Tyre question
rameshr
Has thanked: 8 times
Been thanked: 83 times
Tyre question
Post by rameshr » Sun Jun 21, 2020 11:02 am
So have a evening session at Brands, I have 2 pairs of 595rs. One pair has 1mm above marker and the other pair has 2mm. Am I right in thinking I should put the pair with more thread on the front?
Half-Bridge Engine
Lightened Fly + Clutch
Whiteline ARB's + Droplinks
Brake Upgrade 4 pot front
AEM Intake
D969 Coils
YellowSpeed Suspension
Dwell timers adjusted
Short Shifter
Braided Brake + Clutch Lines
Has thanked: 492 times
Been thanked: 2016 times
Re: Tyre question
Post by warpc0il » Sun Jun 21, 2020 11:13 am
It depends if it's likely to be wet, it which case probably yes.
However, the more worn pair will have a smaller rolling diameter and will therefore rotate faster for the same road speed, which the traction control will detect as wheelspin...
rameshr
Re: Tire question
Post by rameshr » Sun Jun 21, 2020 11:14 am
I am hoping it’s going to dry...if wet will stick to rain sports I have now on.
Half-Bridge Engine
AEM Intake
D969 Coils
Short Shifter
Re: Tyre question
Post by warpc0il » Sun Jun 21, 2020 12:52 pm
In that case I'd put the less worn pair on the rear, as this will not only prevent the TC triggering prematurely but also stop the ABS thinking that the fronts are starting to lock.
Given enough hot laps, the wear might even out, unless you're really hard on the brakes.
Note that you always put the best tyres on the front, for road use, regardless of FWD/RWD, but that's much more about wet grip.
rameshr (Sun Jun 21, 2020 6:48 pm)
rameshr
Re: Tyre question
Post by rameshr » Sun Jun 21, 2020 1:23 pm
Thank you
Half-Bridge Engine
AEM Intake
D969 Coils
Short Shifter
Salokin
Has thanked: 135 times
Been thanked: 109 times
Re: Tyre question
Post by Salokin » Sun Jun 21, 2020 1:40 pm
warpc0il wrote:In that case I'd put the less worn pair on the rear, as this will not only prevent the TC triggering prematurely but also stop the ABS thinking that the fronts are starting to lock.
I'm a tad confused now as I always thought you put your best tyres (the ones with most tread) on the rear in a RWD car? Image
Re: Tyre question
Post by warpc0il » Sun Jun 21, 2020 1:53 pm
Nope. New tyres always go on the front.
Salokin (Sun Jun 21, 2020 2:28 pm)
V8 Power
Has thanked: 238 times
Been thanked: 490 times
Re: Tyre question
Post by V8 Power » Sun Jun 21, 2020 2:11 pm
From Continental
“Mixing different tread depths is generally permissible. The tyre industry recommends fitting the new tyres onto the rear axle. This will provide greater grip to the rear axle and mitigate any potential oversteer condition or loss of vehicle stability on slippery surfaces.”
https://www.continental-tyres.co.uk/car ... xing-tyres
These users thanked the author V8 Power for the post (total 2):
Salokin (Sun Jun 21, 2020 2:28 pm) • rameshr (Sun Jun 21, 2020 6:48 pm)
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
MSD leads
rameshr
Re: Tyre question
Post by rameshr » Sun Jun 21, 2020 2:34 pm
I would prefer oversteer to understeer? Which is what could happen if the front has less thread?
Half-Bridge Engine
AEM Intake
D969 Coils
Short Shifter
Conan
Has thanked: 60 times
Been thanked: 749 times
Re: Tyre question
Post by Conan » Sun Jun 21, 2020 5:53 pm
Oversteer will put you in the barrier backwards at 100mph plus before you even realise what is happening
The 5g sideways on your brain moving inside your skull will make sure you never realise what had really happened.
The reason I know this is the amount of times I have had cars snap round during racing and testing whilst pushing the boundaries
Eventually I got used to it as does a boxer so my brain would continue to work through the situation.
The classic example was at the clubs track day at Spa when the TVR Tuscan on loan from Ranjan boiled the brake fluid snatching a brake and sending us backwards at 140mph in a blink, I remember thinking no one will believe this and then smiling as Paula grabbed my arm before retrieving the situation through sheer luck and lots of practice at crashing :)
I would always put the best tyres on the back regardless of front or rear wheel drive myself, understeer can be controlled quite often where oversteer is in the hands of the Gods ( and we’re not Gods )
If it’s dry use the rsr,s and wet use the road tyres
These users thanked the author Conan for the post (total 2):
GreySilver Beast (Sun Jun 21, 2020 6:24 pm) • rameshr (Sun Jun 21, 2020 6:48 pm)
rameshr
Re: Tyre question
Post by rameshr » Sun Jun 21, 2020 6:09 pm
Okay so two opposing opinions from experienced people...I need a third lol
Half-Bridge Engine
AEM Intake
D969 Coils
Short Shifter
V8 Power
Re: Tyre question
Post by V8 Power » Sun Jun 21, 2020 6:13 pm
It is not my opinion it is the tyre industry opinion and advice.
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
Has thanked: 11856 times
Been thanked: 2912 times
Tyre question
Post by GreySilver Beast » Sun Jun 21, 2020 6:27 pm
I was always taught to put the better tyres on the back regardless if it was FWD or RWD :thumleft:
@Pete : You left out the bit about Paula being white as a sheet when you both came back into the Pits :lol:
GSB III 03/08/13 - Present
Goobie
Has thanked: 40 times
Been thanked: 368 times
Re: Tyre question
Post by Goobie » Sun Jun 21, 2020 8:53 pm
The general rule/advice “used” to be always put the new on the front. Some years ago now that all changed and hand books etc all state the rear.
This is all pretty much down to two factors, rain and most of all sitting water on the roads!
Worn tyres offer little to no water channeling, after lots of crash data was looked at and so on showed that having better grip on the front compared to rear regardless of how much tread showed driving though large puddles that cause aquaplaning would cause the rear to spin out.
rameshr
Re: Tyre question
Post by rameshr » Sun Jun 21, 2020 8:57 pm
Am guessing in the dry, I would want better stopping so I figured putting the tires with more thread on the front.
I leave TC on so can see what the car feels like and swap them. But with a small window on track just wanted to get some advice.
Honestly thought this would have been a quick answer lol
Half-Bridge Engine
AEM Intake
D969 Coils
Short Shifter
Re: Tyre question
Post by warpc0il » Sun Jun 21, 2020 9:44 pm
In the dry, the amount of tread has little effect on grip.
V8 Power
Re: Tyre question
Post by V8 Power » Sun Jun 21, 2020 10:02 pm
4mm of tread gives 11% more grip than 8mm of tread in the dry.
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
