Carbon Fibre wrapping
Delanor
Has thanked: 62 times
Been thanked: 336 times
Post by Delanor »
I thought I would ask you very clever RX-8 owners as I have decided I am not happy with the black mirrors on my Formentor and so I thought a carbon fibre look would be different but its something I have never done before so have watched a couple of how to videos but it seems that as the mirrors are quite angular a certain adhesive should used on sharp edges/corners and I am concerned what that means if you have to remove the vinyl at some time.
So can any of you wrappers advise! :-k
DrewR3
Has thanked: 265 times
Been thanked: 1116 times
Re: Carbon Fibre wrapping
Post by DrewR3 »
Have you searched for carbon fibre covers. I had a bargain on amazon with an incorrect priced carbon cover for both my Merc coupe and estate (same mirrors). Someone appeared to have misplaced the decimal point so I bought x2 pairs for the cars at £5.00 a set including prime delivery. They quickly changed to £50 a set, but in fairness they honoured my £5 bargain and are brilliant. Pre attached 3m tape, simply peel and stick over wingmirror. Look great, perfect fit and doesn't look like a cap is installed over. I probably would of even been happy at £50.
These users thanked the author DrewR3 for the post:
Delanor (Wed Apr 24, 2024 12:23 am)
RX-8 2010 R3, Crystal white, 26k miles, Full Mazda Service History
Daily - 2012 Mercedes E220 Coupe AMG sport, Deep Blue, 19 inch AMG alloys with Michelin Pilot Sport 4s, AMG BBK with drilled discs
Previous RX-8 - 2006 '56' S1 Pz Prodrive edition, Galaxy Grey
Has thanked: 9751 times
Been thanked: 4920 times
Have you looked into hydro dipping which is ideal for components like wing mirrors
Has thanked: 2777 times
Been thanked: 2900 times
Post by MARKTHOMASBRAND »
:arrow: Clicky here
:arrow: Here
I know Steve (nightfire10) has used Wicked Coatings but they're in Dorset :p
Or as Drew suggested...
:arrow: Something like this
Obviously check those will fit :roll:...just the first ones I found :lol:
These users thanked the author MARKTHOMASBRAND for the post (total 2):
ChrisHolmes (Wed Apr 24, 2024 6:18 pm) • Delanor (Thu Apr 25, 2024 12:20 am)
Any updates on the mirrors Del :?:
Delanor
Post by Delanor »
WIP Mark - can`t decide what to do, if I wrap them the caps really need to come off and I`m a little concerned about the plastic tags that hold the caps on breaking, there are carbon fibre caps for £150 that fit over the top of the originals but what would they look like, or there are complete replacement carbon fibre caps but a slight problem they are at £440 a side! :shock:
Ali Express do carbon fibre caps for various cars for less than £20 but not the Formentor! :roll:
UPDATE - have just carefully removed the passenger side mirror cap and only 2 tags broke! #-o :roll:
These users thanked the author Delanor for the post:
MARKTHOMASBRAND (Sat May 18, 2024 4:39 pm)
Has thanked: 832 times
Been thanked: 3560 times
Even in warm weather I heat with a heatgun on low setting, so avoid snapping tags
£49 if you need a replacement Del :money:
Clicky
Delanor
Post by Delanor »
warpc0il wrote:
Sat May 18, 2024 11:29 pm
I waited for a warm day but made a mistake - on Youtube some one removed the mirror cap and reckoned it easily pulls off, the tags/clips are strong "you won`t break them", mine came off easy one side but wouldn`t come off the other and there was no gap to get any sort of trim tool in to help anyway broken clips now re-constituted (fixed with an overlay of stainless steel sheet and Rolls Royce super strength adhesive)
Mark the caps are OE at £30 or copies at £22 in primer, mine are metallic black have got a couple of requests for the part number ready painted as the paint is a sort of satin/matt finish, if I modify anything I prefer to be able to return to standard if needed in the future.
Anyway onward and upward "lets wrap" how difficult can it be you never know mirror caps today a "Green" RX-8 40th Anniversary tomorrow" :shock:
s-l1600 (1).webp (54.65 KiB) Viewed 73 times
MARKTHOMASBRAND (Sun May 19, 2024 11:38 am)
Dem wrappaz mek it luk eezy doe innit bruv :lol:
Return to “DIY”
