RRP Semi PP engine - one step closer- update 1 March
Engine builds, Modification, Mapping, Products, Online store
Ryan Rotary Performance
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Has thanked: 165 times
Been thanked: 552 times
Post by Ryan Rotary Performance » Thu Feb 06, 2020 8:11 pm
The RRP Semi PP intake engine is getting closer.
Some of you may know that we have been working on this particular engine for a while now along with the Peripheral Exhaust engine we are working on too. We are still going to develop that engine but put it on hold until the intake side is complete.
What is the RRP Semi PP (Peripheral Port) engine?
Well we start with standard power 4 port engine, we use this engine as the base engine as both the exhaust ports and intake ports are smaller allowing us more scope to shape them how we wish to shape them providing the perfect balance between low end torque but while maintaining this as long as possible up the rev range. The 4 Port actually delivers more torque earlier on that the 6 Port, the reason why is due to the size and shape of the Intake and Exhaust Ports.
In addition to this the 6 Port base engine would be seriously complicated to make into what would be an 8 port system. Don’t worry though the RPP Semi PP engine will fit both 192 and 231 cars with just a remap required! 
The two new additional intake ports in the housing are different to the standard Side Ports for which opening and closing times are controlled via the side seals. Peripheral Ports are control via the Apex seal. The result being a Peripheral Port will significantly increase the capacity of the intake system, more air, plus fuel generally equals more power.
How are you controlling port timing?
We are designing a complete new intake system with controllable valves, you’ll retain a fully functional Secondary Shutter Value (SSV) in addition to this the PP will also be controllable via the stock ECU probably activating at the point where the Auxiliary Port Valve (APV) does. What you will lose is the Variable Dynamic Intake (VDI).
We will also incorporate a switch to open the PP at idle which will give some serious braps! Move over Bridge-Port the RRP Semi PP has landed!
Why do this?
Well we hope in NA form that this will achieve significantly more power all the way up the rev range than the current 231 and standard 192, but where the 192 drop off we believe we can hold on and increase the torque of the engine. Top line figures may only marginally be better than a very good full Bridge-Port at 220WHP but the area under the curve should be so much better you will really feel it.
The new intake will also make room for a Top mount turbo which in Side Exhaust form will make 400WHP all day long, swap the Side Exhaust for a Peripheral and you’re talking 500/600WHP for a top mount turbo.
Some pics to enjoy for now:
192 Flange has been probed to give a really good base CAD:
Flange CAD for which the prototype has been ordered for test fitting:
Housing inserts:
These are actually just a screw in fit with an integral O-Ring, so no horrible Cement is used to block off the water gallery.
Last edited by Ryan Rotary Performance on Sun Mar 01, 2020 1:17 pm, edited 2 times in total.
These users thanked the author Ryan Rotary Performance for the post (total 3):
13Black (Thu Feb 06, 2020 8:19 pm) • New Duke (Thu Feb 06, 2020 9:04 pm) • sKenDread (Fri Mar 06, 2020 8:29 am)
Vj4sothername
Has thanked: 457 times
Been thanked: 123 times
Re: RRP Semi PP engine - one step closer
Post by Vj4sothername » Thu Feb 06, 2020 8:15 pm
You know I'm saving for a wedding and buying a house right?
These users thanked the author Vj4sothername for the post:
Ryan Rotary Performance (Thu Feb 06, 2020 8:24 pm)
S1 - 231 - brilliant black
Feb 08 built,
Fake Toyosport back box,
Dents,
Scratches,
Replacement engine,
Smiles
Yorindesarin
Been thanked: 166 times
Post by Yorindesarin » Thu Feb 06, 2020 8:29 pm
Isn't that what a mortgage is for... Just say the house will need doing up... Exta £10k for that... Cough.. Cough..
These users thanked the author Yorindesarin for the post:
Vj4sothername (Thu Feb 06, 2020 8:36 pm)
Honkytonk
Has thanked: 205 times
Been thanked: 389 times
Post by Honkytonk » Fri Feb 07, 2020 7:13 am
"Where's our money for the new kitchen gone?!"
