Forge Action Day 2019
Saturday 7th September | Castle Combe
Club stand display | Exclusive Club track session | The ever popular drift team displays | Show and Shine competitions & more
£15 per car (Admits the driver and up to 3 Passengers) | Under 17's go FREE! And do not need a ticket.
Dyno Day Horsham Developments **21/10**
Past events that the Club & Members have attended. Read-only.
rameshr
Been thanked: 43 times
Re: Dyno Day Horsham Developments **21/10**
Post by rameshr » Mon Oct 22, 2018 6:46 pm
Can u recommend coil tester? I doubt it’s my 969, but worth checking
AEM Intake
D969 Coils
Tein S springs
Dwell timers adjusted
Short Shifter
Braided Brake + Clutch Lines
Has thanked: 557 times
Been thanked: 823 times
Post by 13Black » Mon Oct 22, 2018 6:49 pm
The tapered red light-up testers that sit inline between plug and lead can identify poorly working coils.
rameshr
Post by rameshr » Mon Oct 22, 2018 7:05 pm
13Black wrote:The tapered red light-up testers that sit inline between plug and lead can identify poorly working coils.
Do u have a link or code?
AEM Intake
D969 Coils
Tein S springs
Short Shifter
Has thanked: 3463 times
Been thanked: 1305 times
Post by ChrisHolmes » Mon Oct 22, 2018 7:38 pm
PeteH wrote:
Mon Oct 22, 2018 1:26 pm
Pump up your tyres by 10psi Chris. It will "add" about 2bhp on a rolling road dyno. Then you'll be the winner. :thumleft:
(Did you all check your pressures before going on the dyno?)
Err no. That's a neat little trick which makes sense, stiff tyres = less rolling resistance!
Racing Brake Custom front bumper, grills & Side Skirts
CAMP ll Display
Eddie_r32
Has thanked: 38 times
Been thanked: 120 times
Post by Eddie_r32 » Mon Oct 22, 2018 9:21 pm
These are the puppies:
Laser 2780 Ht Lead Ignition Spark Tester
Well worth investing
2007 Galaxy grey 231 with full RRP bridge.
rameshr
Post by rameshr » Mon Oct 22, 2018 9:48 pm
will get this, so I connect this up the start the engine and make sure they all light up?
AEM Intake
D969 Coils
Tein S springs
Short Shifter
Eddie_r32
Post by Eddie_r32 » Mon Oct 22, 2018 10:00 pm
Yup, they made narrowing down my issue super easy, also make sure they are light up brightly
Has thanked: 267 times
Been thanked: 994 times
Post by warpc0il » Tue Oct 23, 2018 12:51 pm
Next time someone is repeating this process I'd love to see if there's any benefit in removing the "room fuse".
Various credible sources suggest that this puts the PCM into a higher output mode but the logic is never explained.
Post by 13Black » Tue Oct 23, 2018 1:14 pm
Removing the room fuse should reset fuel trims.
I recall reading somewhere that racers used to do it before heading out of the pits - as the cars almost always have a positive fuel trim, this'll cause them to run a little leaner (/not end up rich as a pig from extrapolating the trim up top and massively over compensating).
How legit that is, I can't be sure.
Juey
RX-8: Import
Colour: Black Cherry
Has thanked: 18 times
Been thanked: 80 times
Post by Juey » Thu Oct 25, 2018 5:30 pm
No 192's on the day? :-k
Black Cherry Mica
I do not spook easily and those who think I do are wasting their time with their surprise attacks.
Women feel comfortable in my presence, with my tales of sexual experimentation both on the high seas and on railway property.
I am a wizard with star shaped Chinese weaponry, which I throw accurately and without due for-thought.
rameshr
Post by rameshr » Fri Oct 26, 2018 7:41 am
Nope none
AEM Intake
D969 Coils
Tein S springs
Short Shifter
geofftl1000r
Colour: Metropolitan Grey
Has thanked: 51 times
Been thanked: 41 times
Post by geofftl1000r » Sat Oct 27, 2018 1:18 pm
Hi all. Anyone mysteriously gained an engine cover? Just been out to the car to check oil etc and noticed I have no engine cover.
