JDM Combe 2019
Saturday 1st June | Castle Combe
Club stand display | Exclusive Club track session | The ever popular drift team displays | Pro driver passenger rides & more
£15 per car (Admits the driver and up to 3 Passengers) | Under 17's go FREE! And do not need a ticket.
Hard wire a go pro hero 5
Has thanked: 61 times
Been thanked: 215 times
Post by mrspiller » Sun Nov 04, 2018 11:12 am
Does anyone know how to do this or is there a long lead on the market which plugs into the cigarette lighter ?
untakenname
Has thanked: 76 times
Been thanked: 93 times
Re: Hard wire a go pro hero 5
Post by untakenname » Sun Nov 04, 2018 11:52 am
You can tap the fuses in the passenger footwell then run the cables up the A-Pillar, do you want it running all the time or just when the ignition is on?
I did a howto a couple of years ago which can be found further down in the DIY section, these days you can get ready made hardwire kits so no soldering required.
A gopro isn't the best form factor for a dashcam as it's quite bulky and noticeable, I took my dashcam apart and fitted it into a Mazda 6 Autodim mirror housing so I can't be seen from inside the car.
I've got a gopro mount mounted in the dome light which captures the steering wheel and the road for trackdays, initially I had it mounted on the ceiling but it was a bit too high so have a 10cm attachment now which lowers it to give a better view of the road.
Post by mrspiller » Sun Nov 04, 2018 12:12 pm
untakenname wrote:You can tap the fuses in the passenger footwell then run the cables up the A-Pillar, do you want it running all the time or just when the ignition is on?
Thanks , I’ll take a look in the DIY section . I do have a question , it is currently fitted to the windscreen . I did have it fitted to the roll cage behind the seats but found the footage wasn’t very good . Basically , the in car footage was ok but the view of the track ahead was really dark , is there a best setting to improve it as I would prefer it fitted to the roll cage
untakenname
Post by untakenname » Sun Nov 04, 2018 7:43 pm
Does the Hero 5 have a HDR setting? If so then enabling it should solve the issues, otherwise changing the white balance and exposure should make the outside a bit brighter, some trial and error may be required as different weather will need different settings.
I changed the exposure on my cheap Yi action cam and made the interior a bit darker to make the outside brighter, sample pic below before I mounted it lower, for best results I think it's better to mount it on the helmet.
Helmet POV
Return to “DIY”
