Just finished installing some new Gauges using Dashcommand on my car PC. Still got a few more modifications to do and I'm working on a night skin to match the OEM blue and red Gauges.
- Dash gauges.jpg (95.94 KiB) Viewed 1306 times
I use this screen the most and it's helpful for making sure the car is up to temp so I can beep it. The temp gauge on the OEM dash reaches 12 o'clock at 62 degrees, but I don't beep till the temp gets to 80.
- Dash gauges2.jpg (92.35 KiB) Viewed 1306 times
This one looks good but just repeats the standard gauges. I must fix the typo from MPG to MPH
The Rev counter is good though, I've got it to turn red when it hits the beep as a visual guide.
- Dash gauges5.jpg (98.59 KiB) Viewed 1306 times
This is a work in progress screen giving me gear efficiency info and tells me what gear I can drop down to. The gears that would exceed max RPM go red to indicate they should not be used. Likewise the upper gears only turn blue if the engine load would be below a set threshold. Quite good for telling you the best gear to be in. The fuel flow gauge has yet to be calibrated before it is reliable. I've got to change the speed bar on the left hand side from KPH to MPH.
More stuff to follow.......
