Starter motors.
Delanor
Has thanked: 6 times
Been thanked: 76 times
Starter motors.
Post by Delanor » Sun Mar 17, 2013 2:47 pm
There are 4 starter motors fitted to the RX-8 denoted by a label on the motor.
N3H1 is the early (03 - 05 years) original 11 tooth motor which turns the engine over at a slower speed.
N3H1-A is the upgraded motor Mazda fitted as a replacement if the owner at the time made a complaint about slow starting.
N3Z1 is the updated more powerful 13 tooth motor fitted (06+ years) by Mazda to overcome the original slow starter motors.
N3R3 is the latest 14 tooth motor as fitted to the R3.
To identify a particular starter motor there should be an ID Tag.
Also see here Starter motors.
Rotary FX fender grills, Japspeed stainless exhaust, K & N filter, Kinetix slotted & dimpled discs, EBC Red stuff pads, DIY AC Delco D585 coil conversion, Magnecor leads, Stainless front & rear grills, HID main beams, LED tail lights, front side lights/front fogs.
