A guideline on Quoting posts
Please read this for information and guides on how to use the forum, and view our house rules.
Locked
RX-8 Owners Club
RX-8 Owners Club UK
RX-8 Owners Club UK
Post by RX-8 Owners Club » Sun May 01, 2011 7:31 pm
How to use the quoting function
Some people are well versed in this, and some tend to do it even when unnecessary, e.g. quoting the last post, when it is just above where they're typing. If it's the previous post, just above, then there's no need to quote it, the topic will flow better without.
Copy and paste instead of quoting is not an adequate alternative, unless you're simply copying a word or two. By not using the quote function, any formatting intended by the original poster will be lost; colours, images, smileys, font sizes etc.
When pressing the Image button the system will take you to a new screen.
This will include the full text of the post you are quoting. Now includes post_id, user_id, date & time, and a link to take you back to the original post.
Quoting the full post
If you want to keep all of the quoted post then no need to do anything, just add your comments underneath.
Quoting part of the post
Remove the text you don't want to quote. But remember, in order for the quote to work you must leave in the quote tags. These look like [ quote = "some-code-stuff" ] and end in [ / quote ]
Adding to a previous post
If you want to add something to the previous post by quoting, usually a list of names etc. then quote the above post, and remove the two quote tags as shown above. Add what you need to and post. This will post the text without the quoting and make it look like it is your own post and not a quote.
So the result looks like this:
RX-8 Owners Club wrote:
Fri Jan 28, 2011 5:47 pm
There are a couple of ways to link to external websites or other threads/posts in the forum...
Reason: Updated
Has thanked: 456 times
Been thanked: 1828 times
Re: A guideline on Quoting posts
Post by warpc0il » Thu Jun 29, 2017 11:53 pm
Advanced Quoting
If you want to quote a series of questions and place your answers in between then start as above and then copy the {quote="OP"} and {/quote} tags to the beginning and end of each question, then type your answers in between.
This sounds more complicated than it is, so here's an example..
Code: Select all
[quote="OP"]Question 1[/quote]
answer 1
[quote="OP"]Question2[/quote]
answer 2
[quote="OP"]Question 3[/quote]
answer 3
OP wrote:Question 1
answer 1
OP wrote:Question2
answer 2
OP wrote:Question 3
answer 3
You can also use the quote tags to quote text from other sources, e.g.
Code: Select all
The Seller wrote
[quote]This is the best thing since sliced bread[/quote]
or better still
Code: Select all
[quote="The Seller"]This is the best thing since sliced bread[/quote]
The Seller wrote:This is the best thing since sliced bread
Note that I typed ="The Seller" into the first tag.
I used curly brackets in the opening statement to stop the parser trying to action the {quote="OP"} and {/quote} tags, you of course will use square brackets.
Locked
Return to “Forum Guide - Read First”
