JDM Castle Combe Sat 2nd June 2018
Past events that the Club & Members have attended. Read-only.
Has thanked: 2934 times
Been thanked: 1080 times
Re: JDM Castle Combe Sat 2nd June 2018
Post by ChrisHolmes » Mon Jun 04, 2018 8:28 pm
SeanP wrote:
Mon Jun 04, 2018 9:45 am
ChrisHolmes wrote:
Sat Jun 02, 2018 7:35 pm
Whilst clearing up we found a black hoody L size where the octagonal gazebo was and also a vacuum tester pump kit in a red box. If these are yours please let me know and I will get them back to you somehow.
Vacuum tester (actually a brake bleeder) is mine. Despite double checking I knew I’d forget something! Need to tidy up my car kit packing!
I will take your bleeding lost property to Tunerfest Brands on the 24th.
Supercharged and highly customised
Has thanked: 30 times
Been thanked: 173 times
Post by qwakers » Mon Jun 04, 2018 8:49 pm
did your iphone recover or was it terminal?
Post by ChrisHolmes » Mon Jun 04, 2018 10:28 pm
I waited till it was dark and could see the screen, Settings and then adjusted the brightness and all is well. Having the back stuck to the mount doesn't help with cooling I am sure. Ali's had a power connection issue with the dashcam and git no footage of the afternoon session!
casey
Has thanked: 550 times
Been thanked: 801 times
Post by casey » Tue Jun 05, 2018 12:06 am
Club exclusive session from my car. Clive and Jon (boosted) disappear into the distance and I'm on my own for quite a while before catching up with back markers, then the dreaded Red Flag (but we only lost a minute or two :D)
Missed the Red Flag at Quarry, spotted the next one after the chicane....
Seibon Carbon Fibre Bonnet
"Racing Brake" front calipers
Racing Beat (RB) ARB's F&R, RB REVI intake, FULL RB Stainless Steel Exhaust & Mani, 20mm Eibach spacers, KOYO Ali Rad, Lightened Fly, Tein MonoFlex coilovers & strut brace, Axial short-shifter, BHR Coils & Engine Mounts, Greddy Sump
Federal 595RS-R (dry), Rainsport 3 (wet)
Has thanked: 43 times
Been thanked: 130 times
Post by SeanP » Tue Jun 05, 2018 12:53 am
I forgot about my iPhone - left in the console tunnel... Was almost too hot to handle and took a while before It would allow me to turn it on.
Harry's manual does say to try to direct some airflow over the iPhones when being used to record video... (I used my Android, and recorded video separately - which is then overlayed).
See now - the first outcome of this process - Session 1 10:15 with Overlays:
Forum Admin. R3, Diamond Grey = :twisted: HUGE smiles :twisted:
RoSPA & IAM Advanced Driving Tutor; Safe+Smooth+Systematic+Sparkle=FUN! Hayward rebuild@45K(s)miles, 17.5 MPG.
Track Addict: Green Hell :D, Spa :D, AutoSolos 10+, Donnington, Oulton, Blyton, Prodrive x3, Thruxton, Brands Hatch x3, NorthWeald x5, Bedford SW. (Vids, Pics);
Has thanked: 19 times
Post by DanBass » Tue Jun 05, 2018 8:09 am
Thanks for organising to everyone involved, we had a fantastic day. It was a warm one wasn’t it!
I have to make a formal apology and a rather embarrassing admission.
I apologise to those I held up slightly in the first track session. I was moving off the line as much as possible but I’m aware I held Clive and a couple of others up once or twice. I feel you’re owed an explanation :D
Basically, this was largely down to my being a moron and managing to suck around 30hp from the car... The evening before Combe I was farting about with the timing on the 5. Common mod in the mx-5 world is to advance timing 4 degrees as the stock tune is very conservative. In my rush to get everything done ready, I actually managed to retard timing instead of advance it, which meant that the car ran like utter crap below about 4K rpm, and consequently I had absolutely no acceleration out of some of the corners. Having now realised what I did and corrected it (all the while cursing my own stupidity) the car is now running beautifully again. So, I apologise to anyone who got stuck behind me. If it’s any consolation I spent most of the session screaming at the car inside my helmet wondering why it just wouldn’t go.
