Bought a MIG Welder
Has thanked: 4504 times
Been thanked: 1857 times
Bought a MIG Welder
Post by ChrisHolmes » Sat Jan 18, 2020 11:43 am
Whilst I don’t need one, hopefully, at £20 this was worth a punt. Once the car is back in the road then I can have a poke around to see if this works or is a lemon.
iPhone photos!!!!!
Exedy Stg1 Clutch
Adaptronic ECU
Neilparry
Has thanked: 28 times
Been thanked: 227 times
Re: Bought a MIG Welder
Post by Neilparry » Sat Jan 18, 2020 11:50 am
If it works
I’ll get you some steel to practice on
These users thanked the author Neilparry for the post:
ChrisHolmes (Sat Jan 18, 2020 12:02 pm)
:wash:
Vj4sothername
Has thanked: 465 times
Been thanked: 124 times
Post by Vj4sothername » Sat Jan 18, 2020 11:58 am
Most jealous. I've wanted one for ages.
S1 - 231 - brilliant black
Feb 08 built,
Fake Toyosport back box,
Dents,
Scratches,
Replacement engine,
Smiles
mrspiller
Has thanked: 116 times
Been thanked: 265 times
Post by mrspiller » Sat Jan 18, 2020 12:01 pm
If you need any tips I can help ImageImage
Ask Neil ImageImage
Tips for the torch? :D
Post by ChrisHolmes » Sat Jan 18, 2020 12:06 pm
If it works
and a couple of bits of stainless for a real challenge. Their is a mod that can be done to the rear box on the M3 to make it sound a bit throatier!!!!
Exedy Stg1 Clutch
Adaptronic ECU
Essex2Visuvesi
Been thanked: 292 times
Post by Essex2Visuvesi » Sat Jan 18, 2020 12:11 pm
everyone should have a welder
mi60o0
Has thanked: 80 times
Been thanked: 263 times
Post by mi60o0 » Sat Jan 18, 2020 12:14 pm
Every one should have a garage to xD
BatRex 192 stock
Vj4sothername
Post by Vj4sothername » Sat Jan 18, 2020 12:30 pm
mi60o0 wrote:Every one should have a garage to xD
The dream!
Feb 08 built,
Dents,
Scratches,
Replacement engine,
Smiles
nightfire10
Has thanked: 732 times
Been thanked: 287 times
Post by nightfire10 » Sat Jan 18, 2020 12:31 pm
ChrisHolmes wrote:Whilst I don’t need one, hopefully, at £20 this was worth a punt. Once the car is back in the road then I can have a poke around to see if this works or is a lemon.
iPhone photos!!!!!
Bargain if it works
Post by ChrisHolmes » Sat Jan 18, 2020 12:39 pm
The dream!
The nightmare, where will it go?
Exedy Stg1 Clutch
Adaptronic ECU
Vj4sothername
Post by Vj4sothername » Sat Jan 18, 2020 12:41 pm
ChrisHolmes wrote: The nightmare, where will it go?
Still better than having to hide it under dress shirts...
Feb 08 built,
Dents,
Scratches,
Replacement engine,
Smiles
Post by ChrisHolmes » Sat Jan 18, 2020 12:46 pm
Plugged it in, fan came on squeezed trigger and I have wire feed and sparks.
Gas bottle to fill next week and it’s play time soon!
Vj4sothername (Sat Jan 18, 2020 12:46 pm)
Exedy Stg1 Clutch
Adaptronic ECU
Neilparry
Post by Neilparry » Sat Jan 18, 2020 1:03 pm
I’m glad you live many miles away from Wayne. You wouldn’t want tuition off him.
