RRP Performance Coil system MKII
Engine builds, Modification, Mapping, Products, Online store
Delanor
Has thanked: 13 times
Been thanked: 76 times
Re: RRP Performance Coil system MKII - website review now active
Post by Delanor » Wed Dec 05, 2018 4:42 pm
Unless you fabricated an mounting plate and coil bracketry out of Titanium like someone did. :whistle:
geofftl1000r
Colour: Metropolitan Grey
Has thanked: 91 times
Been thanked: 71 times
Post by geofftl1000r » Wed Dec 05, 2018 4:44 pm
Thanks all. The car came with the d585 already fitted so I am not sure what has been changed.
I think I'd better get a 'mini map done to be on the safe side.
40th Anniversary RX8
D585 Coils
R3 Wheels
RRP COFS
RRP Blue Pulleys
Paulie
Has thanked: 8 times
Post by Paulie » Wed Dec 05, 2018 8:29 pm
Got my Coils/leads and COFS yesterday. Thanks! I already have a set of new plugs on the shelf..... another thing I need to do is try out my new compression tester, I was thinking why not try a few before and after compression tests just for the hell of it. Whats the hypothesis on my compression resultsi?
Has thanked: 373 times
Been thanked: 1417 times
Post by warpc0il » Wed Dec 05, 2018 8:38 pm
:-k The square of the hypothesis is equal to.... #-o
RobinPZ72
Has thanked: 67 times
Been thanked: 32 times
Post by RobinPZ72 » Thu Dec 06, 2018 8:41 am
GOOGLE
Delanor
Post by Delanor » Fri Dec 07, 2018 12:28 pm
Has anyone successfully changed Magnecor plug connectors/terminals as I have a set of nearly new leads to fit D585 coils and I have to change the coils to RR MK2 coils so rather than buy another set of Magnecors I might try and change coil caps to suit the new coils.
Anyone?
Been thanked: 785 times
Post by PeteH » Fri Dec 07, 2018 2:17 pm
I believe coil and plug caps usually just screw on. Can't be certain though.
Culdranth
Has thanked: 35 times
Been thanked: 8 times
Post by Culdranth » Fri Dec 07, 2018 3:33 pm
Fitted coils today and went for a quick 2 mile drive, too much traffic and raining to test properly but I "feel" a difference already. I was using fake coils previously. Will get a few miles on and do a review on website :)
These users thanked the author Culdranth for the post:
Ryan Rotary Performance (Fri Dec 07, 2018 8:06 pm)
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Has thanked: 167 times
Been thanked: 558 times
Post by Ryan Rotary Performance » Sat Dec 08, 2018 5:25 pm
How the kits looks on bracket with the MSDs, call me biased but that is one great looking kit!
Post by warpc0il » Sat Dec 08, 2018 6:37 pm
Do you ever get that desire for something to got wrong with your car, just so you can fix it?
My BHR coil kit is still working well after 10 years - so far... ;)
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Sat Dec 08, 2018 6:52 pm
Can't be long now ;)
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Tue Dec 11, 2018 9:27 am
Just a bump guys, would be great to get some more install pics and initial feedback, remember these can also be reviewed on the website now too.
Culdranth
Post by Culdranth » Tue Dec 11, 2018 11:23 am
Not had chance to give the car some decent miles yet but ill make sure ill post a review when ready :thumleft:
Salokin
Has thanked: 119 times
Been thanked: 91 times
Post by Salokin » Tue Dec 11, 2018 8:16 pm
I'll will write up a review once fitted .
Regarding fitting... maybe a silly question, but, can I use the guide on fitting the 585's for fitting these and alter as necessary. I assume there are no huge differences? Thanks
Sent from my VTR-L09 using Tapatalk
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Wed Dec 12, 2018 9:12 am
I'll will write up a review once fitted Image.
Regarding fitting... maybe a silly question, but, can I use the guide on fitting the 585's for fitting these and alter as necessary. I assume there are no huge differences? Thanks Image
There's not a huge difference in the fitting/installation of these compared to the D585's, these are easier to install.
there is a You Tube video here of ER fitting the BHR system which you could loosely follow:
I will do my own instructions at some point, but that doesn't help you all now.
Basic steps are:
1. disconnect the Battery
2. Get access by pushing back the air box and disconnecting at the throttle body.
3. Remove old coils by undoing single retaining bolt and unplugging the harness and ignition leads. (may be an idea to label where goes where)
4. install new coils.
