Rx8 Plug and Play Peripheral engine - Now Landed!!
Engine builds, Modification, Mapping, Products, Online store
Harris-5310
Has thanked: 15 times
Been thanked: 47 times
Re: Rx8 Plug and Play Peripheral engine - Now Landed!!
Post by Harris-5310 » Sun Jan 07, 2018 5:59 pm
Sounds amazing
2004 winning blue 231 gone but not forgotten
Now own a 2003 Audi TT 225 quattro
Has thanked: 1933 times
Been thanked: 640 times
Post by ChrisHolmes » Sun Jan 07, 2018 6:05 pm
ooooooooooohhhh! Sweet
Toyo SS Catback
SS Strakes
Custom Sat Nav 3 Gauge install
Meister Zeta R Coilovers
Whiteline ARBs F&R
Slotted & Dimpled Discs F&R
Mintex 1144 Pads F&R
Full OE Aero Kit
Revolution Alloy Front Strut Brace
Lockwood SS Grills
Passenger Footrest
Lambo doors
Original engine 86000 smiles (169.7 rwhp) and then it died!
Own build Steet ported engine fitted Feb 2018 and running sweet as nut
Has thanked: 47 times
Been thanked: 51 times
Post by Scartlead » Sun Jan 07, 2018 6:14 pm
Holy Moly !!! Epic !
Has thanked: 155 times
Been thanked: 579 times
Post by PeteH » Sun Jan 07, 2018 6:17 pm
Got to agree, that's a proper "Racing rotary" noise. Well done Carl :thumleft: :thumleft:
SAS
Been thanked: 18 times
Post by SAS » Sun Jan 07, 2018 6:28 pm
Well done guys, sound amazing :thumleft: :thumleft:
Supercharged :thumleft:
Ryan Rotary Performance
Forum Trader
Forum Trader
Has thanked: 50 times
Been thanked: 116 times
Post by Ryan Rotary Performance » Sun Jan 07, 2018 7:09 pm
thank you guys, still early days but it's promising so far if all goes well we will be doing an all aluminium engine next but that is going to be ££££
Has thanked: 6 times
Been thanked: 79 times
Post by V8 Power » Sun Jan 07, 2018 7:12 pm
When have you planned to do a rolling road run?
231 track day Hayward custom built exhaust Carbon seats Sabelt 6 point harnesses Cone filter cold air feed Tein Monosport coilovers Lexan front windows Carbon Adjustable rear wing catch can Feed gearknob Hayward Peripheral port engine Axial short shift OMP suede wheel RE Amemiya front splitter & canards Autec lightweight alloys Whiteline ARB's Aurora blue R3
Forum Trader
Forum Trader
Post by Ryan Rotary Performance » Sun Jan 07, 2018 7:16 pm
hopefully next month
we also have to get it through an MOT which is why we went for this short exhaust which is a bit restrictive due to the collector rather than a tuned length exhaust with a larger collector. but that's to come.
Forum Trader
Forum Trader
Post by Ryan Rotary Performance » Tue Jan 09, 2018 8:44 pm
Been getting lots enquiries of costs for this so thought I would put some indicative costs together :)
So the basic package will start from roughly, £5000.00
This will include the following;
- Re-manufactured and re-nitrided irons with the side ports blocked up.
- Brand new housings Rx7 housings machined to the fit the Rx8 block.
- Re-manufactured RH side engine mounting to accommodate new exhaust system.
- RRP Base map
- Fully rebuild engine including the following parts replaced as standard:
6 x OEM Apex Seals
12 x OEM Apex Springs
12 x OEM Sideseals
12 x OEM Sideseal Springs
12 x Two Piece OEM Corner Seals
12 x OEM Corner Springs
12 x Rotor Inner, Outer, Scrapper Springs
2 x OEM Needle bearings
1 X Pilot Bearing
2 X OEM Stationary Bearings
2 X Bearing Retaining Screws
2 X OEM Rotor Bearings
1 X Up rated oil pressure regulator (95PSI)
All seals and gaskets will be replaced with new.
Options will be as follows:
Extended Street Port ​Engine +£250
Half Bridge Port Engine +£400 (will require Goopy Apex seals)
Full Bridge Port Engine +£550 (will require Goopy Apex seals)
Exhaust Porting +£150
Lower Intake Porting ​ +£125
Engine balancing +£300
Engine Painting From £60
3 X Oil Injector modification +£300
Goopy Apex seals +£80
Rotors machined to accept Rx7 seals (Roughly) £300 - ideal for FI
Exhaust Options
- Standard Exhaust 2.5 Inch compatible with current systems £550
- Tuned length exhaust 3 Inch with V bands - £POA expected to be roughly £1000
MightyCondor
Has thanked: 43 times
Been thanked: 62 times
Post by MightyCondor » Wed Jan 31, 2018 10:56 pm
Something similar from the States. Certainly has potential :thumleft:
2004 Sunlight Silver 231 Impulsive Panic Buy Rotary Shed & lesser seen RX-7 FD3s
2005 Winning Blue 231 - Loved and set free (sold) :(
2004 Winning Blue 231 - Lost at the hands of a careless BMW driver
Post by V8 Power » Mon Feb 12, 2018 6:16 pm
Any further update on when the dyno run will be?
Post by V8 Power » Thu Feb 22, 2018 10:25 pm
Any update?
I presume you have it booked in for a RR session?
Post by V8 Power » Thu Mar 15, 2018 11:33 pm
Any update?
Forum Trader
Forum Trader
Post by Ryan Rotary Performance » Fri Mar 16, 2018 6:18 pm
Any update?
We had an issue with the middle plate, basically the engineering company didn't machine it parallel! So we have come up with a new manufacturing process the plate is pretty much ready and as soon as it is it'll be back together.
On the plus side all else worked as we first thought and the blocked ports held up great!
Shouldn't be long a month maybe and it'll be back on the roads
Forum Trader
Forum Trader
Post by Ryan Rotary Performance » Fri Mar 16, 2018 6:23 pm
Second time lucky.
Post by V8 Power » Sun Mar 18, 2018 10:41 am
It is not surprising with something as radical as this that there are a few hiccups along the way.
Great progress though and looking forward to the finished engine and power results.
You never know I might even get my car back soon for a comparison.
Return to “Ryan Rotary Performance”
