Forge Action Day 2018 | Saturday 8th September | Castle Combe
From non-stop track action to huge club displays and some of the biggest names in the performance scene, this is not to be missed!
Track Action / Drifting Demos / Passenger Rides / RX-8 Club Stand / Show & Shine Competition / Forge Motorsport Exhibitor Village
Tickets available in the Club shop now!
Mazda RX8 & R3 Tein Flex Z Damper Kit (New)
Rebuild, Maintenance, Servicing RX7 & RX8 vehicles
LC Rotary
Forum Trader
Forum Trader
Has thanked: 16 times
Been thanked: 11 times
Post by LC Rotary » Wed Mar 22, 2017 6:13 pm
https://www.lcrotary.co.uk/products/maz ... damper-kit
£739.00 - fitting service available....
NEW FLEX Z DAMPER IS THE LATEST EVOLUTION OF TEINS EXCELLENT FLEX COILOVER KIT.
Developed to provide the ultimate balance of comfort and performance for both street driving and circuit use and is fully compatible with Tein's EDFC systems to adjust the shock absorbers either from the drivers seat or Automatically Along with a wide-range damping force adjustment using their new Advance Needle technology and new damper valving specs, giving the driver a much more noticeable feel in damping force change and controllability.
FEATURES:
-Steel Construction
-Twin Tube Internal Construction
-Full-Length Adjustable via Threaded Body and Spring Seat/Seat Locks
-16-Way Damping Adjustable (simultaneous compression and rebound)
-New Damper Valving Specifications for Improved Street Comfort
-Incorporated Advance Needle Design (nearly 200% improvement over predecessor)
-Pillowball Upper Mounts for increased steering feedback
-Larger Piston Diameter (22mm O.D.) for Strut Type
-EDFC (Electronic Damping Force Controller)/EDFC Active Compatible (option)
-Powdercoated Brackets and ZT Coated Shellcase for Outstanding Rust Prevention
-One Year Warranty Against Manufacturer's Defect
Compatible:
Tein EDFC Active
With EDFC (Electronic Damping Force Controller) series installed, damping force can be controlled from the cockpit with ease. Stepping motors attached in place of adjustment knobs control the damping force quickly and accurately.
Use of EDFC turns 16-level adjustment into finer 32-level or 64-level adjustment mode (64-level only available with EDFC ACTIVE / EDFC ACTIVE PRO), to provide the optimum performance by fully utilising the damping force adjustable range drastically widened by the use of "ADVANCE Needle"
Has thanked: 162 times
Been thanked: 614 times
Re: Mazda RX8 & R3 Tein Flex Z Damper Kit (New)
Post by warpc0il » Wed Mar 22, 2017 6:38 pm
Is that the price including the EDFC? If not, then how much is the full system?
Velocity_Dan93
Has thanked: 23 times
Been thanked: 47 times
Post by Velocity_Dan93 » Wed Mar 22, 2017 6:52 pm
Also interested in a price with the EDFC active pro
VR Mazdaspeed with lambo doors yo!
RR rebuild with full bridge and lightweight rotors.
CC ultra lightweight flywheel, pettit flywheel nut and lightweight underdrive pulleys.
AEM intake, full RB exhaust system, custom SOHN and catch can, greddy sump, Mishimoto cooling system and oil lines. Brap
LC Rotary
Forum Trader
Forum Trader
Post by LC Rotary » Thu Mar 23, 2017 3:22 pm
Price Quoted above is for the coilovers, EDFC's are optional extras
Installation relatively straight forward, but time consuming routing to all 4 corners and fixing the controllers in sensible and accessible locations. Look great when fitted right. Will add some pictures later.
EDFC ACTIVE PRO with GPS Kit £750
EDFC ACTIVE PRO without GPS Kit £690
EDFC ACTIVE with GPS Kit £530
EDFC ACTIVE without GPS Kit £470
EDFC II £245
Goobie
Has thanked: 18 times
Been thanked: 83 times
Post by Goobie » Thu Sep 07, 2017 1:49 am
EDFC II £245
Anybody got/using the edfc active kit? Any reviews on an RX-8??
SeeJay
Has thanked: 174 times
Been thanked: 275 times
Post by SeeJay » Fri Mar 30, 2018 7:03 pm
I'm pretty certain Clive (MRP) has EDFC on his race RX8..
Goobie
Post by Goobie » Fri Mar 30, 2018 7:56 pm
Thanks for the heads up SeeJay.
Although, you may of missed I did purchase the full Pro GPS kit September last year, from Clive too, lol.
Mpv2k3
Has thanked: 119 times
Post by Mpv2k3 » Fri Mar 30, 2018 10:59 pm
Goobie, have you fitted these yet? Be interested in knowing what you think of them on the R3
Has thanked: 4735 times
Been thanked: 1153 times
Post by GreySilver Beast » Fri Mar 30, 2018 11:23 pm
I looked into getting the complete kit for the GT86 once upon a time :P , so be interested in seeing how you both get on with this fitted to your R3's :thumleft:
RX-8OC Club Calendar - GBCC Network Delivery Service
Track Days = 54.5/Sprint Days = 13/Car Limits 4 person = 3/Skid Pan = 1/Go Karting = 1/Cars Driven = 177
http://npt-communications.webs.com < Click > ****GSB III**** - GT86 Track Days = 45
Goobie
Post by Goobie » Sat Mar 31, 2018 2:33 pm
Each time I’ve had the chance, either the weather been bad or something come up and stole my cleared day!
The car now got no suspension on it, but this time I’ve good reasons to why I’m not fitting it yet which your see soon in my thread.
Should be awesome, as got the roll bars and links too.
The “money shot”!
wiggles
Has thanked: 75 times
Been thanked: 94 times
Post by wiggles » Sat Mar 31, 2018 2:38 pm
The loads of money shot!
Project thread Galaxy grey 231 - Street Port, Enkei 9J wheels, Tein coilovers, Jperformance exhaust
Post by GreySilver Beast » Sat Mar 31, 2018 3:16 pm
The Racing Beat ARB's are really good Goobie =D> =D> =D> =D>
Mpv2k3
Post by Mpv2k3 » Sat Mar 31, 2018 3:45 pm
Goobie, do you need an adaptor for the tein motors to fit on the top of the shocks due to the engine struts on the R3? Believe the struts block the tops.
Goobie
Post by Goobie » Sat Mar 31, 2018 5:17 pm
That is a good question, looking at it, the motors are very slim and where they go is very reset in the top hat ie deep dish so to speak. I think all I’d need todo is cut a sandwich slot on the edge of the brace mount foot for the wire to past?
The brace is non structural anyway, so popping a slot or drilling a hole for passing wires shouldn’t be a problem. Il have to whip em out and stick one on to confirm.
Mine are the MonoSports coilovers, so not sure if the top fixing points differ to the Flex z’s?, they appear to look the same.
They was my first purchase from Clive, in fact, I bought my whole kit above from him, great bloke.
Got a better one than that come next month! Haha.
Return to “LC Rotary”