"Braps before Taps"
"WHAT DOES THAT EVEN MEAN"
These users thanked the author Honkytonk for the post (total 5):
Vj4sothername (Fri Feb 07, 2020 8:01 am) • Ainmhidh (Fri Feb 07, 2020 9:20 am) • AdamGaltress (Fri Feb 07, 2020 9:58 am) • geofftl1000r (Fri Feb 07, 2020 3:26 pm) • Craig010 (Thu Mar 05, 2020 9:04 pm)
The P-Shed Project Thread
Yorindesarin
Post by Yorindesarin » Fri Feb 07, 2020 7:43 am
Laughed more than I should've at that.
Secla
RX-8: Nemesis
Colour: Stormy Blue
Post by Secla » Fri Feb 07, 2020 8:06 am
That sounds right up my street 🤔
Dom-PZ
Has thanked: 6 times
Been thanked: 11 times
Post by Dom-PZ » Fri Feb 07, 2020 3:24 pm
*Sensible hat on
Any chance of still passing MOT emissions?
*Sensible hat off, sorry.
Has thanked: 370 times
Been thanked: 1409 times
Post by warpc0il » Fri Feb 07, 2020 5:24 pm
Making good power requires as complete combustion as possible, which also aids emissions.
With a good PCM map and a quality cat, emissions shouldn't be a problem, at least as tested for the MOT ;)
Dom-PZ (Sat Feb 08, 2020 10:58 am)
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Sat Feb 08, 2020 7:31 am
:whathesaid:
These users thanked the author Ryan Rotary Performance for the post (total 2):
Dom-PZ (Sat Feb 08, 2020 10:58 am) • warpc0il (Sat Feb 08, 2020 1:35 pm)
Scotty PZ
Has thanked: 34 times
Been thanked: 25 times
Post by Scotty PZ » Sat Feb 08, 2020 1:14 pm
Well, this is a post worth keeping an eye on.... My bank balance (or wife) is not going to thank you.
Galaxy Grey PZ number 24.
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Sun Mar 01, 2020 1:15 pm
Little update:
Flange prototype has been test fitted and ready for production:
Has thanked: 520 times
Been thanked: 792 times
Re: RRP Semi PP engine - one step closer- update 1 March
Post by 13Black » Sun Mar 01, 2020 1:57 pm
tenor (6).gif (782.81 KiB) Viewed 324 times
Vj4sothername (Tue Mar 03, 2020 9:04 pm)
Goobie
Has thanked: 24 times
Been thanked: 187 times
Post by Goobie » Thu Mar 05, 2020 4:24 pm
Awesome stuff Carl.
Is the rest of the intake part all the way to the throttle body going to be all new design or will it just join up to the top half of the factory inlet plastic section?
Has thanked: 4495 times
Been thanked: 1850 times
Post by ChrisHolmes » Thu Mar 05, 2020 7:51 pm
Lurrrvly
Exedy Stg1 Clutch
Adaptronic ECU
sKenDread
Has thanked: 192 times
Been thanked: 140 times
Post by sKenDread » Fri Mar 06, 2020 8:28 am
Is it possible to peripheral port the exhaust? More air in and out?
Kia-ora!
RRP Performance Ignition Coil System MKII | miniMelon Map | RRP COFS | Powerflow Twin Exhaust
Original engine 80k
V8 Power
Has thanked: 85 times
Been thanked: 256 times
Post by V8 Power » Fri Mar 06, 2020 9:24 am
I think that is RRP’s ultimate goal.
My car is PP’d both inlet and exhaust as a bit of a one off but RRP are making a truly well engineered and repeatable conversion.
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
RRP Coils MSD leads
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Fri Mar 06, 2020 11:18 am
Thats right; so the end goal is Peripheral intake and exhaust, although the peripheral exhaust will be more suited to track NA and turbo conversions. The side exhaust will actually feel and perform better on the road due to the longer power stoke and better thermal efficiency lowering fuel consumption (yes i know we are Rotarys)
These users thanked the author Ryan Rotary Performance for the post (total 4):
sKenDread (Fri Mar 06, 2020 11:39 am) • V8 Power (Fri Mar 06, 2020 11:41 am) • Yorindesarin (Fri Mar 06, 2020 12:52 pm) • Techathy (Fri Mar 06, 2020 1:42 pm)
Return to “Ryan Rotary Performance”