On the plus side, once I managed to get it back above 4K it was great fun and hopefully I didn’t hold anyone up too badly. I had a few hairy moments discovering the limits of my new road tyres, but had a great time. See you all soon!
boosted
Has thanked: 4 times
Been thanked: 160 times
Post by boosted » Tue Jun 05, 2018 8:32 am
Did you use a timing gun on the 14 deg mod? Ive done the mod a few times and moving the cas a tiny amount can effect the timing..its defo worth checking in a week or 2..and marking the timing mark makes it so much easier.
231 streetported Rx8 renny powered Westfield kit race car.
92 Rx7 fd3s stock twins..est.320bhp. Track car.
Post by DanBass » Tue Jun 05, 2018 8:48 am
I did yes, what I actually managed to do was forget which way round the TDC and 10deg marks are and turn the CAS the wrong way... you can see why I feel so dumb
boosted
Post by boosted » Tue Jun 05, 2018 9:10 am
Woudnt worry, depends which guide you read, so just checking standing at front of engine..turn cas Anti clockwise advance from big 10deg mark 2 notices to left on cam belt plastic cover? So 14deg of advance..thats the way i do it but i set to 12deg..some go to 18...with superunleaded.
Post by DanBass » Tue Jun 05, 2018 9:55 am
Yes, that’s exactly it, and what I should have done. I brain-failed and for some reason thought advance was clockwise so ended up at 6deg BTDC, hence the garbage performance. This is despite having successfully done this mod before now. What a pillock.
boosted
Post by boosted » Tue Jun 05, 2018 9:57 am
No worries..wouldnt beat yourself up..he who never makes a mistake never does anything...
casey
Post by casey » Tue Jun 05, 2018 11:32 am
No problem Dan, glad you got it sorted, and comforting to know we all make mistakes from time to time ;)
My second session, 14.15. According to RaceChrono, there's a 1m25.70 on lap 6, with loads of 1m26.XX's, so at least consistent. Must take more brave pills for Camp Corner, as I brake far too much for that bend, which compromises the flat out run all the way up to Avon Rise. Trouble is, I've seen too many videos of cars smashing into the wall out of that corner (and two "live" crashes as well)!!
Has thanked: 568 times
Been thanked: 778 times
Post by 13Black » Tue Jun 05, 2018 11:42 am
NO you leave those brave pills alone, I like your bonnet the way it is :D
Seems like you can do about 75mph through Camp judging from other people's footage.
On the subject of braking for corners, I noticed myself in your other video taking perhaps an unusual approach to Avon Rise... which may have something to do with the rear axle divergence I experienced earlier on in that session:
Incidentally, during the briefing when they mentioned strictly no drifting, I did grin and look over at Dan. First time I'd had a bit of a moment on Quarry, hopefully the last as well. I hope it found its way onto a 'Castle Combe Quarry Fail' video on Youtube.
Harrizone
Founder Member
Founder Member
Has thanked: 32 times
Been thanked: 208 times
Post by Harrizone » Tue Jun 05, 2018 11:55 am
I believe you were just trying to emulate the instruction you had seen on the van up on the bank :lol: .
Post by 13Black » Tue Jun 05, 2018 12:06 pm
^ It's hard to know if a sign is an instruction from the marshals or not when you're trying to ram it into 2nd gear without a synchro.
boosted
Post by boosted » Tue Jun 05, 2018 2:19 pm
had another look on gopoo and first session vid there, Bit of tyre squealing for Nick...
Rotary Potato
Has thanked: 59 times
Been thanked: 269 times
Post by Rotary Potato » Tue Jun 05, 2018 2:30 pm
Fortunately Nick had plenty of tarmac to play with, and was pretty much back in control by the time we had drifted (in every sense of the word! :lol: ) from the optimal line to the centre of the track. The only skidmarks were on the track and it remained calm-ish in the car.
