JDM 2023 - Castle Combe - Saturday 8th July **CLOSED OFF**
Past events that the Club & Members have attended. Read-only.
Mattzdaspeed
Has thanked: 9 times
Been thanked: 9 times
Re: JDM 2023 - Castle Combe - Saturday 8th July **CLOSED OFF**
Post by Mattzdaspeed »
rotatopotato wrote:
Mon Jul 10, 2023 11:10 pm
Awesome day, despite the weather. I couldn't have been happier with how the car performed, it is on rails and waiting for my ability to catch up and take full advantage - I slowly figured out that I didn't need to worry too much about traction in the wet as it had plenty and putting the hammer down just tended to make it grip more 😁
In saying that, I have ordered a set of Racing Beat ARBs to reduce that body roll 😂
Hopefully I'll see some of you at another day later in the year, I'm hoping to get out of Scotland for one more this year (possibly Snetterton). In the meantime, Knockhill has me covered...
On the way home in the torrential downpour on the M6, it must have sucked in some water (I've got an AEM), as it wobbled and misfired before throwing a code and not revving above 4.5k(ish), but then continued to cruise while I decided what to do - eventually I realised it was still running fine so cruised to the next services and shut it down for a bit. One lengthy start later and it was back to life again, codes cleared by me (misfire as expected), at first it didn't want to rev above 7k so I left it alone, just giving the odd run up to 7 until I'd been driving a bit, then it was business as usual with beeps being no problem. I thought I'd gone into limp mode earlier but I'm guessing it was something like water still in the intake or sitting in the filter, which slowly dried out/got sucked into the engine in manageable quantities, hence it not wanting to rev much at all after throwing the code, with the rev "limit" rising as everything dried out. No issues with starting it later in the evening when filling up near home either. So counting myself lucky there - it was biblical levels of water on the road, and I didn't even consider the AEM 😬
Do you have the "sock" that goes over the filter? I've had mine fitted on all the ones I've had and never had the same water ingress issues!
Matt
Proud owner of my 5th 6th RX8... “Just when I thought I was out, they pull me back in!”
Mazdaspeed S1 - MS04 RXB Project Thread
rotatopotato
Has thanked: 590 times
Been thanked: 366 times
Post by rotatopotato »
I do - I even replaced it with a fresh one last year. That probably helped make it only a minor hiccup.
Mattzdaspeed (Wed Jul 12, 2023 9:31 am)
Mattzdaspeed
Meant to say, I saw you flying round the track in the early morning session and the car looks/sounds awesome 😎
Matt
rotatopotato
Thanks! I'm really pleased with how it has come together 😁
Yours looks awesome too with all the mazdaspeed bits!
Mattzdaspeed (Wed Jul 12, 2023 11:03 am)
Mattzdaspeed
Ah, thanks man! I'll make sure to actually say hello properly next time :thumleft:
These users thanked the author Mattzdaspeed for the post:
rotatopotato (Wed Jul 12, 2023 11:53 am)
Matt
dw_arnie
Post by dw_arnie »
Return to “The Vault”
