New Cooling Upgrades - Series 1 only
Engine builds, Modification, Mapping, Products, Online store
Ryan Rotary Performance
Sponsor Trader
Sponsor Trader
Has thanked: 165 times
Been thanked: 552 times
Post by Ryan Rotary Performance » Wed Oct 23, 2019 12:57 pm
Website Links and blurb:
https://www.ryanrotaryperformance.com/s ... ng-upgrade - £180 kit
https://www.ryanrotaryperformance.com/s ... ng-upgrade - £300 Kit
https://www.ryanrotaryperformance.com/s ... ng-upgrade - £330 Kit
Rx8 Series 1 (2003-2008) – Ultimate Cooling upgrade
We have modified the Series 2 Water Pump which has a much improved Impeller design to fit the Series 1 Rx8. Say goodbye to the inefficient impeller design of the Series 1 Water Pump which has not been updated since the Rx7, and say hello to the new Water Pump Cooling Upgrade.
Benefits:
Reduced Engine Temperatures for Fast Road or Track use
More efficient impeller, reduces cavitation, increases cooling over a wider Rpm range.
Custom pulley which now under drives the Water-Pump without under driving the rest of the ancillaries.
More Power to the wheels, reducing pumping losses.
Availalbe in 3 sets:
Modified Water Pump, Gasket and Custom Plain Pulley – £180
Modified Water Pump, paired with Racing pulley kit. – £300
Modified Water Pump, paired with 4 piece Pulley kit. – £330
Last edited by Ryan Rotary Performance on Fri Oct 25, 2019 2:03 pm, edited 1 time in total.
These users thanked the author Ryan Rotary Performance for the post (total 2):
PeteH (Wed Oct 23, 2019 2:20 pm) • leeroy69 (Wed Oct 23, 2019 8:29 pm)
Paul_13
Has thanked: 67 times
Been thanked: 93 times
Re: New Cooling Upgrades - Series 1 only
Post by Paul_13 » Wed Oct 23, 2019 1:26 pm
Why do you supply a gasket when the R3 has a built in gasket?
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Wed Oct 23, 2019 3:59 pm
different bolt pattern
Has thanked: 80 times
Been thanked: 95 times
Post by Scartlead » Sun Mar 22, 2020 9:31 am
Hey Carl, is the pump compatible with the pulley set I bought from you? ie can I buy the pump on its own without the pulley if it is ?
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Mon Mar 23, 2020 7:04 pm
You'll need the S2 pulley and waterpump for this mod.
Velocity_Dan93
Has thanked: 27 times
Been thanked: 57 times
Post by Velocity_Dan93 » Tue Mar 24, 2020 1:14 am
Do you have any temperature readings for comparison with or without this kit on cars stock of modified? Just interested to see the difference
VR bridge port Mazdaspeed with lambo doors yo!
GG bridge port track missile
Phantom stock engine impulse buy #-o
Post by Scartlead » Tue Mar 24, 2020 6:20 pm
Thanks, does the belt need replaced?
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Fri Mar 27, 2020 6:39 pm
Yes you can use the same belts. :)
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Fri Mar 27, 2020 6:48 pm
Hi Dan
When Ed Stracey did some testing for me ( I gave him one FOC) he noticed a significant improvement in his temps, cruising it was floating at the thermostat around 82-85 and at WOT he noticed that temps being more stable and less prone to spiking and then returning to normal faster so all in all a great improvement!
From memory you bought his car and so should have one?
These users thanked the author Ryan Rotary Performance for the post:
Velocity_Dan93 (Fri Mar 27, 2020 7:22 pm)
Velocity_Dan93
Post by Velocity_Dan93 » Fri Mar 27, 2020 7:23 pm
Hi Dan
I do indeed but don't have any temp logging on it :P just wondering if you had any details to hand save me starting a study into it ! cheers !
Return to “Ryan Rotary Performance”
