FORscan for the RX8
Vj4sothername
Has thanked: 959 times
Been thanked: 201 times
Re: FORscan for the RX8
Post by Vj4sothername » Sat Jul 25, 2020 10:18 am
rotatopotato wrote:Ah, that sounds like a right mess Image
Out of interest, was the problem with the original key not turning the locks just a faulty actuator? As my new spare has the same issue (doesn't work in boot or door but fine in glovebox/ignition), key cutter reckons it should be fine with the tip how it is as he says it's effectively just leftover material that other machines will trim but his doesn't. Although my original key does work in the locks so maybe not the same issue...
The key wouldn't turn in the locks. In the boot I found a bag with a code on it for taking it to dealer for re programming. I had assumed that they keys where lost and it was just a new ignition barrel.
I've just tried the ski hatch and glove box again but with a more open mind and they work with the key that came with the car. Now I'm hoping I have the original locks to out back in and it's the same issue you face.
What did he say to remove from the key?
S1 - 231 - brilliant black
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Vj4sothername
Post by Vj4sothername » Sat Jul 25, 2020 10:24 am
FFS
https://youtu.be/l55qBsZ4QrM
It's a good job I seem to enjoy doing a job twice....
Well at least the boot one won't work no matter what!
Last edited by Vj4sothername on Sat Jul 25, 2020 10:24 am, edited 1 time in total.
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
rotatopotato
Post by rotatopotato » Sat Jul 25, 2020 10:37 am
FFS
I tried pulling the key out slightly, too (was suggested by the cutter as well). No dice. Have tried all kinds of wiggling.
rotatopotato
Post by rotatopotato » Sat Jul 25, 2020 10:39 am
Oh and thanks for making me realise the hatch to the boot is for skis! I would never have considered that.
Vj4sothername (Sat Jul 25, 2020 10:41 am)
Vj4sothername
Post by Vj4sothername » Sat Jul 25, 2020 10:50 am
FFS
How odd. I'll have a play with mine on the removed door lock and see if some filling will help make it work. You may find yours will be okay after a bunch of use in the ignition.
Then I'm going to try and take apart the old boot look and see if I can move the barrel over and get it working.
All of this is more fun than trying to drill the ignition barrel off. I was dreading to the point I removed the rear sub frame and derusted the arse end of the car over doing it Image
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Has thanked: 408 times
Been thanked: 1633 times
Post by warpc0il » Sat Jul 25, 2020 11:14 am
Just a quick thought....
The normal keys open all the locks and work the ignition.
The Valet* key works the door locks and the ignition but not the glovebox, boot or ski-hatch.
Is your new key working like a Valet key?
*So Valet parking can move the car but not access the glovebox or boot.
rotatopotato
Post by rotatopotato » Sat Jul 25, 2020 11:37 am
No, it's working almost opposite to a valet key. The exterior locks don't turn but the ignition and both internal locks do.
I'll use it as my main key for a while and see if some use in the ignition improves things. I'm not too bothered by it, the main thing is it starts the car.
Vj4sothername
Post by Vj4sothername » Mon Jul 27, 2020 2:19 pm
Got the key blade though today. Works in the ignition and door lock (that I will refit). Programmed using the excellent guide up top and I now hold the only two keys that will start the car!
I did the full wipe as I didn't fancy 3 other keys being able to start it. Was a touch nerve wracking as the instructions said turn to RUN. I assumed that was just ON and thankfully it worked. You'll need two keys to do this as the car won't start again untill it's programmed two.
Not sure if the VISTEON code is important to match or If I got super lucky and randomly got the exact same one.Image
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Vj4sothername
Post by Vj4sothername » Mon Jul 27, 2020 4:04 pm
For the driver's door lock I have to push the key in fairly hard and one way round is better than the other. It works both ways but clearly has a preference to one side.
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Post by warpc0il » Mon Jul 27, 2020 4:22 pm
Are we all hoping that Nigel's not following this thread? [-X
GreySilver Beast (Mon Jul 27, 2020 4:35 pm) • Vj4sothername (Mon Jul 27, 2020 4:53 pm)
rotatopotato
Post by rotatopotato » Tue Jul 28, 2020 7:39 am
Who's Nigel?
Post by warpc0il » Wed Jul 29, 2020 12:14 am
:lol: :lol: :lol: :lol: :lol: :lol:
Ainmhidh
Has thanked: 394 times
Been thanked: 343 times
Post by Ainmhidh » Wed Jul 29, 2020 9:52 pm
Ever heard the phrase "Ignorance is bliss"? :lol: When he gets here, you'll know about it! :shock:
These users thanked the author Ainmhidh for the post:
Vj4sothername (Wed Jul 29, 2020 10:05 pm)
Return to “DIY”
