PZ spoiler fitting
The Ginga NinjRx8
Has thanked: 9 times
Been thanked: 9 times
PZ spoiler fitting
Post by The Ginga NinjRx8 » Fri May 11, 2018 2:56 pm
I managed to pick up a PZ spoiler the other day and was hoping to be an easy fit but from the instructions on here your left with holes.
Just went to a garage and to do all the work was quoted £300
Wondered if anyone else has done it and if price is good or not. I think it's good
Stealth black 192:
Pioneer double din head unit
18"x9.5 ET40 all around
MisteR coilovers
Rear smoked LED
Dazza44
Has thanked: 176 times
Been thanked: 85 times
Re: PZ spoiler fitting
Post by Dazza44 » Fri May 11, 2018 3:04 pm
if u not confident to fit yourself(it's really not that difficult to fit spoiler) just a bit of care needed.
but 300 quid is that supply and fit spoiler
I wouldn't pay nowhere near 300quid just to fit one it's no more than about an hour work.
Sent from my SM-G920F using Tapatalk
The Ginga NinjRx8
Post by The Ginga NinjRx8 » Fri May 11, 2018 4:17 pm
but 300 quid is that supply and fit spoiler Image
It's not that I can't it's the holes I want them filled in properly as the spoiler doesn't cover old holes does it?
Stealth black 192:
MisteR coilovers
Rear smoked LED
WhelanUK
Been thanked: 16 times
Post by WhelanUK » Fri May 11, 2018 5:49 pm
A PZ spoiler should cover holes from a lip spoiler i believe.
If not finding a replacement boot without one and having a go yourself will be much much cheaper.
• Brilliant Black PZ • D585-R Coils • Magnecor Leads • Rear LED Lights • 13Black Mini Map • GROM Unit • Piano Black Trim • Cusco Front Strut Brace • Custom Steering Wheel • 13Black Engine Mounts • 20mm Spacers • Short Shifter • R3 Interior • AEM Intake • Toyosport Decat
The Ginga NinjRx8
Post by The Ginga NinjRx8 » Fri May 11, 2018 8:04 pm
If it covers the holes I will do it myself but going on the post when someone did it he made his own holes so not sure.
Can someone confirm ??
Stealth black 192:
MisteR coilovers
Rear smoked LED
Ian.Mothersole
Has thanked: 38 times
Been thanked: 300 times
Post by Ian.Mothersole » Mon May 14, 2018 12:15 am
The PZ spoiler definitely covers the holes :thumleft: it's the main reason I went with one on my red car.
If it doesn't, then you've done something wrong...
Have a look at my DIY thread: https://www.rx8ownersclub.co.uk/forum/v ... 30&t=39925
These users thanked the author Ian.Mothersole for the post:
ShuffleFun (Wed May 22, 2019 11:15 am)
Ian.M - Keep It Simple!
Club Shopkeeper & Forum Admin Team
"Rex" 2009-16
Velocity Red 231; Hayward Rotary ported engine; Racing Beat exhaust, flywheel, air duct, anti-roll bars; Eibach lowering springs, wheel spacers; Essex Rotary mini-remap; Prodrive PZ spoiler.
"Rex 2" 2014-
Velocity Red 231; the project car.
"Blue Rex" 2015-
Winning Blue 231; RX ATE.
The Ginga NinjRx8
Post by The Ginga NinjRx8 » Mon May 14, 2018 10:04 pm
So you have to make a new hole but does cover the old holes?
If so I will so myself lol
Stealth black 192:
MisteR coilovers
Rear smoked LED
Ian.Mothersole
Post by Ian.Mothersole » Wed May 16, 2018 10:23 am
Yes. The new holes are a little further forward, but the PZ spoiler definitely covers all four holes left by the lip spoiler.
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
The Ginga NinjRx8
Post by The Ginga NinjRx8 » Wed May 16, 2018 1:16 pm
Thank you for confirming I will get onto this soon as now
Stealth black 192:
MisteR coilovers
Rear smoked LED
Has thanked: 66 times
Been thanked: 207 times
Post by mi60o0 » Mon Dec 24, 2018 7:48 am
Did you manage to fit it I went a cheaper way and had this gem from r3 but price was 80 delivered to my door same colour and mint condition.
Took me less than a hour to measure and drill thanks to Dave he give me tips how to do the job easy
I just leav the black plasticks as I have two holes in the middle
BatRex 192 stock
SeeJay
Has thanked: 179 times
Been thanked: 373 times
Post by SeeJay » Mon Dec 24, 2018 12:22 pm
had this gem from r3 same colour..
Unless the R3 it came from was resprayed,that spoiler will be Sparkling Black (metallic),and not the solid black of your car ;)
It'll be quite noticeable in bright sunlight..
Has thanked: 7604 times
Been thanked: 1877 times
PZ spoiler fitting
Post by GreySilver Beast » Mon Dec 24, 2018 1:10 pm
:whathesaid:
RX-8OC Club Calendar - Gang Bang Car Club - My Website - GSB III 03/08/13 - Present
GT86 T/Days = 53.5 + 31 session's
Total = 64.5 + 38 session's
Cars Driven = 182
Post by mi60o0 » Mon Dec 24, 2018 2:54 pm
Is briliant black as mine been resprayed
BatRex 192 stock
ShuffleFun
Post by ShuffleFun » Wed May 22, 2019 11:14 am
Following Ian's instructions, does anyone have a good suggestion to use instead of the UNI-templates?
I've just bought a PZ spoiler and really don't want to buy a new boot lid because I've mounted this spoiler wonky.
Cheers.
Has thanked: 33 times
Been thanked: 96 times
Post by PaulAV » Wed May 22, 2019 8:58 pm
A blob of toothpaste on the studs will leave a witness on the boot lid, if you mark up the approximate area with masking tape then use the blob of toothpaste method you can then measure from the edges to the witness to make sure its central and in the correct position
ShuffleFun (Thu May 30, 2019 10:42 am)
ShuffleFun
Post by ShuffleFun » Thu May 30, 2019 10:41 am
Cheers Paul. I'm going to be fitting it next week, so I'll give that a go.
Return to “DIY”
