New product - oil reservoir/catch can
Engine builds, Modification, Mapping, Products, Online store
Ryan Rotary Performance
Forum Trader
Forum Trader
RX-8: Supercharged
Has thanked: 63 times
Been thanked: 189 times
Post by Ryan Rotary Performance » Sun Mar 05, 2017 8:28 pm
Thoughts on our new rotary themed oil catch can or oil reservoir for the omp adapter?
Can be anodised black, red or blue and configured to suit either application.
Oil Header Tank v3.jpg (20.47 KiB) Viewed 617 times
Dazza44
Has thanked: 148 times
Been thanked: 116 times
Re: New product - oil reservoir/catch can
Post by Dazza44 » Mon Mar 06, 2017 9:01 am
Hi there looks good forgive my lack of knowledge what would be the holding capacity of this unit
Thanks darren
Forum Trader
Forum Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Mon Mar 06, 2017 9:20 am
Would roughly be 0.6-0.8L but we need to firm up the details etc.
Either way thata plenty enough capacity for a catch can or oil for the OMP adapter
SeriousSam
Has thanked: 30 times
Been thanked: 206 times
Post by SeriousSam » Mon Mar 06, 2017 10:31 am
Is it going to be a baffled unit? I think I've seen people who've reported non-baffled catch cans having large oil burps that still make it through to the intake.
Forum Trader
Forum Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Mon Mar 06, 2017 12:32 pm
Hi Sam
It was nice to meet you and your other half at the AGM :)
Yes will have a baffle plate - I also have heard of un baffled units still pulling through to the intake :)
SeriousSam
Post by SeriousSam » Mon Mar 06, 2017 1:09 pm
Likewise Carl, good to see you there. This looks like a nice product, might well keep an eye on it :)
Scartlead
Has thanked: 56 times
Been thanked: 58 times
Post by Scartlead » Mon Mar 06, 2017 1:46 pm
Waiting on the sohn from you Carl, so will keep tabs on this as currently Ive no tank for the 2 stroke
Aka Mark 8)
My Build :thumleft: viewtopic.php?f=204&t=70916
Forum Trader
Forum Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Mon Mar 06, 2017 4:21 pm
Scartlead wrote:Waiting on the sohn from you Carl, so will keep tabs on this as currently Ive no tank for the 2 stroke
The OMP adapter is next on the list mate just got to get the engine mounts done, then its the OMP adapter, then this tank solution and finally the lightweight pulleys :)
I think I have too many projects on the go! :-k
Scartlead
Post by Scartlead » Mon Mar 06, 2017 4:57 pm
See what happens when you're making so many shiney things :mrgreen: :thumright:
Aka Mark 8)
Velocity_Dan93
Has thanked: 18 times
Been thanked: 42 times
Post by Velocity_Dan93 » Mon Mar 06, 2017 5:26 pm
Looks great mate ! If I didn't already have one I'd be all over this ;)
VR Mazdaspeed with lambo doors yo!
RR rebuild with full bridge and lightweight rotors.
CC ultra lightweight flywheel, pettit flywheel nut and lightweight underdrive pulleys.
AEM intake, full RB exhaust system, custom SOHN and catch can, greddy sump, Mishimoto cooling system and oil lines. Brap
HwAoRrDk
Has thanked: 8 times
Been thanked: 38 times
Post by HwAoRrDk » Mon Mar 06, 2017 7:09 pm
Where will the inlet and outlet be when used as a catch can? And where will the outlet be if it's used as a 2T reservoir? I suppose you could have a port on the bottom which would serve as outlet for reservoir use and as a drain plug for catch can use. It looks like it's a two piece design, with the top separate from the rest, so I suppose you could do two different styles of top piece - one with two ports for a catch can, and one with a filler cap for 2T reservoir (as shown). :-k
How's this thing going to be mounted?
Speed-sensitive windscreen wipers upgrade
Forum Trader
Forum Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Mon Mar 06, 2017 9:32 pm
Good questions!
So that design is based on the oil reservoir for the OMP adapter, will try and incorporate a low level sensor at the bottom and dipstick into the screw cap (we will see). I think those straw like level sights will ruin the astetics a little so trying to avoid those. Also there will be vented cap as to not cause a vacuum when drawing oil.
As for the catch version there will be no scew cap, an inlet and outlet near the top of the can with a baffle plate, possibly a double baffle plate incorporated inside with a drain plug at the bottom.
Eventually I'm going to offer a three piece design to replace the washer bottle but for now these will come with their own mounting brackets.
Return to “Ryan Rotary Performance”