Huw
Post by 13Black » Tue Jun 05, 2018 3:18 pm
No tyre squealing there from me Jon!
I had Chris behind me through Bobbies and saw Clive dive up the inside of him for Camp. I know there's no point giving a REW a run for its money so I backed right off but for some reason he just stuck behind me like a lemon, and Chris came by the both of us. :/
Got bored and put my foot down again for the straight then he comes past me just before Avon Rise. :/ really not sure what was happening there.
Saw you in the mirror and again moved right out of the way.
Speaking of which, it was good fun having a play with you Chris :D engine seems to be doing well and a few flames.
Kiwigaz also, car seems to be performing very well.
boosted
Post by boosted » Tue Jun 05, 2018 3:28 pm
I clarify abit ..my drifty moment at 3.13...tyres squealing
I can prob speak for Clive as to what he was doing and just making sure he was seen rather blast past and somebody go for an overtake themselves...i was tad naughty and overtook an 8 overtaking another 8...but thought that was the safest thing todo in nanonsecond of brain reasoning..so aplogise to whoever i did it too...
Lemon
Has thanked: 20 times
Been thanked: 115 times
Post by Lemon » Tue Jun 05, 2018 3:47 pm
let the court records show that i was not involved with any lemon based actions (that were not my own) :lol:
Thanks, Stu
Nso93
Forum Guest
Forum Guest
RX-8: Prospective Buyer
Been thanked: 8 times
Post by Nso93 » Tue Jun 05, 2018 6:51 pm
Your stand looked impressive at Coombe with nice selection of standard and modified cars. I had a look around. I was just up on the 350zuk stand
Post by 13Black » Tue Jun 05, 2018 6:57 pm
Maybe Steve (nightfire10) didn't want to make a song and dance about it but he deserves a big public thank you for sorting me out with a CC fitted steering wheel.
I've been on the lookout for one because I've been meaning to get Cruise up and running on mine before getting a customer in to finish his off.
After I missed out on one from a FB group, he managed to pick one up and insisted I have it for free - wouldn't tell me how much he paid for it or accept any money for it. Something about seeing me help people on the forum and wanting to square me up for it. Total nonsense of course but didn't want to argue :D
SeeJay agreed to pick it up at Combe and drop it off at my place too but in the end that wasn't necessary, but appreciated all the same :D
Great folks on here :thumright: true diamonds. Thank you thank you thank you.
Ray888
Colour: Aluminium Silver
Has thanked: 7 times
Post by Ray888 » Tue Jun 05, 2018 7:00 pm
That might of been me, look at my video on page 18, @8m37 in, if so, no worries at all, i saw you coming through Camp corner, so left you a space to pass as i was overtaking ;)
偉 文
Ray
Post by 13Black » Tue Jun 05, 2018 7:01 pm
Ah but did you try the cake? :D
Let's see your 350Z then, I'm sure a lot of us have considered them before settling on an 8.
Conan
Has thanked: 53 times
Been thanked: 664 times
Post by Conan » Tue Jun 05, 2018 8:03 pm
I left a couple of almost new chairs in the gazebo at Combe, one very green and the other not so green.
I was one of the last to leave but must of had a bit too much sun :) it was hot. Could someone drop them down to the next Cotswold meet for me please.
I had a very pleasant day there, catching up with some people and meeting some new faces as well :thumleft:
It was nice to turn up late and have nothing to do but relax and get chauford around the circuit a couple of times, thanks guys :thumleft:
The driving standards in the mixed sessions seemed very good compared to last year when there were a lot of problems, looks like there has been some tightnening up of the rules.
There is some very good videos of the day that i enjoyed watching and some nice driving from everyone :thumleft:
I am going to have to start doing some things to my car if you guys keep getting faster :)
Well done everyone
Return to “The Vault”
