Track day tyres
Markl17
Colour: Stormy Blue
Has thanked: 46 times
Been thanked: 193 times
Track day tyres
Post by Markl17 » Wed Aug 12, 2020 3:12 pm
Hi
I use Nankang na 2 r tyres.i have just taken them off to put the road wheels back on and noticed the front left has a ripple in the inner side wall I will post a pic but hard to see.
It looks like the side wall is de laminating but this is only a guess.it was very hot on Sunday and I was running the tyres at 1.7 bar hot.was this pressure to low or was it just the heat? It would be nice to have some opinions so I do not destroy any more tyres.
Also replacement recommendations would be helpful
Thanks mark
Conan
Has thanked: 60 times
Been thanked: 749 times
Re: Track day tyres
Post by Conan » Wed Aug 12, 2020 4:21 pm
That’s way too low for 1500 Kls of car in that heat
You probably should have been on 32 pounds not 25
I would advise that you buy Federal 595 RSRs for track day semi slicks
These users thanked the author Conan for the post (total 2):
Markl17 (Wed Aug 12, 2020 4:27 pm) • ChrisHolmes (Wed Aug 12, 2020 8:58 pm)
Markl17
Colour: Stormy Blue
Re: Track day tyres
Post by Markl17 » Wed Aug 12, 2020 5:08 pm
Thanks Pete
I have just had a look at the federal 595 RSRs and they seam a be good value at 105 euro each do they last a decent amount of time? ( if I look after them properly)
Mark
casey
Has thanked: 1249 times
Been thanked: 1465 times
Re: Track day tyres
Post by casey » Wed Aug 12, 2020 6:07 pm
I've had 5 sets of 595 RSRs and, if dry weather is forecast, usually put the wheels on the car to drive to the circuit, do the trackday and drive back on them. I'd say I got an average of around 7 full trackdays out of them with this usage. The front outer shoulders will wear most, so swapping front and rear pairs helps even the wear a bit. I've even managed 11 trackdays by reversing a set of tyres on the rims to use the better shoulders!
Beware using these tyres in very wet conditions when tread is less than 3mm. Cornering gets quite interesting!
These users thanked the author casey for the post (total 2):
Markl17 (Wed Aug 12, 2020 7:02 pm) • ChrisHolmes (Wed Aug 12, 2020 8:58 pm)
Club Secretary
Seibon Carbon Fibre Bonnet
Markl17
Colour: Stormy Blue
Re: Track day tyres
Post by Markl17 » Wed Aug 12, 2020 7:07 pm
I think I will order a set is 235/40/18 the best size to buy for stock wheels? This is the size of the nankangs I wrecked.
Thanks mark
casey
Re: Track day tyres
Post by casey » Wed Aug 12, 2020 8:15 pm
Yep, that's the size I've been using :thumleft:
Markl17 (Wed Aug 12, 2020 8:26 pm)
Club Secretary
Has thanked: 492 times
Been thanked: 2016 times
Re: Track day tyres
Post by warpc0il » Wed Aug 12, 2020 10:15 pm
Looks like the pressure was too low and you might have hooked a curb.
Markl17 (Thu Aug 13, 2020 7:17 am)
Markl17
Colour: Stormy Blue
Re: Track day tyres
Post by Markl17 » Thu Aug 13, 2020 7:19 am
The curb are very tempting there,
Mark
These users thanked the author Markl17 for the post:
Vj4sothername (Thu Aug 13, 2020 8:27 am)
Conan
Re: Track day tyres
Post by Conan » Thu Aug 13, 2020 12:01 pm
Hi Mark,
235x40 is the best size for most on track or road.
The Federal RSRs are good value for money and can last approx 9 open pit lane track days
depending on conditions and driver. You can run them at 30 psi on road and 32 on track, they have a stiff sidewall.
You should run camber of 11/2 to 2 degrees depending on speed of cornering and front wheels straight ahead.
Curbs are there to drive on ( there part of the track ) ;)
And what Casey (Malcolm) said
Have fun
Markl17 (Thu Aug 13, 2020 12:23 pm) • casey (Thu Aug 13, 2020 12:26 pm)
Re: Track day tyres
Post by warpc0il » Thu Aug 13, 2020 7:53 pm
Riding the curbs is fine, it's just when you drop in the hole just beyond the curb that it can hurt.
Saw an MX-5 "track weapon" completely remove the inner bead from the rim doing this at Kirkistown, despite the warning in the briefing, and the holes being pointed-out in the pre-start track walk.
Markl17
Colour: Stormy Blue
Re: Track day tyres
Post by Markl17 » Mon Aug 17, 2020 4:20 pm
I had a delivery today,I just need to get them fitted now.
Then I have a track day on the 6th of September
Mark
Sorry I cannot rotate the pictures
casey
Re: Track day tyres
Post by casey » Mon Aug 17, 2020 5:31 pm
Well done, let us know how you find them.
Based on my experience and many other "trackies" on here, you'll love pushing these on track! The grip and confidence they give powering through corners is brilliant.
Club Secretary
v-rex
Has thanked: 519 times
Been thanked: 194 times
Re: Track day tyres
Post by v-rex » Mon Aug 17, 2020 5:33 pm
viewtopic.php?f=6&t=82292
In case that helps for next time....
These users thanked the author v-rex for the post (total 2):
Markl17 (Mon Aug 17, 2020 6:00 pm) • GreySilver Beast (Mon Aug 17, 2020 6:56 pm)
v-rex
Re: Track day tyres
Post by v-rex » Mon Aug 17, 2020 5:35 pm
Are federal 595R's road legal? Can you drive to the track with them? Or do you swap them somehow once there?
casey
Re: Track day tyres
Post by casey » Mon Aug 17, 2020 5:37 pm
Road legal :thumleft:
v-rex (Mon Aug 17, 2020 6:03 pm)
Club Secretary
New Duke
Has thanked: 793 times
Been thanked: 712 times
Re: Track day tyres
Post by New Duke » Mon Aug 17, 2020 5:58 pm
Just be very careful with them on public roads in the cold and wet.
Markl17
Colour: Stormy Blue
Re: Track day tyres
Post by Markl17 » Mon Aug 17, 2020 6:04 pm
The ns2r’s were bad in the wet ,luckily the roads do not get to cold here ,thanks for the heads up.
Mark
v-rex
Re: Track day tyres
Post by v-rex » Mon Aug 17, 2020 6:05 pm
So just like when I had the original RE040A's on my car? :lol:
V8 Power
Has thanked: 238 times
Been thanked: 490 times
Re: Track day tyres
Post by V8 Power » Mon Aug 17, 2020 6:35 pm
They are ok in the wet you just need to get a bit of heat in them.
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
MSD leads
casey
Re: Track day tyres
Post by casey » Mon Aug 17, 2020 8:26 pm
I drove around Oulton Park on brand new 595RSRs in the wet and was impressed by the grip. I found they were "OK" in the wet until the tread got down to ~3mm, then you had to be cautious.
Club Secretary
benedwards64
Been thanked: 36 times
Re: Track day tyres
Post by benedwards64 » Wed Aug 19, 2020 3:43 pm
Re: pressure, I've run dozens of track days and sprints on either Toyo R888R or Yoko A050s. I tend to set pressures 'cold' at 26psi, then let them rise up to 28 or so.
These users thanked the author benedwards64 for the post (total 2):
Markl17 (Wed Aug 19, 2020 4:19 pm) • New Duke (Wed Aug 19, 2020 11:42 pm)