Called Horsham Developments but only got voicemail.
Cheers
Geoff
40th Anniversary RX8
D585 Coils
R3 Wheels
RRP COFS
RRP Blue Pulleys
Post by ChrisHolmes » Sat Oct 27, 2018 2:12 pm
I remember them coming into the viewing area with a cover so it may have been yours
CAMP ll Display
Eddie_r32
Post by Eddie_r32 » Sat Oct 27, 2018 3:45 pm
Jez thinks only Ramesh's was removed but will look on monday
Has thanked: 62 times
Been thanked: 254 times
Post by qwakers » Sat Oct 27, 2018 3:53 pm
igf you cant find it you can have my spare if you cover the postage
now proudly sponsored by RyanRotaryPerformance :mrgreen:
https://www.ryanrotaryperformance.com/
geofftl1000r
Post by geofftl1000r » Sat Oct 27, 2018 4:39 pm
Sorry all, had a senior moment. I hadn't put it back on after doing the COFS install the weekend before. Found it amongst all the mess and tools.
Thanks all for responding.
These users thanked the author geofftl1000r for the post:
ChrisHolmes (Sat Oct 27, 2018 5:27 pm)
D585 Coils
R3 Wheels
RRP COFS
RRP Blue Pulleys
rameshr
Post by rameshr » Sun Oct 28, 2018 12:09 pm
Front Image
Rear
Sparks need changing too:(
I think I have a year before a rebuild
AEM Intake
D969 Coils
Tein S springs
Short Shifter
Lemon
Has thanked: 23 times
Been thanked: 138 times
Post by Lemon » Sun Oct 28, 2018 3:02 pm
Looks like a side seal may have gone then...
Who did the compression test?
Thanks, Stu
Post by 13Black » Sun Oct 28, 2018 3:08 pm
Looks like an MRS jobbie.
But yis, side seal very worn, stuck, or at an unlikely worst; cracked :(
rameshr
Post by rameshr » Sun Oct 28, 2018 3:47 pm
Luke from MRS, he mentioned the same. Still runs strong so I think I will be okay. Only using it for track so max 4K miles next year
AEM Intake
D969 Coils
Tein S springs
Short Shifter
Post by 13Black » Sun Oct 28, 2018 10:40 pm
Piccies and piccies and piccies.
Got somewhat interested in what might be a typical adjustmelon figure from a typical normal RX-8's BHP figure from Horsham's dyno, to MAP's WHP figures on their hub dyno.
Taken standard-ish cars, transmission loss fudge factor adjusted where necessary, average power/torque figures at each rpm on each dyno... fudge factor created.
Adjust Horsham data, append to Dyno Might data. Voila! As if we all went to the MAP event last year.... sort of, but not really, but kinda sorta, in a way, probably. So don't get hung up on the comparison too much.
Post by 13Black » Sun Oct 28, 2018 10:53 pm
However, because that is a little crowded, here is the Horsham-only version with a few more erroneous plots removed and (in the WHP graph) zoomed into the spicey end, which is what y'all really care about :D
Post by 13Black » Sun Oct 28, 2018 11:21 pm
And for those who are more comfortable with Horsham's figures and scaling, here are the 'accurate' plots collected.
Note mister Holmes that you're making bags of torque in the mid range, it's only at the very end that it drops off compared to monsieur Lémon and his BHP overtakes yours momentarily.
It was similar when Gene compared my plot to one of their street ports - theirs made more peak HP due to holding onto the torque for longer, but mine had better low-to-mid range.
ChrisHolmes (Sun Oct 28, 2018 11:51 pm)
Post by warpc0il » Sun Oct 28, 2018 11:28 pm
This shows the difference between drivability and maximising power.
Even on the track I'd choose drivability every time, and for the road it's a no-brainer.
Post by 13Black » Mon Oct 29, 2018 12:38 am
Peak HP doesn't melt steel beams and all that jazz :thumright:
And not to pish on anyone else's chips but although TerryH's wonder-engine topped the peak leader board, look at the area that's missing under the graph compared to Stu and Chris. Guaranteed their cars would be quicker in any situation.
Return to “The Vault”