These users thanked the author Neilparry for the post (total 2):
Vj4sothername (Sat Jan 18, 2020 2:20 pm) • MARKTHOMASBRAND (Sat Jan 18, 2020 4:35 pm)
:wash:
Has thanked: 371 times
Been thanked: 1413 times
Post by warpc0il » Sat Jan 18, 2020 2:08 pm
That right one looks like TIG rather than MIG.
mrspiller
Post by mrspiller » Sat Jan 18, 2020 2:19 pm
Neilparry wrote:I’m glad you live many miles away from Wayne. You wouldn’t want tuition off him.
Ha ha
Mine maybe bad but yours is no where near as good as the one on the right ImageImageImage
Neilparry
Post by Neilparry » Sat Jan 18, 2020 2:23 pm
Ha ha
That’s the difference between my capabilities and yours ImageImageImageImage
:wash:
Has thanked: 138 times
Been thanked: 504 times
Post by qwakers » Sat Jan 18, 2020 4:56 pm
you'll need a 32a supply for that :D
nice buy though, that's the bargain of the century at 20, the bottle alone is worth more, even empty!
Post by ChrisHolmes » Sat Jan 18, 2020 6:18 pm
Hmm! Thought I could just plug it into a standard 3 pin plug!
Exedy Stg1 Clutch
Adaptronic ECU
Post by qwakers » Sat Jan 18, 2020 6:24 pm
tbf you probably can, but its a old transformer welder so you need to find inrush current and max standing current when in use.
http://www.einhelltools.co.uk/pdfs/store/17216.pdf
i cant find any mention of it in einhells documentation so it might be worth testing at max power with a clamp meter....
or going on migwelding.co.uk and asking the good pro people on there :D
also, pull the top off the plug and check someone hasn't bypassed the fuse :D. Good shout
Thanks for the tips
Post by ChrisHolmes » Sat Jan 18, 2020 7:00 pm
Basic question. How can you tell how much gas is in the bottle? The gauge is showing 2000psi.
Exedy Stg1 Clutch
Adaptronic ECU
Post by qwakers » Sat Jan 18, 2020 7:04 pm
2000 psi is about 1/2 full :D the red line is max fill on most bottles. (note most, some are filled to a lower pressure, these bottles are a ripoff)
edit, 200bar roughly is full on the cylinders i use. some are only filled to 150 (usually sold as hobby weld) that is several hours less welding with the same size bottle.
id strongly recommend a argon/co2 mix, pure co2 works, but leaves a messier weld and is harder to learn.
i use air products cylinders. they are account only, and will deliver and collect.
ChrisHolmes (Sat Jan 18, 2020 11:09 pm)
Honkytonk
Has thanked: 208 times
Been thanked: 401 times
Post by Honkytonk » Sat Jan 18, 2020 8:11 pm
Hey Chris, if you want an RX8 shaped 'Project', I happen to know of a black one that could use the attention... :lol:
These users thanked the author Honkytonk for the post:
Vj4sothername (Sat Jan 18, 2020 8:11 pm)
The P-Shed Project Thread
Neilparry
Post by Neilparry » Sat Jan 18, 2020 8:24 pm
If your looking to do both stainless and mild steel then go for an argon co2 mix which will cost you more But cheaper than having two different bottles, but you will have to purchase different wire.
ChrisHolmes (Sat Jan 18, 2020 11:08 pm)
:wash:
Post by ChrisHolmes » Sat Jan 18, 2020 11:14 pm
@qwakers. This jus5 gets to be a bigger bargain as the gas is an Argon C02 mix
@ Honkytonk. I am not that brave, clean thick metal would be a challenge!
@ Neil Just need the wire then
Note to self: get loads of practice. Making a bench and some shelving as a starter project perhaps
Exedy Stg1 Clutch
Adaptronic ECU
Post by warpc0il » Sat Jan 18, 2020 11:40 pm
I had to teach Pauline to weld, after I broke my arm and the mudguard brackets cracked on the 'bike trailer.
It was more like Pauline teaching me how to swear, as she came out with language that would have made a squadie blush.
To be fair, she had it down after about an hours practice and even cut off some of the first joints and did them again much neater, and stronger.
Return to “DIY”
