water temps
Finalboss
Has thanked: 11 times
water temps
Post by Finalboss » Fri Sep 25, 2020 5:47 pm
Hi guys whats the consensus for safe water temps on track? Reading the american forums it seems 220 degrees F is the safe max around 105 degrees C in our money whats your thoughts?
Vj4sothername
Has thanked: 1484 times
Been thanked: 344 times
Re: water temps
Post by Vj4sothername » Fri Sep 25, 2020 6:07 pm
From my recent trackday at Mallory I was advised 105c is fine, 110c it's fine but time to come in and let it cool off.
Make sure your have all the foam around the radiator as it makes a huge difference to temps.
These users thanked the author Vj4sothername for the post:
Finalboss (Fri Sep 25, 2020 8:06 pm)
S1 - 231 - brilliant black
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
New Duke
Has thanked: 793 times
Been thanked: 712 times
Re: water temps
Post by New Duke » Fri Sep 25, 2020 6:43 pm
You'll be fine up at 115c too. You'll be hard pressed to get it higher than that unless it's a scorching day, or you have a fault, or you have some bananas mod that messes up airflow.
You may see coolant splatter over the engine bay. Don't worry, it's by design and just venting excess out of the overflow when v hot.
Your R3 PCM will cut the revs anyway if you really overheat it, to protect the engine. So you can push and not really worry.
Finalboss (Fri Sep 25, 2020 7:55 pm)
Has thanked: 492 times
Been thanked: 2016 times
Re: water temps
Post by warpc0il » Fri Sep 25, 2020 7:38 pm
:whathesaid:
If you've got an aftermarket gauge, just be wary if it goes really high (120+) and then drops to below normal.
This is what happens if the engine overheats, then dumps out so much coolant that the temperature sensor is no longer wet.
Don't ask how I know this #-o
Finalboss
Re: water temps
Post by Finalboss » Fri Sep 25, 2020 8:06 pm
thanks guys! Never knew the r3 had a limp mode, will this come in prior to it causing damage?
Has thanked: 24 times
Been thanked: 159 times
Re: water temps
Post by 350matt » Fri Sep 25, 2020 8:13 pm
110 sounds rather alarming to me
Has thanked: 214 times
Been thanked: 816 times
Re: water temps
Post by qwakers » Fri Sep 25, 2020 8:26 pm
why? its a pressurised system precisely so it can go that high.
New Duke
Re: water temps
Post by New Duke » Fri Sep 25, 2020 9:54 pm
I can't promise of course. But I've pushed it into limp mode through overheat lots of times (deliberately) and touch wood haven't broken it yet.
You'll also encounter limp mode as the first symptoms of fuel starvation too. At that point be smart and come into the pits. Don't do what I did today and then do another hot lap. It didn't end well.
Has thanked: 11856 times
Been thanked: 2912 times
water temps
Post by GreySilver Beast » Fri Sep 25, 2020 9:58 pm
Oh dear Haydn :(
GSB III 03/08/13 - Present
New Duke
Re: water temps
Post by New Duke » Fri Sep 25, 2020 10:00 pm
Oh dear Haydn :(
Got a big dent in my roof too in a separate incident. :(
water temps
Post by GreySilver Beast » Fri Sep 25, 2020 10:01 pm
How did that happen :?:
New Duke
Re: water temps
Post by New Duke » Fri Sep 25, 2020 11:10 pm
Got hit on the way home. Hoping it's repairable as the roof isn't exactly a replaceable panel. Am very annoyed. Will give you a ring next week to catch up :salut:
GreySilver Beast (Fri Sep 25, 2020 11:28 pm)
