the world of pain trying to fit a MM rad?
Has thanked: 256 times
Been thanked: 975 times
Post by warpc0il » Tue Apr 16, 2019 3:39 pm
Why change the rad?
Just give it a good flush with a hose and refit, unless it's damaged.
Post by Scartlead » Tue Apr 16, 2019 3:42 pm
Twas me sir. Pain in the arse! Ended up going oem.
Ryan Rotary Performance
Forum Trader
Forum Trader
Has thanked: 94 times
Been thanked: 287 times
Post by Ryan Rotary Performance » Tue Apr 16, 2019 4:56 pm
Money no object, The Pro-Alloy is the best I've seen and is what I have on mine, the Mishimoto fits a lot better these days and also has the mounting points for the AC condenser.
https://www.ryanrotaryperformance.com/p ... ubrication
Pro Alloy £540
Mishimoto £250
Has thanked: 570 times
Been thanked: 823 times
Post by 13Black » Tue Apr 16, 2019 5:06 pm
The Mishi rad I fitted to Ed's car wasn't that testing imho. That was a recent one with AC mounts.
Eddie_r32
Has thanked: 37 times
Been thanked: 119 times
Post by Eddie_r32 » Tue Apr 16, 2019 5:10 pm
Yep, they have improved a lot, would happily Reccomend a mishimoto one now
2007 Galaxy grey 231 with full RRP bridge.
Post by Scartlead » Tue Apr 16, 2019 5:48 pm
The mishi I bought was maybe 18months ago. Was far from being perfect.wouldnt going anywhere near another one!
SeriousSam
Been thanked: 227 times
Post by SeriousSam » Wed Apr 17, 2019 6:09 am
The Koyo rads that Clive sells are a very good option, fit is not a problem and performance is excellent.
Ninja_Freak
Post by Ninja_Freak » Wed Apr 24, 2019 5:05 pm
Thanks for your input folks! I really appreciate this place! :)
Has thanked: 35 times
Been thanked: 141 times
Post by mi60o0 » Sat May 11, 2019 8:49 pm
Up what you end it up getting in a next 4 5 weeks I will change the coolant hoses and is a good time for ally radiator to I think I was thinking for mishi due funds.
BatRex 192 stock