5. Reconnect air box and battery.
These users thanked the author Ryan Rotary Performance for the post:
Salokin (Wed Dec 12, 2018 8:18 pm)
AutoGibbon
Has thanked: 29 times
Been thanked: 25 times
Post by AutoGibbon » Wed Dec 12, 2018 1:04 pm
Thanks lots for uploading that diagram! Will come in handy for hooking it up (which I plan to do this weekend, followed by some rigorous brapping for science).
Andrew.
09' R3, Sparkling Black ~ RRP Stainless 3" cat + catback ~ RRP Lightweight Pulleys ~ RRP MKII ignition coils & MSD 8.5mm leads
Instagramelonalam: @autogibbon
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Wed Dec 12, 2018 1:44 pm
You need to update your signature: The RRP MKII are ready and available :thumright:
AutoGibbon (Thu Dec 13, 2018 5:42 pm)
Salokin
Post by Salokin » Wed Dec 12, 2018 8:19 pm
Basic steps are:
This is really helpful thank you Image Image.
Rostyghost
Been thanked: 10 times
Post by Rostyghost » Fri Dec 14, 2018 5:49 pm
I wonder if these coils have the same properties as D585 ones (like improved bhp, life and fuel economy) or they are just a more reliable alternative to OEM coils?
Current: 2010 Black Abarth 500 Esseesse; Sabelt Seats, EBC Brakes; Ulter stainless steel exhaust; BMC air intake.
Ex: 2004 Velocity Red S1; RRP Coil Pack & MSD Leads, Mishimoto oil catch can & magnetic drain plug, Cobra rear exhaust; Motul 6100 + Motul 710; Autobot Drift figure on the dashboard 8)
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Fri Dec 14, 2018 6:17 pm
At standard dwell they'll out perform almost anything in the market including D585s,
If you read the full thread you'll see thst most D585 coils output 73mj of spark energy (after a remap) these will output 96mj of spark energy at standard dwell.
Guys are even selling D585s and upgrading to these coils, you won't go wrong here mate they are a well thought out system
PJ_Parsons
Post by PJ_Parsons » Sun Dec 16, 2018 1:46 pm
Got my MKII coils through this week and fitted them, along with the Magnecor leads and standard plugs. The coils were easy to fit by partially removing the air box. It was just a matter of unbolting the old coils and disconnecting the connectors. This is a bit fiddly and not for the ham phisted. The RRP coils fitted easily and the leads went on no problem. Exactly as I hoped. The car started without trouble and I took it for a 30 minute drive. The difference compared to the old ignition system was night and day. The car is much more eager. Of course, this is in part due to the RRP system being new. Even so, for value, ease of fitting, if you looking to replace coils and leads I would buy the RRP system again. We’ll see how the coils last over time but, so far I’m very happy.
These users thanked the author PJ_Parsons for the post:
willberry70 (Sun Dec 16, 2018 5:57 pm)
willberry70
RX-8: Kuro
Has thanked: 474 times
Been thanked: 107 times
Post by willberry70 » Sun Dec 16, 2018 6:06 pm
Just got my new coils fitted (mostly thanks to Rob, and it was pretty fiddly}, and they're amazing!
Rock solid robustness, starts in under 1s rather than the asmatic 3-4 I had, and seeing a 2mpg improvement. Haven't been able to try the 0-60 time yet but it feels more eager low down and high up, so we'll see 😁
Will post review on the website.
Sparkling Black Kuro SN# 400/500. Green LEDs on door and puddle lamps. LEDs on interior lamps. EBC fronts disks. Uprated battery. Greyed alloys. K&C air filter. RRP Mk2 Coils and MSD Leads.
SeeJay
Has thanked: 168 times
Been thanked: 360 times
Post by SeeJay » Sun Dec 16, 2018 7:58 pm
Looking at these on Ryan's website,and it says R3's need to have a bit chopped off in order to fit.. so not a direct bolt-on replacement,then :scratch:
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Sun Dec 16, 2018 8:52 pm
Its just two spigots on the bracket, literally 5mins with a dremel. But point taken
I've some R3/S2 brackets without these spigots, the one sent from Greece to me didn't have any, apologise for any inconvenience this has caused anyone
ChrisHolmes (Sun Dec 16, 2018 9:04 pm)
SeeJay
Post by SeeJay » Sun Dec 16, 2018 9:08 pm
Seriously considering treating the R3 to a set of these in the new year..would you be willing to throw in one of those brackets as part of the deal :?:
Return to “Ryan Rotary Performance”
