Radio reception
crabacle
Founder Member
Founder Member
Radio reception
Post by crabacle » Sun May 09, 2004 10:45 pm
To check the functioning of the aerial there is a diagnostic mode. Switch IGN and audio on, then press and hold power. Then press preset button two and release both when you hear a beep. The display should then show a reception level (0-10).
Craig
Membership Number 1
Has thanked: 236 times
Been thanked: 857 times
Re: Radio reception
Post by warpc0il » Wed Oct 17, 2012 2:58 pm
If you get noise/interference only when the heated rear window is switched ON, that's a sign that the noise filter has failed.
It's a small box fitted under the parcel shelf, #10 in this diagram.
They're not that expensive new and there should be loads of used ones around, as it's still a fairly rare failure and every car that's been broken had one.
For replacement and testing instructions see[urlw=http://www.rx8ownersclub.co.uk/forum/vi ... 58&t=35629]the Service Materials[/urlw]
under
Workshop Manual
ENTERTAINMENT
NOISE FILTER REMOVAL/INSTALLATION
Rear Window Defroster Noise Filter
see also
NOISE FILTER INSPECTION
